no counter values in day
ropske
Domoticz version: V3_8394
Post by ropske »
i made some counters and for some reason there is no data in the day usage.
Please find pictures in attachment
Total count as overview is now at 34 and that's correct.
But day usage keeps telling 0
Someone knows what i'm doing wrong?
Thank you
2017-05-08 09_27_44-Clipboard.jpg (9.8 KiB) Viewed 2529 times
2017-05-08 09_26_15-Clipboard.jpg (33.1 KiB) Viewed 2529 times
2017-05-08 09_24_53-Clipboard.jpg (95.7 KiB) Viewed 2529 times
geezerrr
Re: no counter values in day
Post by geezerrr »
Hmm I have the same problem. No idea how to debug this one.
ropske
Post by ropske »
Glad i'm not alone :p
i want to know how many times my dishwasher,... has run every day.
But now i cant do it with domoticz
In my sql server i can see it (i store all data also in here)
freijn
Domoticz version: Stable
Post by freijn »
Could it be the way you insert the events?
I think I am using the same (general ) counter and adressing the counting via a URL.
As you can see with nice hour stats
ropske
Post by ropske »
freijn wrote:Could it be the way you insert the events?
Hi freijn,
thank you for your answer.
You could be right :)
i'm updating my counters this way:
http://127.0.0.1:8080/json.htm?type=com ... value=xxxx
where svalue is the updated value of my counter
freijn
Post by freijn »
Hemmm
Everytime I have found a new airplane ( in your case as new wash :-) )
I call the following url
http://192.168.1.155:8080/json.htm?type ... 7&svalue=1
Why you have the two value's ?
b.t.w. Do you not have the issue that the counter goes "red" if not seen for serveral minutes/hrs?
I call the same Url with a 0 (zero) value as a keep alive...
ropske
Post by ropske »
freijn wrote:Hemmm
Your counter, is it a rfxmeter or incremental counter?
Mine is a virtual rfxmeter as a normal counter.
And im not updating by 1 like you, but i store the washes done in a variable and i send that variable to my counter , maybe thats why its not working?
freijn
Post by freijn »
My counter is a script running on an different Rasp and "just" calling the url to increment the counter by 1.
I have not tested the adding to counter as you do, can't help you on that one :-(
I can only confirm that adding 1 every time is working perfectly....
ropske
Post by ropske »
I mean, are you using a normal counter or an incremental counter? See picture :)
2017-05-10 12_59_11-Clipboard.jpg (11.17 KiB) Viewed 2459 times
freijn
Post by freijn »
The "normal" counter.
Top one.
ropske
Post by ropske »
can you show the information about your counter please?
this is mine:
[77] => Array
[AddjMulti] => 1
[AddjMulti2] => 1
[AddjValue] => 0
[AddjValue2] => 0
[BatteryLevel] => 255
[Counter] => 1 vaatwas
[CounterToday] => 1 vaatwas
[CustomImage] => 0
[Data] => 1 vaatwas
[Description] =>
[Favorite] => 0
[HardwareID] => 4
[HardwareName] => Dummy
[HardwareType] => Dummy (Does nothing, use for virtual switches only)
[HardwareTypeVal] => 15
[HaveTimeout] =>
[ID] => 140CA
[LastUpdate] => 2017-05-11 22:50:08
[Name] => Vaatwasbeurten
[Notifications] => false
[PlanID] => 0
[PlanIDs] => Array
[0] => 0
[Protected] =>
[ShowNotifications] => 1
[SignalLevel] => -
[SubType] => RFXMeter counter
[SwitchTypeVal] => 3
[Timers] => false
[Type] => RFXMeter
[TypeImg] => counter
[Unit] => 1
[Used] => 1
[ValueQuantity] => beurten
[ValueUnits] => vaatwas
[XOffset] => 0
[YOffset] => 0
[idx] => 122
i tried with your url to update the counter, it says ok
"status" : "OK",
"title" : "Update Device"
but when i check at my device it stays at 1
http://192.168.1.175:8080/json.htm?type ... 2&svalue=1
freijn
Post by freijn »
Sure I can show you, but please tell me how to get the info you are showing?
aleph0
Domoticz version: 11838
Post by aleph0 »
Hi guys !
I'm having the same problem on *one* of my three dummy counters, all updated by the same lua function !
This happened when I updated to the beta 7412, everything was working fine before, with version 6371
I checked data in the dB, everything is normal. I guess something is broken in the last betas, but I can't figure out what
koender
Post by koender »
ropske wrote: Monday 08 May 2017 9:31 Hi,
Thank you
So we now in 2019... and still this is happening to me. Logging GB diskspace from my NAS.
Used a Counter. Updating is with:
/json.htm?type=command&param=udevice&idx=$NAS_TEST01_IDX&svalue=<SOMEVALUE>
So the status is ok, but the day count is wrong. Also the graphs are all 0.
Did some testing: First we post this:
/json.htm?type=command&param=udevice&idx=$NAS_TEST01_IDX&svalue=10
Count will be 10.
A few minutes later we post:
/json.htm?type=command&param=udevice&idx=$NAS_TEST01_IDX&svalue=13
Count will be 13.
Graph will show a bar with value 10 (on hour 0) and a bar at with value 3 (for the hour+1). Because it thinks this hour(13) -/- 10 (previous hour) = 3. And I think this is a part of the strange behaviour. I my case I don't want to have a 'usage per day', but just the value of that day, so no calculation with previous periods.
Does anyone know what counter can best be used for 'counting' harddisk GB's?
Edit:
Just found out that 'Custom Sensor' is what I need. It just shows the latest value. And in graph it shows the values over time.
