Dashticz - Module - Calendar
robgeerts
Domoticz version: 3.7067
Re: Dashticz - Module - Calendar
Post by robgeerts »
It should work with latest beta found here: https://github.com/robgeerts/dashticz_v2/tree/beta
If not, send me your config with the code you've tried.
EdwinK
Post by EdwinK »
Still having problems with the combined and private calendar. Business is working.
Something I just thought of, In Textwrangler (some sort of programm to write code in), the 'private' part is in blue-ish colour, while .combined isn't.
columns[1] = {}
columns[1]['blocks'] =
['blocktitle_1','s1',91,51,99,125,52,53,54,55,56,'blocktitle_11',calendars.private]//idx 57 - 62 reserve KaKU
columns[1]['width'] = 5;
Error messagee
Error messagee
Screen Shot 2017-05-16 at 20.58.23.png (32.56 KiB) Viewed 2821 times
Trigun
Domoticz version: 4.10717
Post by Trigun »
htilburgs wrote:
Trigun wrote:Hi Guys, trying to setup the calender but am quite lost with all the info within this topic.
I am trying to setup a google calendar but don't know which info is right and which is not.
I assume I need 2 things:
1: the Icalender URL = which is ?
2: the ical url = which I have.
but whats next.
Thnx in advance guys!
Have you already take a look at the wiki?
http://www.domoticz.com/wiki/Dashticz_V ... a_calendar
to be honest, I didn't know it was written in the Wiki but i read it :)
as for now I get a nice calendar whenever I click on the block.
but so far I am not seeiing all the event is on block.
this is my code(where the private info is "x"
// iCalendar Plugin, supports all .ics calendar types like Google Calendar, Apple Calendar
var _ICALENDAR_URL		= 'https://calendar.google.com/calendar/ical/x/public/basic.ics'; //supports .ics type calendars (Google Calendar, Apple Calendar etc.)
var _ICALENDAR_DATEFORMAT	= 'friendly'; //'friendly', 'MM.DD.YYYY HH:mm', 'DD.MM.YYYY HH:mm', 'YYYY.MM.DD HH:mm'
var _ICALENDAR_LOCALE		= 'en'; //en,hu, etc.
var calendars = {}
calendars.business = { maxitems: 5, url: 'https://calendar.google.com/calendar/embed?src=x&ctz=Europe/Amsterdam', icalurl: 'https://calendar.google.com/calendar/ical/x/public/basic.ics' }
calendars.private = { maxitems: 5, icalurl: 'https://calendar.google.com/calendar/ical/x/private-x/basic.ics' }
can anyone tell me where I'm going wrong?
mvveelen
Post by mvveelen »
My combined calendar is working. However, I see several appointments from 2018 scattered through the list. At least I know what to do in about 12 months :) I hope this will be fixed in a new update.
This is what I'm using in CONFIG.js:
var calendars = {}
calendars.samen = { icalurl: 'https://p49-calendars.icloud.com/published/2/bla' }
calendars.shayna = { icalurl: 'https://p49-calendars.icloud.com/published/2/ookbla' }
calendars.combined = {}
calendars.combined.calendars = [
   { color:'white',calendar:calendars.samen },
   { color:'pink',calendar:calendars.shayna }
and
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['s1',508,778,'s2',509,779,3453,3454,3455,3452,3533,3534,calendars.combined]
@Trigun:
you use:
var calendars = {}
But your URL's don't match, Is there a reason for that? One is: "url" and the other is "icalurl".....
EdwinK
Post by EdwinK »
This is why.
Where 'url' is the webaddress of the page to be shown when clicking the block.
'icalurl' is the webaddress to the ical-version of your calendar.
Wasn't this part obsolute now?
robgeerts
Post by robgeerts »
I use 'private' too so that shouldnt be a problem.
Did private work when you use only that calendar (and not combined?)
If not, are the settings in google correct (share settings) ?
EdwinK
Post by EdwinK »
I think all my settings are okay, but never could use the private calendar.
Deze agenda openbaar maken Meer informatie
Deze agenda wordt weergegeven in de openbare zoekresultaten van Google
poudenes
Domoticz version: 3.8993
Post by poudenes »
robgeerts wrote:It should work with latest beta found here: https://github.com/robgeerts/dashticz_v2/tree/beta
I see with last update (did update today) that there is a improvement of the calendar.
Still see also itms from 2018 already. If you want i can send you a link to do some tests on it?
EdwinK
Post by EdwinK »
When I now look with the Inspector, I see this.
Request URL:https://cors-anywhere.herokuapp.com/http://ical-to-json.herokuapp.com/convert.json?url=https://calendar.google.com/calendar/ical/PRIVATE KEY/basic.ics/
Request Method:GET
Status Code:400 Bad Request
Remote Address:23.23.100.24:443
Referrer Policy:no-referrer-when-downgrade
Fixed the typo.
EdwinK
Post by EdwinK »
Business is still working
Private keeps loading but doesn't seem to finish.
combined gives an error
robgeerts
Post by robgeerts »
Maybe its because of the [[ in the url of the calendar... wich i have to escape..
EdwinK
Post by EdwinK »
No, that was a copy/paste error for the posting here. Forgot to adjust it. Changed it in my previous post.
mvveelen
Post by mvveelen »
Any progress EdKo66 ? Your private calendar IS shared, right?
EdwinK
Post by EdwinK »
Yeah, it is. Didn't had any time to test it more this week though.
Screen Shot 2017-05-18 at 19.15.08.png (29.42 KiB) Viewed 2629 times
Calendar is :
Screen Shot 2017-05-18 at 19.16.42.png (79.87 KiB) Viewed 2629 times
mvveelen
Post by mvveelen »
What exact code do you use (without the private URL)?
EdwinK
Post by EdwinK »
calendars.private = { maxitems: 5, icalurl: 'https://calendar.google.com/calendar/ical/PRIVATE PART/basic.ics/' }
mvveelen
Post by mvveelen »
Can you try it without the 'maxitems: 5,' ?
On my dashboard it doesn't matter what amount I use: it doesn't work.
EdwinK
Post by EdwinK »
Still give '400 - bad request' -error
Request URL:https://cors-anywhere.herokuapp.com/http://ical-to-json.herokuapp.com/convert.json?url=https://calendar.google.com/calendar/ical/PRIVATE/basic.ics/
Request Method:GET
Remote Address:54.225.216.119:443
Response Headers
view source
EdwinK
Post by EdwinK »
I suspect it is the cors-anywhere part that is doing this. At least I didn't put it in.
Grove
Post by Grove »
Can you download the ICS file is you put the google link directly in a browsers address bar?
