Thanks again for the quick responserobgeerts wrote:It's not the same for all devices.
You can search the output (http://DOMOTICZ_URL:8080/json.htm?type=devices&filter=all&used=true&order=Name) for attributes you could use.
For example, you could use for switch:
function getStatus_145(idx,value,device){ if(device['Data']=="On"){ $('div.block_145').addClass('warning'); } else { $('div.block_145').removeClass('warning'); } }
Dashticz - Function - Trigger action on specific value
mikeoo
Re: Dashticz - [BETA] - Function - Do something at a specific value
- mvveelen
I'm using:
for the size and rounded corners of the buttons. How can I use (for instance) the orange style code to get the same sized button? Tried a few things, but it still has another size. See attachment.
.transbg.col-xs-1, .transbg.col-xs-2, .transbg.col-xs-3, .transbg.col-xs-4, .transbg.col-xs-5, .transbg.col-xs-6, .transbg.col-xs-7, .transbg.col-xs-8, .transbg.col-xs-9, .transbg.col-xs-10, .transbg.col-xs-11, .transbg.col-xs-12 {
padding-top: 15px;
padding-bottom: 15px;
border: 2px solid rgba(255,255,255,0);
background: rgba(0,0,0,0.2);
background-clip: padding-box;
border-radius: 9px;
- Schermafbeelding 2017-05-23 om 19.18.20.png (266.8 KiB) Viewed 4577 times
- htilburgs
If you use this code, I think it should be the same....
.warning {
background: rgba(204,129,44,0.30) !important;
border: 7px solid rgba(255,255,255,0);
}Hardware:
- htilburgs
Is it also possible to get multiple devices / IDX in 1 function?
Now I've to add the same function 2, 3 or more times with a different IDX. Is it possible to create a kind of array?
Hardware:
robgeerts
- Domoticz version: 3.7067
Not yet but you can do this to by pass this:
if(parseFloat(device['Data'])>24){
else {
function getStatus_5(idx,value,device){
getStatus_145(idx,value,device);
repoman
Hi. I've tried adding the line "border: 7px solid rgba(255,255,255,0);" but nothing seems to change.htilburgs wrote:If you use this code, I think it should be the same....
.warning { background: rgba(204,129,44,0.30) !important; background-clip: padding-box; border: 7px solid rgba(255,255,255,0); }
The warning block is still bigger...
Is this by design? How can I make them the same size as the others?
Thanks,
Pascal
- mvveelen
Unfortunately it isn't:htilburgs wrote:If you use this code, I think it should be the same....
- Schermafbeelding 2017-05-25 om 12.07.02.png (290.53 KiB) Viewed 4509 times
- HansieNL
Don't know for sure, but what if removing the border code?mvveelen wrote:Unfortunately it isn't:htilburgs wrote:If you use this code, I think it should be the same....
Blah blah blah
- mvveelen
I get the same result when I delete that line.
- HansieNL
Does this work?mvveelen wrote:I get the same result when I delete that line.
.warning .transbg.col-xs-1,
.warning. transbg.col-xs-2,
.warning .transbg.col-xs-3,
.warning .transbg.col-xs-4,
.warning .transbg.col-xs-5,
.warning .transbg.col-xs-6,
.warning .transbg.col-xs-7,
.warning .transbg.col-xs-8,
.warning .transbg.col-xs-9,
.warning .transbg.col-xs-10,
.warning .transbg.col-xs-11,
.warning .transbg.col-xs-12 {
padding-top: 15px;
border-radius: 9px;
Blah blah blah
- htilburgs
Maybe you overrule the setting in your custom.css. Is it possible for you to post your custom.css
I've tested the css and for me it's working great.
Hardware:
- mvveelen
htilburgs wrote:Maybe you overrule the setting in your custom.css. Is it possible for you to post your custom.css
- Spoiler: show
- htilburgs
Ok, quite a puzzle (but a nice one...
Put this in your custom.css for the .warning part and it should work:
Let me know, if its OK now.
And I see one minor error in your custom.css.
In the #newsTicker li part the */ Set the maxim height of the news-ticker */ shoud be /* Set the maxim height of the news-ticker */
For now it's not causing an issue, but you never now what it causes in the future....
.warning {
padding-top: 15px !important;
padding-bottom: 15px !important;
border-radius: 9px !important;
background-color: rgba(199, 44, 43, 0.3) !important;
border: 2px solid rgba(255,255,255,0) !important;
background-image: initial !important;
background-position-x: initial !important;
background-position-y: initial !important;
background-size: initial !important;
background-repeat-x: initial !important;
background-repeat-y: initial !important;
background-attachment: initial !important;
background-origin: initial !important;
background-clip: padding-box !important;
}And I see one minor error in your custom.css.
Hardware:
repoman
Tried this code and I get the rounded corners but the warning blocks are still bigger...htilburgs wrote:Ok, quite a puzzle (but a nice one...).
Put this in your custom.css for the .warning part and it should work:Let me know, if its OK now.Code: Select all
.warning { padding-top: 15px !important; padding-bottom: 15px !important; border-radius: 9px !important; background-color: rgba(199, 44, 43, 0.3) !important; border: 2px solid rgba(255,255,255,0) !important; background-image: initial !important; background-position-x: initial !important; background-position-y: initial !important; background-size: initial !important; background-repeat-x: initial !important; background-repeat-y: initial !important; background-attachment: initial !important; background-origin: initial !important; background-clip: padding-box !important; }
(it's the only code in my custom.css)
- htilburgs
This was specific for @mveelen, based on his css.
I'll will look into it later on, now busy with my regular job....
Hardware:
- htilburgs
Try this one:repoman wrote: Tried this code and I get the rounded corners but the warning blocks are still bigger...
.warning {
background: rgba(199,44,44,0.7) !important;
}Hardware:
repoman
Yep, that did the trick!
freakshock
Hi Rob,robgeerts wrote:I did this to have different colors, depending on the temperature of my living room:
function getStatus_145(idx,value,device){ if(parseFloat(device['Data'])>23){ $('div.block_145').removeClass('warning').addClass('warningorange'); } else if(parseFloat(device['Data'])>25){ $('div.block_145').removeClass('warningorange').addClass('warning'); } else { $('div.block_145').removeClass('warning').removeClass('warningorange'); } }
I think you need to switch the higher value with the lower value.
Your code did not work for me, the blocks remained orange even though the value exceeded 25.
My code:
//kleurtje op knop temp huiskamer wanneer het warmer is dan bepaalde temperatuur (oranje of rood)
function getStatus_90(idx,value,device){
if(parseFloat(device['Temp'])>25){
$('div.block_90').removeClass('warningoranje').addClass('warning');
else if(parseFloat(device['Temp'])>23){
$('div.block_90').removeClass('warning').addClass('warningoranje');
else {
$('div.block_90').removeClass('warning').removeClass('warningoranje');
}- mvveelen
Yesssss, that's it !! Thanks !htilburgs wrote:Ok, quite a puzzle (but a nice one...).
- Spoiler: show
Also changed the newsTicker-part
- htilburgs
I also noticed a minor in .trashcan. After height the : is missing. (I know, I'm a nitpickermvveelen wrote:Yesssss, that's it !! Thanks !htilburgs wrote:Ok, quite a puzzle (but a nice one...).
- Spoiler: show
Hardware:
