josimd
Re: Dashticz v2.0, custom positioning and multiple screens
Post by josimd »
mvveelen wrote:
josimd wrote:An easy question... how can add a blocktitle like "Schakelaars woonkamer" ?
See the wiki:
use in config.js :
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars woonkamer';
and then:
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1']
Thanks, I exactly followed your steps.. but no title... I can add all my switches etc etc.. but no title... :-(
var blocks = {}
var columns = {}
columns[1] = {}
htilburgs
Post by htilburgs »
var blocks = {}
var columns = {}
columns[1] = {}
EDIT: Sorry, made a mistake.
Can you post your CONFIG.js (without the private information)??
Hardware:
jake
Post by jake »
The maps block shows an empty grey block. Is it possible that it has to do with the API-key. I went into my google account and found the API website. However, for Google Maps there are more than 10 different API keys like Maps Roads etc. Which one do I have to select? I can't find anything about it in the Wiki, how to properly setup the Maps functionality. The Wiki explains the 3 map variables, but without example or further instruction. It therefore is possible that the coordinates are filled in with an incorrect format.
josimd
Post by josimd »
var blocks = {}
var columns = {}
columns[1] = {}
Ok, changed it... but... no change :-(
var blocks = {}
blocks['blocktitle_1']['title'] = 'Schakelaars';
columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1'];
htilburgs
Post by htilburgs »
josimd wrote:
var blocks = {}
var columns = {}
columns[1] = {}
var blocks = {}
columns = {}
columns[1] = {}
Sorry, made a mistake, didn't read good...;) It should be var columns = {}
Hardware:
josimd
Post by josimd »
htilburgs wrote:
josimd wrote:
var blocks = {}
columns = {}
columns[1] = {}
Hereby.... should be easy...
//CUSTOM POSITIONING:
//defining which blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
var blocks = {}
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['Schakelaar',27] //remark: idx 144 produces 2 blocks, so you can use: '144_1' and '144_2' (or of course, just 144 if you want one)
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise','horizon',buttons.buienradar,buttons.radio,buttons.calendar,buttons.nunl,buttons.nzbget]
columns[3]['width'] = 2;
sander
Domoticz version: latest..
Post by sander »
Hi All, I know I should be mowing the lawn and not try to thinking I can do this too.
But would anyone be so kind to tell me:
1) in which fill do you put the code for custom positioning
2) can someone post a printscreen of an actual working part of code for example of a dimmer or a switch.
I am going nuts to get anything going, I just need a handle to get going. Once I know where and how I will sort it I reckon.
It is just to nice to throw it overboard because I cant get going.
Thank you in advance!
Raspberry Pi 2B+
connected: klik aan klik uit switches, dimmers, weather station, water meter (pulse)
Automation use: Blocky
htilburgs
Post by htilburgs »
columns[1]['blocks'] = ['Schakelaar',27] is not Ok. Should be:
columns[1]['blocks'] = ['blocktitle_1',27]
Hardware:
josimd
Post by josimd »
htilburgs wrote:columns[1]['blocks'] = ['Schakelaar',27] is not Ok. Should be:
ooo finally!!! Thanks! Saved my day.... :-)
htilburgs
Post by htilburgs »
Glad to help, but.....
I answered the same as @mweelen did in the previous post.
But an error is quickly made. I'm using the dashboard for 5 weeks now and getting the hang of it....
Enjoy it and have a nice evening.
mvveelen wrote:
See the wiki:
use in config.js :
CODE: SELECT ALL
and then:
CODE: SELECT ALL
var columns = {}
columns[1] = {}
Hardware:
mvveelen
Post by mvveelen »
Glad we can help each other. I'm still learning every day and there are still a few things that don't really work for me. One of them is the (combined) calendars, but maybe Rob can help me out with that.
The other thing is the pressure of the CV, where it should read 1,3Bar it only tells me that it's ON, hahahaha.
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
EdwinK
Post by EdwinK »
I find this part of the community very supportive. Happy with that. Have soon other sort of behaviour.
I too can't get the combined calendars to work, but we might, one day. I don't really mind, as I can always access my calendars through my computers and smartphone
mvveelen
Post by mvveelen »
EdKo66 wrote:I find this part of the community very supportive. Happy with that. Have soon other sort of behaviour.
You mean "seen" I guess :mrgreen:
Yeah, but so can we with all other sensors and statuses. Just trying to get this fixed. But 'glad' to see that I'm not the only one with this problem, so the code might need to be altered a bit.
EdwinK
Post by EdwinK »
Yeah. Getting late a bit.
mkscity
Domoticz version: 3.5877
Post by mkscity »
is it somehow possible to change days in "currentweather_big" from lowercase to normal view?
saturday = Saturday, sunday = Sunday................
in language file it is correct, but somewhere it will changed to lowercase.
DvD
Post by DvD »
DvD wrote:I didn't change anything , except the updates with git pull but now after 5 minutes it goes to a black screen. Normally it should dimm the active screen.
my config
var _LANGUAGE                           = 'nl_NL'; //or: en_US, fr_FR, hu_HU
var _HOST_DOMOTICZ                      = 'http://192.168.0.4:8080';
var _DOMOTICZ_REFRESH           = 5; //in seconds
var _DASHTICZ_REFRESH           = 30;
var _HOST_ZIGGO_HORIZON         = 'http://192.168.0.4:8080/dashboard/switch_horizon.php'; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND        = ';
var _WEATHER_CITY                       = 'Spijkenisse';
var _WEATHER_CITYNAME           = ''; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY            = 'NL';
var _USE_AUTO_POSITIONING       = false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES                      = true; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK  = true; //do not show the seconds in the clock
var _NEWS_RSSFEED                       = 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT                     = false;
var _STANDBY_AFTER_MINUTES  = 5; //enter amount of minutes like: 5 (5 minutes)
var _USE_DUTCH_TRAFFICINFO      = true;
var _STANDBY_CALL_URL           = 'http://127.0.0.1/cgi-bin/screen_brightness.cgi?brightness=20'; //adjust brightness raspberry touchscreen, leave empty if not used
var _END_STANDBY_CALL_URL       = 'http://127.0.0.1/cgi-bin/screen_brightness.cgi?brightness=250'; //adjust brightness raspberry touchscreen, leave empty if not used
var _IDXmoonpicture      = 31; //index of the uservariabele MoonPicture
var _APIKEY_MAPS         = ';
var _MAPS_LATITUDE         = 51.850978;
var _MAPS_LONGITUDE      = 4.321489;
var _MAPS_ZOOMLEVEL = 11
var _SCREENSLIDER_EFFECT        = 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip'
Am I missing something ?
Nobody ?
godinperson
Post by godinperson »
I just installed Dashticz, configured the settings but all I get is a blank Dashticz screen with only the background image. If I open the console on Chrome, I get:
[Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
And hundreds of
Uncaught TypeError: disableStandby is not a function
at HTMLBodyElement.<anonymous> (main.js:413)
at HTMLBodyElement.dispatch (jquery.min.js:3)
at HTMLBodyElement.r.handle (jquery.min.js:3)
What's wrong? I'm on the latest beta of Domoticz
tontze
Domoticz version: Beta Ch
Post by tontze »
godinperson wrote:Hi,
And hundreds of
I did new install too, and getting black screen... In console :
jquery.min.js:4 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
jquery.min.js Failed to load resource: the server responded with a status of 404 (Not Found)
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
tontze
Post by tontze »
And hundreds of
I did new install too (not beta), and getting black screen... In console :
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
tontze
Post by tontze »
And hundreds of
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Locked
