Aurora Nanoleaf
andi216
Domoticz version: 3.7243
Aurora Nanoleaf
Post by andi216 »
Hello everybody
Aurora Nanoleaf device is possible to implement?
https://nanoleaf.me/en/consumer-led-lig ... arter-kit/
Api (.pdf)
https://community.home-assistant.io/t/n ... ort/5786/5
tontze
Domoticz version: Beta Ch
Re: Aurora Nanoleaf
Post by tontze »
No thats cool lightning, definitely interested if someone can implement it !
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
andi216
Re: Aurora Nanoleaf
Post by andi216 »
They are a bit expensive. I was curious if domoticz system can contrlol.
poudenes
Domoticz version: 3.8993
Re: Aurora Nanoleaf
Post by poudenes »
I gonna get mine today.... For now not supported. And to bad im not a programmer. But maybe people can help en give me some info maybe someone can build a plugin :)
poudenes
Re: Aurora Nanoleaf
Post by poudenes »
Until there is no plugin what you can do (if you use homekit as well) is add the created scenes in NanoLead app and make a automation within Homekit.
When you do lights on you can automatic turn on a scene on NanoLeaf Aurora.
I have created switched in Domoticz that triggers scenes within Domoticz for my lights. These switches are true homebridge into homekit. With MQTT as well the response is so quick that it seems that Aurora is controlled by Domoticz
cattoo
Domoticz version: 2.3072
Re: Aurora Nanoleaf
Post by cattoo »
Home assistant had success to include Nanoleaf Aurora, so it feels like if some programer could translate the script it would be possible.
Script
poudenes
Re: Aurora Nanoleaf
Post by poudenes »
cattoo wrote: Wednesday 15 November 2017 11:48 Home assistant had success to include Nanoleaf Aurora, so it feels like if some programer could translate the script it would be possible.
Script
im not a programer but a high Thanks for the one who can do this !!
+1
MatsL
Re: Aurora Nanoleaf
Post by MatsL »
Nanoleafs can be controlled similary as the Ikea bulbs by calling scripts. See here:
viewtopic.php?t=13882&start=40#p143476
First generate a API key (google translate)
https://technikkram.net/2017/05/nanolea ... ic-steuern
Then create scripts and make a calls to them from a domoticz selector switch
Examples below, replace IP and Auth_token with your own
On= {"on":true}
Off= {"on":false}
#!/bin/bash
curl -v -X PUT -H "Content-Type: application/json" -d '{"on":true}' http://192.168.0.218:16021/api/v1/AUTH_TOKEN/state/
Effect selector=
{"select" : "Forest"}
{"select" : "Nemo"}
and so on...
#!/bin/bash
curl -v -X PUT -H "Content-Type: application/json" -d '{"select" : "Forest"}' http://192.168.0.218:16021/api/v1/AUTH_TOKEN/effects/
poudenes
Re: Aurora Nanoleaf
Post by poudenes »
Wow that is good news! Better then nothing. I go try this :)
MatsL wrote: Monday 12 February 2018 18:52 Nanoleafs can be controlled similary as the Ikea bulbs by calling scripts. See here:
On= {"on":true}
Off= {"on":false}
#!/bin/bash
Effect selector=
{"select" : "Nemo"}
and so on...
#!/bin/bash
poudenes
Re: Aurora Nanoleaf
Post by poudenes »
Cant get any API key.. Everything i try i get a 404 error
MatsL
Re: Aurora Nanoleaf
Post by MatsL »
Guide in swedish:
https://snillevilla.se/guide_step/nanol ... i-nyckeln/
A short translation:
Download Postman and install it on your computer
Find you nanoleaf IP-adress, check in your wireless router or use Fing on your mobile phone
192.168.xxx.xxx
Go to your Nanoleaf and press power button for 5-7s until white led starts blinking
Now you got a 30s window to do the next step:
Use postman and do a POST (not GET) select it next to the adress bar
Replace with your own IP
http://192.168.xxx.xxx:16021/api/v1/new
In postman you will see the response containing the API key
MatsL
Re: Aurora Nanoleaf
Post by MatsL »
And to verify if the key works you can do a GET in Postman to this adress:
http://192.168.xxx.xxx:16021/api/v1/APIKEY/effects/
Replace with right IP and insert your own API KEY
The response should be a list of available effects
    "select": "Romantic",
    "effectsList": [
        "Bedtime",
        "Color Burst",
        "Deep Abyss",
        "Dracarys",
        "Flames",
        "Forest",
        "Matrix",
        "Mint",
        "Nemo",
        "Netflix and Chill",
        "Northern Lights",
        "Rain",
        "Reading Light",
        "Romantic",
        "Sleep Mode",
        "Snowfall",
        "Sweet candy",
        "Test",
        "Triluminox Energy Crystal",
        "Twinkling Midnight Sky",
        "Vibrant Sunrise",
        "Vintage Modern",
        "moonlight"
poudenes
Re: Aurora Nanoleaf
Post by poudenes »
I have created this script for On and Off
nl.sh true/false
#!/bin/bash
curl -v -X PUT \
    --url  http://192.168.100.2:16021/api/v1/API KEY HERE/state/\
    --header 'content-type: application/json' \
    --data '{"on":'$1'}';
and this one for effect. You can now add the effect and it will act. So you can add many Switch Selectors with a scene without make lots of script for 1 specific scene
nleffect.sh "flames"
nleffect.sh "Roces are Red"
#!/bin/bash
curl -v -X PUT \
    --url  http://192.168.100.2:16021/api/v1/API KEY HERE/effects/\
    --data '{"select":"'"$1"'"}';
poudenes
Re: Aurora Nanoleaf
Post by poudenes »
Hi All,
found this on GitHub:
https://github.com/dumbstart/nanoleaf-cli
You can do more then just effect and on off. Also Brightness level.
desertdog
Domoticz version: 2020.1
Re: Aurora Nanoleaf
Post by desertdog »
poudenes wrote: Wednesday 04 April 2018 13:41 I have created this script for On and Off
nl.sh true/false
#!/bin/bash
curl -v -X PUT \
#!/bin/bash
curl -v -X PUT \
Do you have an example of this script and how to add that to a selector?
