Dashticz - Module - Calendar
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
You can add a block with upcoming events from your ical-calendar (gmail, apple etc.).
Define them as:
var calendars = {}
calendars.business = { maxitems: 5, url: 'https://calendar.google.com/calendar/', icalurl: 'https://calendar.google.com/calendar/' }
calendars.private = { maxitems: 5, icalurl: 'https://cors-anywhere.herokuapp.com/https://calendar.google.com/calendar/' }
And define them in a column like:
columns[1] = {}
columns[1]['width'] = 2;
columns[1]['blocks'] = [calendars.business,calendars.private]
If you want to combine multiple calendars, add this code:
calendars.combined = {}
calendars.combined.maxitems = 5;
calendars.combined.calendars = [
	{ color:'white',calendar:calendars.business },
	{ color:'#ccc',calendar:calendars.private }
calendars.combined.url = 'https://calendar.google.com/calendar';
columns[1] = {}
columns[1]['blocks'] = [calendars.combined]
If calendars wont load, add https://cors-anywhere.herokuapp.com/ in front of the url.
For example:
calendars.private = { maxitems:5, icalurl: 'https://cors-anywhere.herokuapp.com/https://calendar.google.com/calendar/' }
EdwinK
Re: Dashticz - Module - Calendar
Post by EdwinK »
Mmm. I thought I had it..
Missing required request header. Must specify one of: origin,x-requested-with
ar calendars = {}
calendars.business = { url: 'https://cors-anywhere.herokuapp.com/https://calendar.google.com/calendar/', icalurl: 'https://cors-anywhere.herokuapp.com/<<Google kalender URL.basic.ics' }
calendars.private = { icalurl: 'https://cors-anywhere.herokuapp.com/Google kalender URL.basic.ics/' }
calendars.combined.url = ' https://cors-anywhere.herokuapp.com/https://calendar.google.com/calendar';
Edit. I now have removed the cors-anywhere link and then I get the following in the console:
Request Headers
Provisional headers are shown
Referer:http://192.168.0.10/dashboard/
User-Agent:Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_4) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/58.0.3029.96 Safari/537.36
EdwinK
Post by EdwinK »
Or this might be a problem too:
Refused to display 'https://calendar.google.com/calendar/render' in a frame because it set 'X-Frame-Options' to 'sameorigin'.
poudenes
Domoticz version: 3.8993
Post by poudenes »
Is there any solution how to shown calendars that repeating? I have lots of calendar items that is repeating every 3 weeks. Somedays more then 2 on a day.
I only see the 1 time calendar items ...
bsmeding
Post by bsmeding »
Yes me too, now whole day or repeating items.
Also still a problem with the timezone, everything is +2 hour, is there a possibility to change the timezone
I'm using iCloud calendar
robgeerts
Post by robgeerts »
Timezone and repeating will be fixed in upcoming version.
robgeerts
Post by robgeerts »
bsmeding wrote:Yes me too, now whole day or repeating items.
Could you try latest BETA?
I'm not sure but I changed one thing that may fix it...
qwerk
Post by qwerk »
I am sorry to say, it does not look fixed.
no repeat en two ours off.
an ICS taking from my own mailserver ( kopano) gives the correct time. but also no repeats.
robgeerts
Post by robgeerts »
Didnt check the repeating events yet ;)
ARRGGGHHH I hate the time offset.
In my calendar, all events were ok, but one. One had a time offset of 2 hours..
(Created on another device..)
htilburgs
Post by htilburgs »
Maybe I've overlooked it, but is there also a posibilty to just use one calendar?
I only want to use my icloud calendar.
Hardware:
HansieNL
Post by HansieNL »
htilburgs wrote:Maybe I've overlooked it, but is there also a posibilty to just use one calendar?
var calendars = {}
calendars.icloud = { title: 'My Calendar', icalurl: 'http://<your_url>' }
columns[1]['blocks'] = [calendars.icloud];
Blah blah blah
EdwinK
Post by EdwinK »
Still can't get it to work.
var calendars = {}
calendars.business = { url: 'https://calendar.google.com/calendar/', icalurl: 'path_to_basic.ics' }
calendars.private = { icalurl: 'path_to/basic.ics' }
{ color:'red',calendar:calendars.private }
I can see a place under 'Agenda' a slightly lighter place where there should be something, but when clicking it's empty. I think it because of the 'calendars.combined.url'. What should be there?
Agenda
Agenda
Screen Shot 2017-05-08 at 13.31.00.png (128.97 KiB) Viewed 13902 times
bsmeding
Post by bsmeding »
I checked latest beta, but still a 2 hour offset
bsmeding
Post by bsmeding »
EdKo66 wrote:Still can't get it to work.
var calendars = {}
the block must have the value 'calendars.combined' {without the .url}
columns[2]['blocks'] = [314,315,399,''blocktitle_14',calendars.combined]
bsmeding
Post by bsmeding »
For all that use iCloud calendar but don't want to use an public service processing their calendar items (privacy)
I download the ical from iCloud every 5 minutes to a local folder and use this local file for the calendar plugin
the file is a php file, so you need php available
create in custom a new folder :
mkdir ical
place this file to this folder
change the path in the file for $local_file, use full path because it will run from cronjob
$remote_file = url from iCloud calendar (in example the dutch holiday's) but you can use this for you own shared iCloud calendar.
calendar.feestdagen.php
<?php
$local_file = "/var/www/home.local/web/dashboard/dashticz_beta/custom/ical/calendar.feestdagen.ics";//This is the file where we save the information
$remote_file = "https://p58-calendars.icloud.com/holidays/nl_nl.ics"; //Here is the file we are downloading
$ch = curl_init();
$fp = fopen ($local_file, 'w+');
$ch = curl_init($remote_file);
curl_setopt($ch, CURLOPT_TIMEOUT, 50);
curl_setopt($ch, CURLOPT_FILE, $fp);
curl_setopt($ch, CURLOPT_FOLLOWLOCATION, 1);
curl_setopt($ch, CURLOPT_ENCODING, "");
curl_exec($ch);
curl_close($ch);
fclose($fp);
open 'crontab -e'
*/5 * * * * /usr/bin/php /var/www/home.local/web/dashboard/dashticz_beta/custom/ical/calendar.gezamenlijk.php
00 00 * * * /usr/bin/php /var/www/home.local/web/dashboard/dashticz_beta/custom/ical/calendar.feestdagen.php
I use two scripts, one for holidays, update every day once at 00:00 hour
and second script run every 5 minutes to update the iCloud shared calendar (gezamenlijke) these two icals will be used in Dashticz
CONFIG.js
var calendars = {}
calendars.gezamenlijk = { icalurl: 'custom/ical/calendar.gezamenlijk.ics' }
calendars.feestdagen = { icalurl: 'custom/ical/calendar.feestdagen.ics' }
   { color:'white',calendar:calendars.gezamenlijk },
   { color:'#ccc',calendar:calendars.feestdagen }
calendars.combined.url = 'https://www.icloud.com/#calendar';
columns[2]['blocks'] = [314,315,399,'blocktitle_6','buttons.cameravoordeur','blocktitle_14',[b]calendars.combined[/b]]
EdwinK
Post by EdwinK »
[/quote]
That is what I have. Maybe I do something wrong with the Google Calendar. Trying with Icloud.
robgeerts
Post by robgeerts »
I'm rewriting the calendar block, will be up in few days I hope, please be patient! :)
EdwinK
Post by EdwinK »
Will do ;)
poudenes
Post by poudenes »
robgeerts wrote:Timezone and repeating will be fixed in upcoming version.
In v2 and Beta i can't see my repeating calendar. just the one time calendars.
robgeerts
Post by robgeerts »
You mentioned that already, will be fixed soon ;)
