Dashticz - Bug report
HansieNL
Re: Dashticz - Bug report
Post by HansieNL »
Just updated to latest beta and all the trash info is gone. I have only the icon left. Anyone else has same problem?
EDIT: Fixed :D
Blah blah blah
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Fixed in beta!
htilburgs
Post by htilburgs »
robgeerts wrote:Fixed in beta!
Confirmed! And the new var trashnames / colors work nice!!
Hardware:
Blueone
Post by Blueone »
robgeerts wrote:
Blueone wrote:There appear to be a new bug with the thermostat function. Every 5 seconds (the refresh time) there is a class added to the thermostat setpoint. When you increase or decrease the setpoint the action is done for every added class, zo if you have the dashboard open for a couple of minutes the classed several dozens of classes are added to the setpoint, and it is going to change the setpoint for every class and one click will change the setpoint with 10 degrees for example:
Please test in latest beta!
Sorry, not working yet, I know have one setpoint with loads of classes which increases with every refresh and one setpoint without a thermostat**** class. The up and down aren't working at all.
I also verified the code I added in the addthermostat function in main.js but that isn't causing the issue.
robgeerts
Post by robgeerts »
Could you try once in another browser?
Blueone
Post by Blueone »
My mistake, I had some code in custom.js which was interfering. Both setpoint don't have a thermostat class at all at the moment, so changing the setpoint doesn't work but the multiple classes are gone.
robgeerts
Post by robgeerts »
Those classes arent used anymore ;)
Blueone
Post by Blueone »
Oke clear, but the increase and decrease doenst work at the moment :P, so there is still a small bug somewhere.
maninblack30
Post by maninblack30 »
on the latest master I have a selector switch, if I operate any other switch once, the drop-down for the selector doesn't stay open long enough for me to select, tried chrome and IE. it works fine if it's the first switch i use after a reload, but as soon as I operate anything else it breaks again.
Ta,
mikeoo
Post by mikeoo »
Updated to latest beta and cleared the cache.
I use some door sensors with Xiaomi Mi Smart Home Gateway 2.
Added them to Dashticz and try to use some other icons instead of the default ones because i want to use the doorsensor as a windowssensor.
For the test i use this in config.js
blocks[1980] = {}
blocks[1980]['icon'] = 'fa-window-close';
blocks[1980]['title'] = 'Voordeur';
blocks[1980]['show_lastupdate'] = true;
But it keeps the default doorsensor icon .
When i do the same for a dummy switch it is working fine.
qwerk
Post by qwerk »
hi,
since today I get
a java error main.js/v=54 line:417
It is not the lat beta also before that.
Is it my installation, or is dashticz?
HansieNL
Post by HansieNL »
mikeoo wrote:Updated to latest beta and cleared the cache.
blocks[1980] = {}
I'm not sure of this works in your case... maybe you can try? Add following code to custom.js. Change to your own icon.
function getBlock_1980(device,idx){
   $('.block_'+idx).attr('onclick','switchDevice(this)');
   var html='';
   html+='<div class="col-xs-4 col-icon">';
      if(device['Status']=='Closed') html+='<img src="img/your_icon_closed.png" class="off icon" />';
      else html+='<img src="img/your_icon_open.png" class="on icon" />';
   html+='</div>';
   html+='<div class="col-xs-8 col-data">';
   html+='<strong class="title">'+device['Name']+'</strong><br />';
   if(device['Status']=='Off') html+='<span class="state">Closed</span>';
   else html+='<span class="state">Open</span>';
   if(_SHOW_LASTUPDATE) html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(_LASTUPDATE_FORMAT)+'</span>';
   html+='</div>';
   return html;
Blah blah blah
robgeerts
Post by robgeerts »
qwerk wrote:hi,
since today I get
Try latest beta..
Do you still have the issue in this version?
qwerk
Post by qwerk »
robgeerts wrote:
qwerk wrote:hi,
since today I get
Try latest beta..
had it a few tmes with at least two dashticz versions
moved to latest beta and other webserver.
did not have it anymore
mikeoo
Post by mikeoo »
blocks[1980] = {}
   var html='';
   html+='</div>';
   html+='</div>';
   return html;
Nice, code is working fine.
Only problem when you need to use it for more sensors you get a lot of extra code in custom.js for every sensor.
Why does it works for most sensor when you change the icon in CONFIG.js but not for this type of sensor.
Blueone
Post by Blueone »
Blueone wrote:Oke clear, but the increase and decrease doenst work at the moment :P, so there is still a small bug somewhere.
Oke, i found the bug in this piece of code:
[/code]
if(typeof(addedThermostat[idx])=='undefined'){
addThermostatFunctions('.block_'+idx+'_2');
addedThermostat[idx] = true;
[/code]
The ‘_2’ is hardcoded while not every setpoint block contains the _2, for example, mine setpoint block class is simply Block_628, so the clickevent isn’t added to the block.
BTW: The thermostatfunctions are also added to the temperature blocks at the moment, not really an issue but it isn’t nessecary ;)
robgeerts
Post by robgeerts »
Thanks for finding the bug, will fix this asap!
robgeerts
Post by robgeerts »
[/code]
[/code]
Could you test latest beta?
robgeerts
Post by robgeerts »
blocks[1980] = {}
Should be fixed in latest beta!
htilburgs
Post by htilburgs »
@robgeerts, I'm using the index2 / custom_2 option right now. Works great, but....
Can it be that the custom.css doesn't work that's in this directory? Or did I miss something?
Hardware:
Locked
