Dashticz - Feature Requests
Locked
robgeerts
Domoticz version: 3.7067
Re: Dashticz - Feature Requests
Post by robgeerts »
This function is working in latest beta!
Example config:
var _AUTO_SWIPEBACK_TO	= 1;
var _AUTO_SWIPEBACK_TIME	= 0; //seconds
var _SLIDE_PAGES			= 5;
Clemen
Post by Clemen »
Nice working great..! 8-)
Swifty
Post by Swifty »
@robgeerts - Any luck with adding iCal support for the garbage module?
I'm not hassling - just been away for a week or so, and trying to catch up on the board, so wondering if I missed it as i can't see it in the first post :)
niceandeasy
Domoticz version: 3.8153
Post by niceandeasy »
I have two windows with motorized blinds on them, not compatible with Domoticz. I control them via Domoticz, by using a KAKU remote switch. Switch type is set to 'Blinds'. LUA scripting takes care of sending the appropriate commands to a Mediola gateway which sends it to the motors.
In Domoticz, these blinds switches have an open and a close button. They can be stopped by pressing a button again.
In Dashticz, these blinds switches have an open, a close and a stop button. Off course, Stop is not working.
Can I make this Stop button disappear in the Dashticz switches? Preferably by adding something to the blocks{}section of config.js.
Thank you.
htilburgs
Post by htilburgs »
blocks[IDX]['hide_stop'] = true;
Hardware:
niceandeasy
htilburgs wrote:blocks[IDX]['hide_stop'] = true;
Thanks! Works perfectly.
robgeerts
Post by robgeerts »
Swifty wrote:@robgeerts - Any luck with adding iCal support for the garbage module?
No sorry... didnt have much time in the last couple of days... could you send me an example ical? (Or did you already?)
Swifty
Post by Swifty »
No problem, as I say - not hassling just wasn't sure if I'd missed it :)
I already sent a PM with ical link (sent 12th May) let me know if you need it again.
htilburgs
Post by htilburgs »
Feature requests:
1. Is it possible to choose between icon or image, so we can use our own image (like F1 in Formule1 Calendar) like in example??
calendars.f1 = { maxitems: 5, title: 'F1 Calendar', icon: 'fa-calendar ',icalurl: 'https://calendar.google.com/.../xx/basic.ics' }
OR
calendars.f1 = { maxitems: 5, title: 'F1 Calendar', image: 'img/calendar.png',icalurl: 'https://calendar.google.com/.../xx/basic.ics' }
2. Present the Domoticz Log in the 'Domoticz Layout' - With the current URL it's not easy to read
buttons.domoticz = {width:12, icon:'fa-microchip', title: 'Domoticz Log', url: 'http://192.168.0.100:8088/json.htm?type ... loglevel=2'}
Hardware:
Teunissm
Domoticz version: V3.5858
Post by Teunissm »
Just curious,
What is the state of an rgb switch posibility in Dashticz.
it is the only basic thing i am missing here.
Marcel
HansieNL
Post by HansieNL »
Teunissm wrote:Just curious,
Marcel
You can check here... https://github.com/robgeerts/dashticz_v2/issues/48
Blah blah blah
gielie
Domoticz version: latest β
Post by gielie »
Is it possible to create the air pressure from the weather tab, it is now a on/off and id like to display the pressure.
This is the output
"AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "Barometer" : 1015,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "19.0 C, 58 %, 1015 hPa",
         "Description" : "",
         "DewPoint" : "10.55",
         "Favorite" : 1,
         "Forecast" : 1,
         "ForecastStr" : "Sunny",
         "HardwareID" : 7,
         "HardwareName" : "Weer station",
         "HardwareType" : "Weather Underground",
         "HardwareTypeVal" : 14,
         "HaveTimeout" : false,
         "Humidity" : 58,
         "HumidityStatus" : "Comfortable",
         "ID" : "0001",
         "LastUpdate" : "2017-06-04 13:11:56",
         "Name" : "Barometer",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "THB1 - BTHR918, BTHGN129",
         "Temp" : 19.0,
         "Timers" : "false",
         "Type" : "Temp + Humidity + Baro",
         "TypeImg" : "temperature",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "forecast_url" : "aHR0cDovL3d3dy53dW5kZXJncm91bmQuY29tL2NnaS1iaW4vZmluZHdlYXRoZXIvZ2V0Rm9yZWNhc3Q/cXVlcnk9UFdTJTNBSU5PT1JESE8yNTM=",
         "idx" : "15"
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
gielie
Post by gielie »
Is it possible to create buttons instead a dropdown menu.
- FIBARO FGS223
- Toon
- Kodi Media Server
robgeerts
Post by robgeerts »
gielie wrote:Is it possible to create the air pressure from the weather tab, it is now a on/off and id like to display the pressure.
This is the output
"AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "Barometer" : 1015,
         "CustomImage" : 0,
         "Description" : "",
         "Favorite" : 1,
         "Forecast" : 1,
         "HardwareID" : 7,
         "Humidity" : 58,
         "ID" : "0001",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Temp" : 19.0,
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "15"
Check your config because, I just testen with your output and works as expected!
gielie
Post by gielie »
Yes, tanks, i used the wrong idx, i fixed it now, thanks.
- FIBARO FGS223
- Toon
- Kodi Media Server
EddyG
Post by EddyG »
I really love the work that has been done on this Dashboard.
I have some conflicts with Wunderground, they keep sending me emails and counting on raindrops(???)
I think that this is the part which could work with a var.
setTimeout(function(){
loadWeather(_WEATHER_CITY,_WEATHER_COUNTRY);
}, (60000*30));
Could the timeout on refresh be a var in CONFIG.js?
EdwinK
Post by EdwinK »
It looks you are running the script too often. Do you also use another script that uses this API?
Raindrops are some sort of credit. You start out with 29 of them, and everytime you go over the max allowed number of calls you lose one raindrop.
EddyG
Post by EddyG »
I know. I am in the process of retuning the layout of Dashticz.
So when ever I want to look at a change, I refresh the screen.
Temporary I disabled Weather Underground, but still it would be nice if the refresh of Weather Underground could be controlled by a parameter.
I have some other programs calling Weather Underground.
Hesmink
Post by Hesmink »
EddyG wrote:I know. I am in the process of retuning the layout of Dashticz.
I lost a few when trying to get my android tablet to work full screen. If I do that, dashtics keeps refreshing the screen, including the weather. Some sort of stop to WU refreshes would be welcome.
Derik
Post by Derik »
A webcam as background.
And background switching on month or day or season with pictures from from the web as extra...[ like andriod options ]
And if possible different to choose by screen
screen 1 webcam
screen 2 season
screen 3 static
etc
Think that should be great
Locked
