- corbin
Please check your IP and password settings if you haven't already. The other sensors will still work as they use a different communication method.
Correct, I had until 10 minutes ago the same issue. So I opened the Mi Home again and I had to re-login again. (Most likely because my phone was recently updated with a new android version)corbin wrote:Please check your IP and password settings if you haven't already. The other sensors will still work as they use a different communication method.
After logging in I also saw that I could update the gateway and the Mi Home app.
Then I refreshed the Xiaomi gateway in Domoticz and all worked....
Only I still don't see the lux sensor, but as I read some pages earlier it could be that the needed code is not merged yet in the main (beta) code.
I'm using the latest main beta and I can see the lux sensor
Thanks,xxLeoxx93 wrote:I'm using the latest main beta and I can see the lux sensor
on your remark I enabled new hardware devices and I made sure the light environment changed around the gateway. The lux sensor popped up in my devices now.
- Domoticz version: v4.11307
Compilation was successful, just waiting to smoke alarm to appear in Domoticz.corbin wrote:Sorry, forgot to sync. It is updated now - https://github.com/corbinmunce/domoticzchatainsim wrote: I will try as soon as possible.
Which branche ? Because master was updated 13 days ago.
I can add the Smoke detector.
But I have an error in logs :
2017-05-20 12:20:15.026 Error: XiaomiGateway: invalid data received!
How can I check what is it ? Get more debug log ?
If I click to turn on smoke detector, I cannot turn it off back. It always turn on.
Yes I know it shouldn't be turn on from Domoticz it doesn't make sense but I tried
Nothing change except the status in Domoticz.
Edit: Ok nevermind I found the reset button...
- corbin
Was the error when smoke was detected?
You can enable the raw gateway messages to appear in the Domoticz log by creating a user variable 'XiaomiMessage' of type Integer and value 1. (Setup -> More Options -> User Variables). Then restart the Gateway hardware in Domoticz. from http://www.domoticz.com/wiki/Xiaomi_Gat ... leshooting
Ahh awesome! Someone adding the Smoke Detector, mine should be arriving any day now.
Ok, I've deleted everything than add Gateway back.corbin wrote:Was the error when smoke was detected?
I can't get the error message again.
So for me it's working.
If you want me to test the activation of the smoke alarm, I have to wait until monday when I'll be alone at home
I have a question regarding battery information.
For a temp sensor, I have this information :
Which one should I trust ?
The Low for Temp only, or the 80 ?
I might be wrong about this but what is your battery low threshold set to?chatainsim wrote:I have a question regarding battery information.
http://domoticzip/#/Setup Go to the "Other" tab.
Maybe it set the "Low" label because the level is under the threshold on that tab?
It's set to 5(%)ben53252642 wrote: ...
Guys, what about xiaomi powerstrips? It is somehow compatible?
- corbin
Not compatible with the Gateway, but -> http://www.domoticz.com/forum/search.php?keywords=miio
- corbin
Yes please test (but don't burn your house down! ), as I've only tested here with your previously posted message. Need to see what actual value is reported when smoke/fire is detected - so enable the messages with the XiaomiMessage user variable.chatainsim wrote: Ok, I've deleted everything than add Gateway back.
Ok, so I haven't burn my house down but thanks to ecig I was able to test the smoke alarm easilycorbin wrote: Yes please test (but don't burn your house down! ), as I've only tested here with your previously posted message. Need to see what actual value is reported when smoke/fire is detected - so enable the messages with the XiaomiMessage user variable.
Just press the button to test :
2017-05-22 10:23:21.750 {"cmd":"report","model":"smoke","sid":"158d0001538a9e","short_id":31763,"data":"{\"density\":\"0\"}"}
2017-05-22 10:23:21.752 {"cmd":"heartbeat","model":"smoke","sid":"158d0001538a9e","short_id":31763,"data":"{\"voltage\":3215}"}
2017-05-22 10:23:21.752 (Gateway) General/Voltage (Xiaomi Voltage)
2017-05-22 10:23:21.952 {"cmd":"report","model":"smoke","sid":"158d0001538a9e","short_id":31763,"data":"{\"alarm\":\"0\"}"}
When smoke is detected :
2017-05-22 10:24:36.842 {"cmd":"report","model":"smoke","sid":"158d0001538a9e","short_id":31763,"data":"{\"alarm\":\"1\"}"}
2017-05-22 10:24:39.039 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:24:39.041 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":305}"}
2017-05-22 10:24:39.041 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:24:41.038 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:24:41.039 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":312}"}
2017-05-22 10:24:41.039 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:24:42.033 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:24:42.034 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":313}"}
2017-05-22 10:24:42.034 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:24:42.649 {"cmd":"report","model":"smoke","sid":"158d0001538a9e","short_id":31763,"data":"{\"density\":\"255\"}"}
2017-05-22 10:24:42.649 (Gateway) Light/Switch (Xiaomi Smoke Detector)
2017-05-22 10:24:42.654 {"cmd":"heartbeat","model":"smoke","sid":"158d0001538a9e","short_id":31763,"data":"{\"voltage\":3215}"}
2017-05-22 10:24:42.654 (Gateway) General/Voltage (Xiaomi Voltage)
2017-05-22 10:24:42.847 {"cmd":"report","model":"smoke","sid":"158d0001538a9e","short_id":31763,"data":"{\"alarm\":\"1\"}"}
2017-05-22 10:24:44.037 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:24:44.038 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":318}"}
2017-05-22 10:24:44.038 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:24:45.034 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:24:45.045 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":319}"}
2017-05-22 10:24:45.045 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:24:47.025 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:24:47.026 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":323}"}
2017-05-22 10:24:47.026 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:24:48.020 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:24:48.021 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":323}"}
2017-05-22 10:24:48.021 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:24:50.016 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:24:50.017 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":327}"}
2017-05-22 10:24:50.017 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:24:51.013 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:24:51.014 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":326}"}
2017-05-22 10:24:51.014 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:24:53.012 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:24:53.013 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":329}"}
2017-05-22 10:24:53.013 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:24:54.008 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:24:54.009 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":328}"}
2017-05-22 10:24:54.009 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:24:56.002 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:24:56.003 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":330}"}
2017-05-22 10:24:56.003 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:24:59.002 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:24:59.003 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":331}"}
2017-05-22 10:24:59.003 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:24:59.993 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:24:59.995 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":331}"}
2017-05-22 10:24:59.995 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:01.996 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:01.997 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":332}"}
2017-05-22 10:25:01.997 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:02.988 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:02.989 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":332}"}
2017-05-22 10:25:02.989 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:05.003 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:05.004 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":333}"}
2017-05-22 10:25:05.004 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:05.985 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:05.986 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":332}"}
2017-05-22 10:25:05.986 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:07.979 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:07.980 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":333}"}
2017-05-22 10:25:07.980 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:08.975 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:08.976 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":333}"}
2017-05-22 10:25:08.976 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:10.975 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:10.977 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":333}"}
2017-05-22 10:25:10.976 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:11.970 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:11.971 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":333}"}
2017-05-22 10:25:11.973 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:13.965 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:13.966 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:13.967 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":334}"}
2017-05-22 10:25:14.963 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:14.964 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":334}"}
2017-05-22 10:25:14.964 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:16.449 (Gateway) Light/Switch (Xiaomi Motion Sensor)
2017-05-22 10:25:16.450 {"cmd":"report","model":"motion","sid":"158d00014d2d72","short_id":28678,"data":"{\"status\":\"motion\"}"}
2017-05-22 10:25:16.959 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:16.960 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":334}"}
2017-05-22 10:25:16.960 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:17.958 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:17.959 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":334}"}
2017-05-22 10:25:17.959 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:19.710 {"cmd":"report","model":"smoke","sid":"158d0001538a9e","short_id":31763,"data":"{\"alarm\":\"0\"}"}
2017-05-22 10:25:19.955 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:19.956 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":334}"}
2017-05-22 10:25:19.956 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:20.952 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:20.953 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":334}"}
2017-05-22 10:25:20.953 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:22.916 (Gateway) Light/Switch (Xiaomi Motion Sensor)
2017-05-22 10:25:22.917 {"cmd":"report","model":"motion","sid":"158d00013f7278","short_id":32884,"data":"{\"status\":\"motion\"}"}
2017-05-22 10:25:22.951 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:22.952 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":50331435,\"illumination\":334}"}
2017-05-22 10:25:22.952 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:23.944 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:23.945 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":334}"}
2017-05-22 10:25:23.945 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:25.939 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:25.940 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":334}"}
2017-05-22 10:25:25.940 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:26.720 {"cmd":"heartbeat","model":"plug","sid":"158d00012f4f30","short_id":49264,"data":"{\"voltage\":3600,\"status\":\"off\",\"inuse\":\"0\",\"power_consumed\":\"2045\",\"load_power\":\"0\"}"}
2017-05-22 10:25:26.720 (Gateway) General/kWh (Xiaomi Smart Plug Usage)
2017-05-22 10:25:27.705 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:27.706 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":331}"}
2017-05-22 10:25:27.706 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:29.705 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:29.706 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":334}"}
2017-05-22 10:25:29.706 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:30.703 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:30.704 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":1694433280,\"illumination\":331}"}
2017-05-22 10:25:30.704 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:32.663 (Gateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-05-22 10:25:32.664 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":345}"}
2017-05-22 10:25:32.664 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:32.693 {"cmd":"report","model":"gateway","sid":"286c078891f8","short_id":0,"data":"{\"rgb\":0,\"illumination\":345}"}
2017-05-22 10:25:32.693 (Gateway) Lux (Xiaomi Gateway Lux)
2017-05-22 10:25:53.379 {"cmd":"report","model":"smoke","sid":"158d0001538a9e","short_id":31763,"data":"{\"alarm\":\"0\"}"}
I'm new in your world
All work fine here. Domoticz + xiaomi smart home + 3 doors sensors + switch.
The switch have 4 states :
CLICK
LONG CLICK
LONG CLICK RELEASE
DOUBLE CLICK
Are there a way to use this switch for ARM AWAY /ARM HOME /DISARM ?
Solved my first one
just one question in my Domoticz french language in curent state I have 'Normal' and not 'DIsarm' but the lua script work with Disarm. IS it a bug ?
CLICK
LONG CLICK
LONG CLICK RELEASE
DOUBLE CLICK
Solved my first one
if (devicechanged['Xiaomi Wireless Switch'] == 'Click') then
commandArray['Domoticz Security Panel'] = 'Disarm'
elseif (devicechanged['Xiaomi Wireless Switch'] == 'Double Click') then
commandArray['Domoticz Security Panel'] = 'Arm Home'
elseif (devicechanged['Xiaomi Wireless Switch'] == 'Long Click') then
commandArray['Domoticz Security Panel'] = 'Arm Away'
About smoke sensor easu to see alarm goes 0 when all is ok and alarm goes 1 when smoke is detected.
About alarme just a french translation...all is ok aucun probleme c'est ainsi
http://domo-attitude.fr
Hi Deennoo thanks for your answer. What is the best way for find real 'Current state' for use in lua script ? put Domoticz in english ?deennoo wrote: About alarme just a french translation...all is ok aucun probleme c'est ainsi
