Hi there
i am just starting out with Domoticz and today i added my first Zwave switch.
Everything is connected as it should be as the manual stated.
The normal lightswitch can still operate the lights
I added the fibaro module to the Aeotec ZW090 Z-Stick Gen5 and then i plugged the Z-stick in my synology where domoticz runs.
Under devices i see new names coming up like: switch, powermeter etc.
When i use the lightswitch manually, domoticz changes its state after a while.
But when i want to use domoticz to turn the light on or off, domoticz changes state but the light doesnt turn on or off.
can you help me out here?
Fibaro Single switch FGS-213 problem
Re: Fibaro Single switch FGS-213 problem
Hi, i have the same problem. Did you solve it ?
- Domoticz version: 2020.2 b
There are some problems after adding Fibaro FGS 213 or 223 switches. Just restart domoticz, that fixes it most of the time.
Habe a look here: http://www.domoticz.com/forum/viewtopic ... &start=160
or search the format your own.
Yep restart did the trick
That did the trick indeed :thumbs
