Buienradar Weather Lookup Plugin
Snowtiger
Domoticz version: 4.10915
Re: Buienradar Weather Lookup Plugin
Post by Snowtiger »
Snowtiger wrote:Update Domoticz Bèta 3.7602 - Buienradar (Weather Lookup) Type in Hardware types is missing and no actual information is delivered anymore by the Plugin.
Somebody else with the same experience?
I submitted an issue in Github - it has to do with changes in the Python system used for the newest Domoticz Bèta
ffes
Post by ffes »
I've seen the issue on GitHub. From the top of my head, the changes that are mention in "advance warning" are not used by my plugin, so I need to dive in to see what goes wrong.
mivo
Post by mivo »
same problem with my own plugin - prebuilt beta binary tarballs are compiled without Python suport - from v3.7602 hash f39f21d.
viewtopic.php?f=6&t=17778#p136671
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
assenzuid
Post by assenzuid »
After the Domoticz Beta 3.7602 the plugin has stop working.
ffes
Post by ffes »
After a short investigation I also noticed that the plugins are disabled at the moment in the master branch and in the downloadable beta release. It is mentioned in many other posts in this forum as well. So it is up to the devs of domoticz to fix the issue and enable Python plugins again. When I build domoticz myself and enable Python plugins the Buienradar plugin just work.
differentieel
Domoticz version: 2021.1
Post by differentieel »
thank for doing this job for us - - works like charm - - but only in the DEV version
assenzuid
Post by assenzuid »
update to v3.7686 beta and the plugin is working again.
Brutus
Post by Brutus »
assenzuid wrote:update to v3.7686 beta and the plugin is working again.
After installing this version my Domoticz keeps crashing at booting...
Windows 10 v3.7686
Buienradar.nl plugin,
Kodi Plugin 1.7.0 (Disabled)
It think the Buienradar plugin needs to be updated because of the new phyton interface?
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
assenzuid
Post by assenzuid »
Mine is also not running stable, web interface stops working
Snowtiger
Post by Snowtiger »
Buienradar is working again at Bèta 3.7686, for flooding log file see - http://www.domoticz.com/forum/viewtopic ... 20#p136763 or just remove the files, the demo files mentioned in the post are already present.
Harald777
Domoticz version: Latest
Post by Harald777 »
On Beta v3. 7676 all running fine for some hours and than Domoticz stops working. This only happens when when the Buienradar plugin is active.
Hope to see this fixed in the near future.
Snowtiger
Post by Snowtiger »
Harald777 wrote:On Beta v3. 7676 all running fine for some hours and than Domoticz stops working. This only happens when when the Buienradar plugin is active.
update to latest Domoticz Bèta, some problems fixed in Python Domoticz part - no problem any more
Harald777
Post by Harald777 »
Thanks for the info, updating now.
Hope the issue are solved and indeed I have been reading that it is python related.
Snowtiger
Post by Snowtiger »
to be precise - the problems where Python related but in the new Domoticz events system - had nothing to do with Buienradar plugin ;)
Harald777
Post by Harald777 »
Snowtiger wrote:
Harald777 wrote:
Snowtiger wrote:update to latest Domoticz Bèta, some problems fixed in Python Domoticz part - no problem any more
Yes I know. Hope to see this fixed soon. Really love this plugin but for now i switched of the plugins completely. Just had another Domoticz crash on latest beta. Two crashes a day is too much.
Verstuurd vanaf mijn Nexus 5X met Tapatalk
Harald777
Post by Harald777 »
Is someone running this plugin stable? I am still getting domoticz shut downs 3 times a day when I use this "python" plugin. Only renaming my plugin folder solves the issue.
Perhaps a new and fresh domoticz installation solves the problem?????
Verstuurd vanaf mijn Nexus 9 met Tapatalk
ffes
Post by ffes »
Some major work has been done on the python plugins in Domoticz recently. Not sure how stable it is at the moment. My Domotics at home is not running as it should be (problem with my hardware), so I can only test a little.
Harald777
Post by Harald777 »
ffes wrote:Some major work has been done on the python plugins in Domoticz recently. Not sure how stable it is at the moment. My Domotics at home is not running as it should be (problem with my hardware), so I can only test a little.
Hope to see this plugin working again in the near future.
Today updated my pi, including all installed packages.
Activated the Buienradar plugin and unfortunately within a few hours Domoticz was offline again.
Brutus
Post by Brutus »
Is it possible to include the "Solar Irradiance" and "Visibility" ?
They come visible at the log but not as a device.
28x Fibaro Modules
SMA Solar System
G3rard
Domoticz version: No
Post by G3rard »
I have made some updates to the Buienradar script of @ffes.
Added the following devices (data from xml.buienradar.nl):
* Visibility
* Solar radiation
* Rain rate
* Weather forecast
* Rain forecast (uses data from https://gps.buienradar.nl/getrr.php?lat=51&lon=3)
Check this Dutch site for more information on the rain forecast.
I have made a pull request for this and hopefully it will be merged :D
Not using Domoticz anymore
