Fibaro Single switch FGS-213 problem
mazlbeer
Post by mazlbeer »
Hi there
i am just starting out with Domoticz and today i added my first Zwave switch.
Everything is connected as it should be as the manual stated.
The normal lightswitch can still operate the lights
I added the fibaro module to the Aeotec ZW090 Z-Stick Gen5 and then i plugged the Z-stick in my synology where domoticz runs.
Under devices i see new names coming up like: switch, powermeter etc.
When i use the lightswitch manually, domoticz changes its state after a while.
But when i want to use domoticz to turn the light on or off, domoticz changes state but the light doesnt turn on or off.
can you help me out here?
Masterblaster
Re: Fibaro Single switch FGS-213 problem
Post by Masterblaster »
Hi, i have the same problem. Did you solve it ?
Ernstl
Domoticz version: 2020.2 b
Post by Ernstl »
There are some problems after adding Fibaro FGS 213 or 223 switches. Just restart domoticz, that fixes it most of the time.
Habe a look here: http://www.domoticz.com/forum/viewtopic ... &start=160
or search the format your own.
Masterblaster
Yep restart did the trick
mazlbeer
Post by mazlbeer »
That did the trick indeed :thumbs
