doloers
Post by doloers »
Have anybody import two xiaomi gateway into Domoticz?
Will switch have diff idx but same id?Will witch have same id works well?
burton666
Post by burton666 »
Sorry if this has been answered already, but is the "new" xiaomi ceiling light supported? http://www.gearbest.com/ceiling-lights/pp_596249.html
lamouette
Post by lamouette »
burton666 wrote:Sorry if this has been answered already, but is the "new" xiaomi ceiling light supported? http://www.gearbest.com/ceiling-lights/pp_596249.html
yes
burton666
Post by burton666 »
yes
Are you sure, I do not find any info in the wiki and I have browsed the last 10 pages without finding any relevant info. The ceiling light came out less then a month ago I think.
lamouette
Post by lamouette »
consider it a classic yeelight product
burton666
Post by burton666 »
Ok, sorry for all the questions but it is quite hard finding info from the forums from the phone. Is the light controlled by the gateway in any way or is it a compleatly separate "plugin"? And is it controllable by bluetooth or wifi?
Revers59
Post by Revers59 »
are there a way to do a loop for the Alarme Ringtone ?
Here when the alarm is 'on' the sound play just one time.
lamouette
Post by lamouette »
The light is not connected to the gateway.
It is working via wifi.
corbin
Post by corbin »
ben53252642 wrote: Build 3.7602
Any ideas?
Yes - compile from https://github.com/corbinmunce/domoticz as this is still being tested
Derik
Post by Derik »
got new temp and hum sensor @ home...
PFFFF very nice stuff!!!
perhaps soemone can tell me how i can use the sounds from the gateway separate ..
Will use the horn and the air alarm with a dummy. Or something else
SwordFish
Domoticz version: V4.11375
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Post by SwordFish »
deennoo wrote:
SwordFish wrote:
deennoo wrote: Bedlight works on Bluetooth only.
There is a trick for it i made it works with a simple bt4le dongle and a script found on github.
This control :
Brightness
On/off
Color
White temp
I will provied a how to quickly on my blog
Sory for asking but is it on your blog already?
Cant find it.
deennoo
Post by deennoo »
SwordFish wrote:
deennoo wrote:
Cant find it.
I didn't write it already, i'm trying to made a python plugin for it...
http://domo-attitude.fr
quack3d
Post by quack3d »
Has anyone been able to write a script for extra long clicks? I'm assuming it's possible to trigger something if there are for instance 5 seconds between 'long click' and 'long click release'.
SwordFish
Post by SwordFish »
deennoo wrote:
SwordFish wrote:
Cant find it.
No wonder I didn't found it Image
theo69
Domoticz version: la. beta
Post by theo69 »
Does anybody using this together with homekit? And does it work reliable?
Love my Xiaomi Gateway in connection with homebridge and domoticz on my PI3
Xiaomi Gateway Domoticz Wiki
SwordFish
Post by SwordFish »
Yes, I have the gateway and door contacts. I can ask siri the status of the door contact and it report the status.
StefanoA
Post by StefanoA »
Swifty wrote: Not sure if it helps, as I don't seem to have this problem, but if you run 'raspiconfig' I think there is an option in there to 'Wait for network on boot' (or something along those lines).
Maybe try to turn that on so that the network stack is fully up and address allocated etc. before Domoticz starts?
Thanks Swifty,
that made the magic for me :mrgreen:
After enabling this option, both of my raspberry's systems now connect and work properly after reboot
I put some screenshot below and I recommend adding this information to Wiki's page of Aqara gateway in Domoticz
(1)
Open a shell
Type <sudo raspi-config>
(2)
Choose Boot Options
(3)
Select Wait for network at Boot option
(4)
Enable it!!
corbin
Post by corbin »
Thanks StefanoA, I just checked my Raspberry setup and had already had it set to wait for network on boot. Feel free to ad this fix to the Wiki
warmaniac
Post by warmaniac »
Hi there , i want to ask if somebody use the new temperature and humidity sensor link : http://m.gearbest.com/access-control/pp_626702.html
My other sensors works well, like human body , door, but this new not appearing in new devices , i can't see it at log file when added , already restarted xiaomi gateway try to compile new beta version of domoticz , nothing works , has anybody idea ? Thanks
StefanoA
Post by StefanoA »
corbin wrote:Feel free to ad this fix to the Wiki
Ok, done
( hopefully in the right way ;) )
