Amazon Echo to Domoticz Bridge: switches, sensors & more
Madgeni
Re: Amazon Echo to Domoticz Bridge: switches, sensors & more
working on light colour control - one issue is controlling multiple lights. As you control one device at a time, i'm not sure of the user experience you'll get if you have to do this one light at a time!
any thoughts anyone?
borcon
- Domoticz version: BETA
@swifty: sorry for late reply.
My nginx reverse proxy has a self-signed webserver certificate.
Amazon AWS is talking to my proxy and forwards the packages to domoticz. Thats all.
In aws i have no own (client) certificates. AWS accepts in dev mode self signed certs.
@Madgeni, i will send you a new version of the manual
Madgeni
Thanks Borcon - it's been uploaded.
Also, i've added the ability to set colours (i've only tested it at the lambda, not via Alexa). I had to create the ability in the node module for Domoticz, I convert it to hex, so took a little while.
Still not convinced that turning each Hue on (or any RGBW) one by one is a great experience!
Madgeni
so - just heard that Alexa Notifications are coming soon. As my Product Owners
- can you provide me with some user stories for notifications, and i'll get thinking
- heggink
- Domoticz version: 12451
Wow, interesting. How would that work?
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
qwerk
@madgeni is that like push messages?
and you need use cases specific for alexa-domo?
Lokonli
My use case for Alexa push notifications: when someone enters the garage this is detected by a PIR sensor. This triggers Alexa to say 'We have a guest' (or whatever you want)
I have this working. I have modified the Alexa AVS sample app to send a pre-recorded MP3 file to the Alexa server. This triggers a custom skill which gets the text that needs to be speech synthesized from Domoticz.
The delay between PIR detection and the moment Alexa starts talking is a few seconds. Acceptable.
Verstuurd vanaf mijn SM-G800F met Tapatalk
qwerk
@lokonli that's the kind off things I had in mind.
I had a homey, and let domoticz speak through it.
Doorbell actions, specific confirmations, and PIR's but only after time checking etc.
So a way to let Domoticz to tell Alexa what to say, would be perfect for me.
The nicest way is to let it happen without "man in the middle" so domoticz >> the skill by madgeni >> alexa.
How did you make this function, is there a manual ???
Lokonli
Re: RE: Re: Amazon Echo to Domoticz Bridge: switches, sensors & more
I've derived it from:qwerk wrote:@lokonli that's the kind off things I had in mind.
https://github.com/jbreed/AlexaDomoticz
See:
http://www.domoticz.com/forum/viewtopic.php?t=8755
Madgeni
I'd considered another skill just for push notifications - using mqtt to the AWS iot - but the ideal is for it to be built into the Smart Home Skill Api Amazon provide. It might still be a couple of months away, but at least we know it's now on the horizon.
As people have said, obvious things are about state changes to devices, based on criteria.
As soon as I get any info, i'll pass it on
markk
I'm trying to update to the latest version but keep getting this error:
What am I doing wrong?
"errorMessage": "Cannot find module 'hsl-to-rgb-for-reals'",
"errorType": "Error",
"stackTrace": [
"Module.require (module.js:353:17)",
"require (internal/module.js:12:17)",
"Object.<anonymous> (/var/task/node_modules/hsl-to-hex/index.js:3:13)",
"Module._compile (module.js:409:26)",
"Object.Module._extensions..js (module.js:416:10)",
"Module.load (module.js:343:32)",
"Function.Module._load (module.js:300:12)",
}Running Domoticz on Pi3 with RFXtrx433e. LWRF power sockets and dimmer switches. Integrated my existing wirefree alarm PIRs and door contacts with domoticz. Geofencing with Pilot. Harmony Hub. Tado for Heating. Now playing with mysensors.
Madgeni
Hi markk - you'll need to pull the node_modules folder also - i've included a couple of libraries to convert hue to hex
markk
hi Madgeni
I downloaded the whole zip from github into a separate folder, changed the config.json and then zipped all 4 new files, including the node_modules folder together !
Madgeni
weird - and that module is in the node_modules folder?
markk
yep
here's the folder. The zip contains the three downloaded today plus the amended conf.json
- alexa4.jpg (97.9 KiB) Viewed 2277 times
Madgeni
i've just tested it again on the lambda, and all seems well this end?
this is the test i use:
"header": {
"messageId": "ABC-123-DEF-456",
"namespace": "Alexa.ConnectedHome.Control",
"name": "SetColorRequest",
"payloadVersion": "2"
"payload": {
"accessToken": "123",
"appliance": {
"applianceId": "157",
"additionalApplianceDetails": {
"WhatAmI": "light"
"color": {
"hue": 180.0,
"saturation": 1.0000,
"brightness": 97.0000
}Native Alexa skill and Google app - register at https://www.controlicz.com - https://twitter.com/Controlicz
qwerk
I don't see how to get a message to alexa with this skill. Alexa seems to be the trigger in the jbreed story and I am looking for a way to let ( in my case) domoticz be the trigger. please correct me if I am wrongLokonli wrote:I've derived it from:qwerk wrote:@lokonli that's the kind off things I had in mind.
See:
When I reed back my earlier post, it says "without man in the middle" I do not see the madgeni skill as a "man in the middle" but as a necessary and good step from domoticz to alexa.
I meant without an extra man in the middle. just to set things straight.
markk
How odd.
just tried again with your test but still no good. Here's the cloud watch report:
START RequestId: 9641d249-3ae4-11e7-8db5-ab8d427fed42 Version: $LATEST
Unable to import module 'domapi': Error
at Function.Module._resolveFilename (module.js:325:15)
at Function.Module._load (module.js:276:25)
at Module.require (module.js:353:17)
at require (internal/module.js:12:17)
at Object.<anonymous> (/var/task/node_modules/hsl-to-hex/index.js:3:13)
at Module._compile (module.js:409:26)
at Object.Module._extensions..js (module.js:416:10)
at Module.load (module.js:343:32)
at Function.Module._load (module.js:300:12)
END RequestId: 9641d249-3ae4-11e7-8db5-ab8d427fed42
REPORT RequestId: 9641d249-3ae4-11e7-8db5-ab8d427fed42 Duration: 9.78 ms Billed Duration: 100 ms Memory Size: 512 MB Max Memory Used: 36 MB Running Domoticz on Pi3 with RFXtrx433e. LWRF power sockets and dimmer switches. Integrated my existing wirefree alarm PIRs and door contacts with domoticz. Geofencing with Pilot. Harmony Hub. Tado for Heating. Now playing with mysensors.
Madgeni
i must have broken something - i'll go through it again
Madgeni
I've added a zipped file which has my current files (the same as on github) to github - this is the one i'm using - try that?
