Send Z-Wave command in script?
- Ben0it
- Domoticz version: 3.6745
Is it possible to send a Z-Wave command to a device in LUA?
For instance, I would like to change the ring color of a Fibaro wall plug (FGWPE). Using the OpenZWave control panel (as shown in the picture below) I can do this, but using a LUA script, is it possible also?
Best Regards,
Best Regards,
Benoît.
Benoît.
- Egregius
- Domoticz version: v2024.7
Re: Send Z-Wave command in script?
Don't know about lua, but possible in PHP:
What to post can be looked up in developer view of your browser. The example above sets the illumination to green of node 85.
The first file_get_contents is just for authentication.
<?php
$domoticzurl='http://127.0.0.1:8080/';
$zwaveidx=7;
file_get_contents($domoticzurl.'json.htm?type=openzwavenodes&idx='.$zwaveidx);
function ValuePost($command) {
global $domoticzurl;
$zwaveurl=$domoticzurl.'ozwcp/valuepost.html';
$zwaveoptions = array('http'=>array('header'=>'Content-Type: application/x-www-form-urlencoded\r\n','method'=>'POST','content'=>$command,),);
$zwavecontext=stream_context_create($zwaveoptions);
$result=file_get_contents($zwaveurl,false,$zwavecontext);
return $result;
echo ValuePost('85-CONFIGURATION-config-list-1-62=Green illumination');
- Ben0it
Thanks for the code, I will try it and report about the result here.
Benoît.
Benoît.
- Ben0it
Good evening,
Finally, I could find some spare time to play with these commands...it works!
Thanks a lot for the hint.
Best Regards,
Best Regards,
Benoît.
Benoît.
- Egregius
You're sure the 3th line is still in the code?
Without that line the second url fails after some time.
file_get_contents($domoticzurl.'json.htm?type=openzwavenodes&idx='.$zwaveidx);- Ben0it
Here is my code, I invoque from BASH interpreter with arguments:
Invocation from shell is performed as follows:
2016-03-28 - Actually, it seems to fail after a while. Once it fails, if I manually change a parameter from Domoticz' web interface in the OZW control panel, my script works again.
Best Regards,
$domoticzURL = 'http://127.0.0.1:8080/';
if (count($argv) != 4)
$command = basename($argv[0]);
echo "Usage: {$command} node function value\n";
exit(0);
$zwaveNodeID = $argv[1];
$nodeFunction = $argv[2];
$nodeFunctionValue = $argv[3];
function Authenticate($domoticzURL, $zwaveIDX)
$result = json_decode(file_get_contents($domoticzURL.'json.htm?type=openzwavenodes&idx='.$zwaveIDX, false, NULL), true);
if (strtoupper($result['status']) == "OK")
return true;
return $result;
function SetNodeValue($domoticzURL, $zwaveNodeID, $functionNumber, $functionValue)
$zwaveURL = $domoticzURL.'ozwcp/valuepost.html';
$zwaveCommand = "{$zwaveNodeID}-CONFIGURATION-config-list-1-{$functionNumber}={$functionValue}";
$zwaveOptions = array('http'=>array('header'=>'Content-Type: application/x-www-form-urlencoded\r\n','method'=>'POST','content'=>$zwaveCommand,),);
$zwaveContext = stream_context_create($zwaveOptions);
$result = file_get_contents($zwaveURL, false, $zwaveContext);
if (strtoupper($result) == "OK")
return true;
return $result;
$result = Authenticate($domoticzURL, $zwaveNodeID);
if ($result != true)
echo "Failed to authenticate: {$result}";
return 1;
$result = SetNodeValue($domoticzURL, $zwaveNodeID, $nodeFunction, "{$nodeFunctionValue}");
echo "Failed to set parameter: {$result}";
return 2;
return 0;Code: Select all
php -f bin/ozwcmd.php 3 62 "Red illumination"Best Regards,
Benoît.
Benoît.
leoncornelissen
- Domoticz version: 3.8258
If I look at the PHP code, I would say that one should be able to convert this to a curl command.
I don't know how I should use the PHP code. I don't have the file: 'ozwcp/valuepost.html';
I want to have a simple curl command to switch the alarm sound of the zwave aeotec siren dependend of the situation.
juankar
- Domoticz version: 4.
Curl command equivalent:
curl --data "85-CONFIGURATION-config-list-1-62=Green illumination" http://127.0.0.1:8080/ozwcp/valuepost.html
valuepost.html does not exist as webpage, it's a page "inside http Domoticz server"
rgvandenbosch
Hi there,
I was wondering. When invoking the script with nodeID, Function and Value, how does one know the id of the function and the possible values. In the examples the function '62' is called. What is function 62 and what are the other functions?
Hope someone can help.
Thanx in advance.
Thanx in advance.
I have the same question. How did you come up with the "85-CONFIGURATION-config-list-1-62=Green illumination" string? Thanks.
