If you are referring to removing an incorrect power measurement; if it's the P1 port output, there are up to 4 plot lines in the the graph.
So if you remove a value, you only remove one single value from one line. So you might need to remove the value at the same point more than once in order to remove the one you are after.
This is a very old thread, but I'm running into the same problem. I confirm the deletion, but the value remains visible. What is the best solution to get this removed?
Dz on Ubuntu VM on DS718+ behind FRITZ!Box.
EvoHome; MELCloud; P1 meter; Z-Stick GEN5; Z-Wave-js-ui; Sonoff USB-Dongle Plus-E; Zigbee2Mqtt; MQTT; Greenwave powernodes 1+6; Fibaro switch, plugs, smoke; FRITZ!DECT 200. Scripts listed in profile interests.
I also saw recently this looks not working anymore: I have a zwave temp sensor that sometimes returns false 0°C values for some time and I cannot erase these values anymore. This at least lasts since my (still) current 2025.1.
I I'm currently still using this version as trying to make a brand new SD with up to date raspbian (because ssl3) and Domoticz 2025.2 leads to a complete/brutal system hang at domoticz startup when zwave/zigbee sticks are attached (without this, it starts). And so sudden I could not get any logs so completely in the dark for the root-cause...
It is an Electric (Instant+counter). First value very high.
Both refresh page and holding shift did not do the tric.
I guess I have to go into the database and see how and where it is stored.
Actually it would be a nice feature, when there is an option to delete all data of a selected device in a given timeframe.
For some other devices I see a past of may years ago. Sometimes interesting, but it also sometimes makes it less clear with data that I am no longer interested in. Then it would be nice to be able to selectively remove it.
For me removing an incorrect value only works in the week, month or year graphs. Not in the day graph. But it could also depend on the type of device, not sure.
waltervl wrote: Wednesday 07 January 2026 23:05
Ah, maybe that is the solution. (But in that case it is strange that a popup appears to confirm the removal!!)
I managed to remove it from the monthly overview. I will see what happens to the daily value as time goes by. Thanks so far.
