Qubino ZMNHAD1 alive but not repsonding
Gravityz
Post by Gravityz »
this is the first time i have problems with this module.
As far as Domoticz can tell the module is alive, gives out temperature readings, poll ok but it does not switch on/off
i actually says it switches on/off but the light does not go on like the relay is either stuck or damaged.
really strange.
the only way i could solve this is to switch of the power to the module for 30 seconds.
after that everything was back to normal.
did anybody else experience something similar?
tinidk
Re: Qubino ZMNHAD1 alive but not repsonding
Post by tinidk »
I have the same issue with 2 out of 6 qubino flush dimmer modules.
Mine are not working, but they are not marked as dead.
I will try to disconnect power to them, and see if that helps.
