Amazon Echo to Domoticz Bridge: switches, sensors & more
Alexa, Google Home and Siri
Madgeni
Re: Amazon Echo to Domoticz Bridge: switches, sensors & more
Post by Madgeni »
working on light colour control - one issue is controlling multiple lights. As you control one device at a time, i'm not sure of the user experience you'll get if you have to do this one light at a time!
any thoughts anyone?
borcon
Post by borcon »
@swifty: sorry for late reply.
My nginx reverse proxy has a self-signed webserver certificate.
Amazon AWS is talking to my proxy and forwards the packages to domoticz. Thats all.
In aws i have no own (client) certificates. AWS accepts in dev mode self signed certs.
@Madgeni, i will send you a new version of the manual
Madgeni
Post by Madgeni »
Thanks Borcon - it's been uploaded.
Also, i've added the ability to set colours (i've only tested it at the lambda, not via Alexa). I had to create the ability in the node module for Domoticz, I convert it to hex, so took a little while.
Still not convinced that turning each Hue on (or any RGBW) one by one is a great experience!
Madgeni
Post by Madgeni »
so - just heard that Alexa Notifications are coming soon. As my Product Owners ;) - can you provide me with some user stories for notifications, and i'll get thinking
heggink
Domoticz version: 12451
Post by heggink »
Wow, interesting. How would that work?
DASHTICZ 🙃
P1 meter & solar panel
qwerk
Post by qwerk »
@madgeni is that like push messages?
and you need use cases specific for alexa-domo?
Lokonli
Post by Lokonli »
My use case for Alexa push notifications: when someone enters the garage this is detected by a PIR sensor. This triggers Alexa to say 'We have a guest' (or whatever you want)
I have this working. I have modified the Alexa AVS sample app to send a pre-recorded MP3 file to the Alexa server. This triggers a custom skill which gets the text that needs to be speech synthesized from Domoticz.
The delay between PIR detection and the moment Alexa starts talking is a few seconds. Acceptable.
Verstuurd vanaf mijn SM-G800F met Tapatalk
qwerk
Post by qwerk »
@lokonli that's the kind off things I had in mind.
I had a homey, and let domoticz speak through it.
Doorbell actions, specific confirmations, and PIR's but only after time checking etc.
So a way to let Domoticz to tell Alexa what to say, would be perfect for me.
The nicest way is to let it happen without "man in the middle" so domoticz >> the skill by madgeni >> alexa.
How did you make this function, is there a manual ???
Lokonli
Re: RE: Re: Amazon Echo to Domoticz Bridge: switches, sensors & more
Post by Lokonli »
qwerk wrote:@lokonli that's the kind off things I had in mind.
I've derived it from:
https://github.com/jbreed/AlexaDomoticz
See:
http://www.domoticz.com/forum/viewtopic.php?t=8755
Madgeni
Post by Madgeni »
I'd considered another skill just for push notifications - using mqtt to the AWS iot - but the ideal is for it to be built into the Smart Home Skill Api Amazon provide. It might still be a couple of months away, but at least we know it's now on the horizon.
As people have said, obvious things are about state changes to devices, based on criteria.
As soon as I get any info, i'll pass it on
markk
Post by markk »
I'm trying to update to the latest version but keep getting this error:
  "errorMessage": "Cannot find module 'hsl-to-rgb-for-reals'",
  "errorType": "Error",
  "stackTrace": [
    "Module.require (module.js:353:17)",
    "require (internal/module.js:12:17)",
    "Object.<anonymous> (/var/task/node_modules/hsl-to-hex/index.js:3:13)",
    "Module._compile (module.js:409:26)",
    "Object.Module._extensions..js (module.js:416:10)",
    "Module.load (module.js:343:32)",
    "Function.Module._load (module.js:300:12)",
What am I doing wrong?
Madgeni
Post by Madgeni »
Hi markk - you'll need to pull the node_modules folder also - i've included a couple of libraries to convert hue to hex
markk
Post by markk »
hi Madgeni
I downloaded the whole zip from github into a separate folder, changed the config.json and then zipped all 4 new files, including the node_modules folder together !
Madgeni
Post by Madgeni »
weird - and that module is in the node_modules folder?
markk
Post by markk »
yep
here's the folder. The zip contains the three downloaded today plus the amended conf.json :?
Madgeni
Post by Madgeni »
i've just tested it again on the lambda, and all seems well this end?
this is the test i use:
  "header": {
    "messageId": "ABC-123-DEF-456",
    "namespace": "Alexa.ConnectedHome.Control",
    "name": "SetColorRequest",
    "payloadVersion": "2"
  "payload": {
    "accessToken": "123",
    "appliance": {
      "applianceId": "157",
      "additionalApplianceDetails": {
        "WhatAmI": "light"
    "color": {
      "hue": 180.0,
      "saturation": 1.0000,
      "brightness": 97.0000
qwerk
Post by qwerk »
See:
I don't see how to get a message to alexa with this skill. Alexa seems to be the trigger in the jbreed story and I am looking for a way to let ( in my case) domoticz be the trigger. please correct me if I am wrong
When I reed back my earlier post, it says "without man in the middle" I do not see the madgeni skill as a "man in the middle" but as a necessary and good step from domoticz to alexa.
I meant without an extra man in the middle. just to set things straight.
markk
Post by markk »
How odd.
just tried again with your test but still no good. Here's the cloud watch report:
START RequestId: 9641d249-3ae4-11e7-8db5-ab8d427fed42 Version: $LATEST
Unable to import module 'domapi': Error
at Function.Module._resolveFilename (module.js:325:15)
at Function.Module._load (module.js:276:25)
at Module.require (module.js:353:17)
at require (internal/module.js:12:17)
at Object.<anonymous> (/var/task/node_modules/hsl-to-hex/index.js:3:13)
at Module._compile (module.js:409:26)
at Object.Module._extensions..js (module.js:416:10)
at Module.load (module.js:343:32)
at Function.Module._load (module.js:300:12)
END RequestId: 9641d249-3ae4-11e7-8db5-ab8d427fed42
REPORT RequestId: 9641d249-3ae4-11e7-8db5-ab8d427fed42	Duration: 9.78 ms	Billed Duration: 100 ms Memory Size: 512 MB	Max Memory Used: 36 MB
Madgeni
Post by Madgeni »
i must have broken something - i'll go through it again
Madgeni
Post by Madgeni »
I've added a zipped file which has my current files (the same as on github) to github - this is the one i'm using - try that?
