I submitted an issue in Github - it has to do with changes in the Python system used for the newest Domoticz BètaSnowtiger wrote:Update Domoticz Bèta 3.7602 - Buienradar (Weather Lookup) Type in Hardware types is missing and no actual information is delivered anymore by the Plugin.
Somebody else with the same experience?
Buienradar Weather Lookup Plugin
Snowtiger
Re: Buienradar Weather Lookup Plugin
ffes
I've seen the issue on GitHub. From the top of my head, the changes that are mention in "advance warning" are not used by my plugin, so I need to dive in to see what goes wrong.Snowtiger wrote:I submitted an issue in Github - it has to do with changes in the Python system used for the newest Domoticz BètaSnowtiger wrote:Update Domoticz Bèta 3.7602 - Buienradar (Weather Lookup) Type in Hardware types is missing and no actual information is delivered anymore by the Plugin.
mivo
same problem with my own plugin - prebuilt beta binary tarballs are compiled without Python suport - from v3.7602 hash f39f21d.
viewtopic.php?f=6&t=17778#p136671
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
assenzuid
After the Domoticz Beta 3.7602 the plugin has stop working.
ffes
After a short investigation I also noticed that the plugins are disabled at the moment in the master branch and in the downloadable beta release. It is mentioned in many other posts in this forum as well. So it is up to the devs of domoticz to fix the issue and enable Python plugins again. When I build domoticz myself and enable Python plugins the Buienradar plugin just work.
- differentieel
- Domoticz version: 2021.1
thank for doing this job for us - - works like charm - - but only in the DEV version
assenzuid
update to v3.7686 beta and the plugin is working again.
- Brutus
After installing this version my Domoticz keeps crashing at booting...assenzuid wrote:update to v3.7686 beta and the plugin is working again.
Windows 10 v3.7686
Buienradar.nl plugin,
Kodi Plugin 1.7.0 (Disabled)
It think the Buienradar plugin needs to be updated because of the new phyton interface?
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
28x Fibaro Modules
SMA Solar System
assenzuid
Mine is also not running stable, web interface stops working
Snowtiger
Buienradar is working again at Bèta 3.7686, for flooding log file see - http://www.domoticz.com/forum/viewtopic ... 20#p136763 or just remove the files, the demo files mentioned in the post are already present.
Harald777
- Domoticz version: Latest
On Beta v3. 7676 all running fine for some hours and than Domoticz stops working. This only happens when when the Buienradar plugin is active.
Hope to see this fixed in the near future.
Snowtiger
update to latest Domoticz Bèta, some problems fixed in Python Domoticz part - no problem any moreHarald777 wrote:On Beta v3. 7676 all running fine for some hours and than Domoticz stops working. This only happens when when the Buienradar plugin is active.
Harald777
Thanks for the info, updating now.Snowtiger wrote:update to latest Domoticz Bèta, some problems fixed in Python Domoticz part - no problem any moreHarald777 wrote:On Beta v3. 7676 all running fine for some hours and than Domoticz stops working. This only happens when when the Buienradar plugin is active.
Hope the issue are solved and indeed I have been reading that it is python related.
Snowtiger
to be precise - the problems where Python related but in the new Domoticz events system - had nothing to do with Buienradar pluginHarald777 wrote:Thanks for the info, updating now.Snowtiger wrote:update to latest Domoticz Bèta, some problems fixed in Python Domoticz part - no problem any moreHarald777 wrote:On Beta v3. 7676 all running fine for some hours and than Domoticz stops working. This only happens when when the Buienradar plugin is active.
Harald777
Yes I know. Hope to see this fixed soon. Really love this plugin but for now i switched of the plugins completely. Just had another Domoticz crash on latest beta. Two crashes a day is too much.Snowtiger wrote:to be precise - the problems where Python related but in the new Domoticz events system - had nothing to do with Buienradar pluginHarald777 wrote:Thanks for the info, updating now.Snowtiger wrote:update to latest Domoticz Bèta, some problems fixed in Python Domoticz part - no problem any more
Verstuurd vanaf mijn Nexus 5X met Tapatalk
Harald777
Is someone running this plugin stable? I am still getting domoticz shut downs 3 times a day when I use this "python" plugin. Only renaming my plugin folder solves the issue.
Perhaps a new and fresh domoticz installation solves the problem?????
Verstuurd vanaf mijn Nexus 9 met Tapatalk
ffes
Some major work has been done on the python plugins in Domoticz recently. Not sure how stable it is at the moment. My Domotics at home is not running as it should be (problem with my hardware), so I can only test a little.
Harald777
Hope to see this plugin working again in the near future.ffes wrote:Some major work has been done on the python plugins in Domoticz recently. Not sure how stable it is at the moment. My Domotics at home is not running as it should be (problem with my hardware), so I can only test a little.
Today updated my pi, including all installed packages.
Activated the Buienradar plugin and unfortunately within a few hours Domoticz was offline again.
- Brutus
Is it possible to include the "Solar Irradiance" and "Visibility" ?
They come visible at the log but not as a device.
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
- G3rard
- Target OS: -
- Domoticz version: No
I have made some updates to the Buienradar script of @ffes.
Added the following devices (data from xml.buienradar.nl):
* Visibility
* Solar radiation
* Rain rate
* Weather forecast
* Rain forecast (uses data from https://gps.buienradar.nl/getrr.php?lat=51&lon=3)
Check this Dutch site for more information on the rain forecast.
I have made a pull request for this and hopefully it will be merged
* Visibility
* Solar radiation
* Rain rate
* Weather forecast
Not using Domoticz anymore
