How do I know which voltage reading is for which temperature sensor? I have 5 of them now.
bing69
Look to the hex code by id in the device listquack3d wrote:How do I know which voltage reading is for which temperature sensor? I have 5 of them now.
But the code doesn't match any of the other devices. Example: 3FBBDA6D on voltage and DF25 on humidity, temp, humidity/temp.bing69 wrote:Look to the hex code by id in the device listquack3d wrote:How do I know which voltage reading is for which temperature sensor? I have 5 of them now.
EDIT: Ahh... now I get it. The new voltages showing up was for my 4 switches and 1 motion sensor, not the 5 temperature sensors. Now I could identify the hex codes.
elgiampo
Hello to everyone!
in my dreams
I would like to use my Xiaomi Smart Wireless Switch to turn on my hue light.. what's the best way to do this?
in my dreams
Perhaps a bit OT, but what's the deal with the tape that comes with the buttons, temp and motion sensors? Are they just extras if original wears out? If so, shouldnt the tape be double sided? Or are you supposed to use the sticker in the package together with the sticker attached to the device?
Also, my motion sensor has no preattached double sided tape but a small circular patch comes with in the package. But this one is not double sided, so what's the intention here? :S
deennoo
They are all double side tape, they come as a second part if you need to change them.quack3d wrote:Perhaps a bit OT, but what's the deal with the tape that comes with the buttons, temp and motion sensors? Are they just extras if original wears out? If so, shouldnt the tape be double sided? Or are you supposed to use the sticker in the package together with the sticker attached to the device?
http://domo-attitude.fr
StefanoA
I'm having a problem on Domoticz Beta (latest version V3.7450 but also previous last was the same)
Until yesterday everything was ok, but today after restarting the raspberry3 on which domoticz is running, I cannot connect anymore to xiaomy gateway
and if I go to hardware page, I can't see all parameters of gateway,
IP address, port and password fields aren't visible anymore !
In another instance I'm running, again on a rasp3, I don't have same problem
connection is fine and I can see all parameters under hardware page !!
what's the matter ? the two systems are almost identical
pls help
pls help
No, there's only adhesive on one side. Have you checked?deennoo wrote:They are all double side tape, they come as a second part if you need to change them.quack3d wrote:Perhaps a bit OT, but what's the deal with the tape that comes with the buttons, temp and motion sensors? Are they just extras if original wears out? If so, shouldnt the tape be double sided? Or are you supposed to use the sticker in the package together with the sticker attached to the device?
And did your motion sensor come with double sided tape? This is how mine looks:
- superelch
the door sensor works with magnetism.farhanito wrote:sorry for my ignorance, but what does this hack do?superelch wrote:simple hack:
put the door sensor very close to the Electromagnetic coil of your doorbell. works for me. easy hack without any soldering.
you get an alarm/massage when someone ring your doorbell.....
Raspberry / Domoticz (beta) / z-wave & xiaomi & habridge & 5x Alexa & google dots & milight & yeelight & harmony hub & Netatmo & ITTT & sonoff & Conbee II .... & a girlfriend who hates that stuff ...
chatainsim
- Domoticz version: v4.11307
Regarding smoke sensor here what I got in Domoticz logs:
If it can help to integrate into Domoticz.
2017-05-16 20:51:43.558 XiaomiGateway: unhandled model: smoke
2017-05-16 20:51:43.559 {"cmd":"report","model":"smoke","sid":"158d0001538a9e","short_id":31763,"data":"{\"density\":\"0\"}"}
2017-05-16 20:51:43.583 XiaomiGateway: unhandled model: smoke
2017-05-16 20:51:43.583 {"cmd":"heartbeat","model":"smoke","sid":"158d0001538a9e","short_id":31763,"data":"{\"voltage\":3265}"}
- corbin
I've added the smoke detector to https://github.com/corbinmunce/domoticz, are you able to compile and test?
Mat2Vence
- Domoticz version: 3.7449
Just to know.. Are the sound elements supposed to work back with the actual beta version? Thanks for your helpcorbin wrote:I've added the smoke detector to https://github.com/corbinmunce/domoticz, are you able to compile and test?
farhanito
noticed a new firmware update for the gateway, anybody knows what's changed?
blacksn0w
Here too, 1.4.1_146.0141
Hope they've fixed the false positives in the APIl
chatainsim
I will try as soon as possible.corbin wrote:I've added the smoke detector to https://github.com/corbinmunce/domoticz, are you able to compile and test?
Which branche ? Because master was updated 13 days ago.
Mat2Vence
Sorry for annoying you again on that point, but could anyone let me know whether the MP3, Alarm Clock, Alarm Ringtone, Door ringtone, RGB and gateway volume are wrking with beta 3.7450?
I have try to remove them and set them back, but there is still no communication from Domoticz to these fonctions on the gateway. But, in another hand, if I am setting the RGB with the Xiaomi apps, I have the status back on Domoticz (only the case with RGB).
Any idea where it can come from in case it is supposed to work?
- corbin
All gateway sounds are working through Domoticz on my setup.
Check that your gateway IP has not changed, and also double check the password - I think it did once reset on me accidentally.
- corbin
Sorry, forgot to sync. It is updated now - https://github.com/corbinmunce/domoticzchatainsim wrote: I will try as soon as possible.
Caribou
Sorry I don't know if it's Xiaomi related or a more general question about domoticz:
why do I get that message "no temperature sensors founded or added in the system…" quickly displayed in the footer of this webpage: https://i.imgur.com/nebpvLz.png ?
Mat2Vence
I have other sensor (door sensor and PIR) that are working perfectly. So I guess the communication is correct... I am gonna make some other checks.corbin wrote:All gateway sounds are working through Domoticz on my setup.
