Python plugin: Battery Level for Z-Wave Devices
- Egregius
- Domoticz version: v2024.7
Re: Python plugin: Battery Level for Z-Wave Devices
In my case the XML isn't good either.
I replaced all batteries of my smoke sensors yesterday. All battery levels went to 100%.
Today, one reports as 0%. So I looked at the devices table, all devices from that node just have a - as battery level...
Logread
Not clear to me if you are saying the domoticz/Config/zwcfg_0x????????.xml file on your system does not hold an accurate COMMAND_CLASS_BATTERY data for that node, or if my plugin has a bug ?Egregius wrote:In my case the XML isn't good either.
That being said, you may want to try to manually wake up the culprit smoke sensor and see what happens (may have to wait for one hour to see any change though) ?
- Egregius
Yes, the /Config/zwcfg_0x????????.xml contains value="0" for that node.
Or maybe it's a faulty battery, haven't received temps in the last 6 hours... Damn, up to the attic that is.
- capman
A tryded the script , but got a error in my log.
2017-05-27 09:38:25.534 (Baterijen Z-Wave) Initialized version 0.4.0, author 'logread'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) Debug log level set to: 'true'.
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'Key':'BatteryLevel'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'Mode6':'Debug'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'Port':'0'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'HardwareID':'55'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'Version':'0.4.0'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'Author':'logread'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'Name':'Baterijen Z-Wave'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'HomeFolder':'/usr/local/domoticz/var/plugins/BatteryLevel/'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'Mode1':'60'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) Device count: 0
2017-05-27 09:38:25.591 (Baterijen Z-Wave) Number of icons loaded = 4
2017-05-27 09:38:25.591 (Baterijen Z-Wave) Icon 120 batterylevelok
2017-05-27 09:38:25.591 (Baterijen Z-Wave) Icon 118 batterylevelfull
2017-05-27 09:38:25.591 (Baterijen Z-Wave) Icon 119 batterylevellow
2017-05-27 09:38:25.591 (Baterijen Z-Wave) Icon 117 batterylevelempty
2017-05-27 09:38:25.591 (Baterijen Z-Wave) Using polling interval of 60 minutes
Error: (Baterijen Z-Wave) Enable to find a zwave controller configuration file !
And all 10 seconds get this message
2017-05-27 09:38:45.459 (Baterijen Z-Wave) Calling message handler 'onHeartbeat'.
Logread
@capman,
I assume that indeed you have a zwave stick connected and functional ? If so, what is the platform you are running Domoticz on (Linux, Windows, ...) ? Can you locate the zwcfg_0x????????.xml file on your system (where ???????? is the unique homeid of your zwave controller)... it should be in the Config subfolder of the Domoticz install folder. If it is not there, then please report on where that file is on your system (you might have a non standard directory setup ?)
- capman
I have it installed on synology beta 3.7468Logread wrote:@capman,
On my config folder a have a file called 'zwcfg.xsd'. It's located in /volume1/@appstore/domoticz/Config/zwcfg.xsd
Code showing under.
- Spoiler: show
- zwave.JPG (97.8 KiB) Viewed 5162 times
Logread
@capman,
The .xsd file is of no use for the plugin... only the zwcfg_0x????????.xml file (where ???????? is the unique homeid of your zwave controller) is required for the plugin to work... I note your zwave stick is a Vision one, while I tested on a Aeotec, so may be openzwave works differently with that controller ? Not sure. Can you send me by pm a directory listing of your domoticz/Config folder ?
- capman
I search in my domoticz structure folders to 'zwcfg' , but nothing found. I send you a pm. Thanks 4 lookingLogread wrote:@capman,
Derik
- Domoticz version: BETA
m,mmm
Did have this plugin working.
Only need to upgrade my cb to a Xu4...[ more power needed..
Now i do the [ same ] trick..
Only no plugin in domoticz hardware section......
And in the ftp area is see everything i need...
Do i need to start the script or??
Where do i go wrong..
linaro@odroidxu4:~/domoticz/plugins/BatteryLevel$ sudo chmod +x plugin.py
linaro@odroidxu4:~/domoticz/plugins/BatteryLevel$ sudo apt-get install git
Reading package lists... Done
Building dependency tree
Reading state information... Done
git is already the newest version (1:2.7.4-0ubuntu1.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
linaro@odroidxu4:~/domoticz/plugins/BatteryLevel$ sudo /etc/init.d/domoticz.sh restart
[ ok ] Restarting domoticz.sh (via systemctl): domoticz.service.
linaro@odroidxu4:~/domoticz/plugins/BatteryLevel$ cd
linaro@odroidxu4:~$ cd ~/domoticz/plugins/BatteryLevel
linaro@odroidxu4:~/domoticz/plugins/BatteryLevel$ git reset --hard
HEAD is now at dd0d29b Version 0.4.2
linaro@odroidxu4:~/domoticz/plugins/BatteryLevel$ git pull --force
Already up-to-date.
Logread
I think the sequence of shell commands you send is not finished... you need to restart domoticz AFTER you update the plugin and make the script executable...Derik wrote:m,mmm
Only need to upgrade my cb to a Xu4...[ more power needed..]
This should do it
Derik
strange,
Do everything i need to do for the 3 time.
No plugin
ast beta..
Do the thing as subscribe here in the topic...
see the map an all the stuff.
Reboot
Refresh hardware list
no plugin
No plugin
ast beta..
Reboot
no plugin
Logread
Which version of Domoticz are you running ? I saw on the forum that some of the recent beta builds had python disabled... do you have other python plugins installed and working (or not)... If no plugin works, then definitely a domoticz issueDerik wrote:strange,
No plugin
ast beta..
Reboot
no plugin
Derik
Last beta..
New hardware xu4 ..
With other kernell perhaps that??
Or can i mananual install python
Or check the versions
New hardware xu4 ..
Logread
A new version (0.4.3) is available from the GitHub repository. The plugin should now work on Synology platforms (different location of the openzwave files compared to "standard" Linux or Windows installs). Thanks to @capman for raising the issue and testing the new version
TakeAway
- Domoticz version: 3.7722
I have the same problem as derik, also latest beta. Can't see the plugin in the hardware list.
Raspberry Pi 3 - Domoticz 3.7722 - Aeon Labs Z-Stick GEN5 - RFXcom version: Ext/1012- Logitech Harmony Elite - Homebridge - Fibaro FGMS-001-ZW5 - Fibaro FGDW-002-01 - KAKU stuff.
TakeAway
Problem solved by installing python from the wiki:https://www.domoticz.com/wiki/Using_Python_plugins
Derik
Not by me:
And instal the plugin
reboot
check and double ..
No hardware in my list for the battery
linaro@odroidxu4:~/domoticz$ dpkg -l | grep libpython3
ii libpython3-dev:armhf 3.5.1-3 armhf header files and a static library for Python (default)
ii libpython3-stdlib:armhf 3.5.1-3 armhf interactive high-level object-oriented language (default python 3 version)
ii libpython3.5:armhf 3.5.2-2ubuntu0~16.04.1 armhf Shared Python runtime library (version 3.5)
ii libpython3.5-dev:armhf 3.5.2-2ubuntu0~16.04.1 armhf Header files and a static library for Python (v3.5)
ii libpython3.5-minimal:armhf 3.5.2-2ubuntu0~16.04.1 armhf Minimal subset of the Python language (version 3.5)
ii libpython3.5-stdlib:armhf 3.5.2-2ubuntu0~16.04.1 armhf Interactive high-level object-oriented language (standard libra ry, version 3.5)
linaro@odroidxu4:~/domoticz$ cd
linaro@odroidxu4:~$ sudo apt-get install python3-dev
python3-dev is already the newest version (3.5.1-3).
The following packages were automatically installed and are no longer required:
gir1.2-javascriptcoregtk-3.0 gir1.2-soup-2.4 gir1.2-webkit-3.0 inxi
libarchive13 libboost-python1.58.0 libexiv2-14 libgd3 libgdata-common
libgdata22 libglib2.0-bin libgoa-1.0-0b libgoa-1.0-common libgphoto2-6
libgphoto2-port12 libimobiledevice6 libjavascriptcoregtk-3.0-0 libmate-menu2
libmtp-common libmtp9 liboauth0 libpcre16-3 libpcre3-dev libpcre32-3
libpcrecpp0v5 libplist3 libusbmuxd4 libwebkitgtk-3.0-0
libwebkitgtk-3.0-common python3-polib
Use 'sudo apt autoremove' to remove them.
linaro@odroidxu4:~$
reboot
check and double ..
- Phantom
- Domoticz version: 4.11652
Thanks for the plugin.
I have installed it today and works great.
TakeAway
Works for some time, but domoticz crashes. Is there a solution for this?
bdormael
Same issue here, 2 times a day Domoticz crashes now, when disabling the plugin, no crashes anymoreTakeAway wrote:Works for some time, but domoticz crashes. Is there a solution for this?
Verzonden vanaf mijn iPad met Tapatalk
