this is the first time i have problems with this module.
As far as Domoticz can tell the module is alive, gives out temperature readings, poll ok but it does not switch on/off
i actually says it switches on/off but the light does not go on like the relay is either stuck or damaged.
really strange.
the only way i could solve this is to switch of the power to the module for 30 seconds.
after that everything was back to normal.
did anybody else experience something similar?
Qubino ZMNHAD1 alive but not repsonding
tinidk
Re: Qubino ZMNHAD1 alive but not repsonding
I have the same issue with 2 out of 6 qubino flush dimmer modules.
Mine are not working, but they are not marked as dead.
I will try to disconnect power to them, and see if that helps.
