htilburgs
Re: RE: Re: Dashticz - General Discussions
Post by htilburgs »
HansieNL wrote:
robgeerts wrote:
HansieNL wrote:Hello Rob,
Is it possible to change the icon/image for the trash block. I've made a kliko image and wanna use that one if possible...
Could you send me that image?
Goodmorning,
You did accept my pull request already? If so, you should have it in the img folder as kliko.png.
I see a nice kliko....;)
Hardware:
koowee
Post by koowee »
Rob, can you add these two new device types to Dashticz
Thermostat mode selector. There is four different mode 0 = Off, 1 = Heat (Default), 2 = Cool, 3 = Energy Heat;
   "ActTime" : 1493975839,
   "ServerTime" : "2017-05-05 12:17:19",
   "Sunrise" : "05:01",
   "Sunset" : "21:41",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 4,
         "HardwareName" : "Razberry",
         "HardwareTypeVal" : 21,
         "HaveTimeout" : false,
         "ID" : "00001801",
         "LastUpdate" : "2017-05-05 12:16:43",
         "Mode" : 0,
         "Modes" : "0;Off;1;Heat (Default);2;Cool;3;Energy Heat;",
         "Name" : "Thermostat Mode",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "Thermostat Mode",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "mode",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "329"
   "status" : "OK",
   "title" : "Devices"
Solar radiation, now Dashticz shows it as a switch
   "ActTime" : 1493976213,
   "ServerTime" : "2017-05-05 12:23:33",
   "Sunset" : "21:41",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "347.2 Watt/m2",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 9,
         "HardwareName" : "Dark Sky",
         "HardwareType" : "DarkSky (Weather Lookup)",
         "HardwareTypeVal" : 25,
         "ID" : "0",
         "LastUpdate" : "2017-05-05 12:14:53",
         "Name" : "Solar",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Radiation" : 347.19999999999999,
         "SubType" : "Solar Radiation",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "radiation",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "forecast_url" : "aHR0cHM6Ly9kYXJrc2t5Lm5ldC8jL2YvNjEuNjM2NjUzJTJDJTIwMjMuNzg3MjA1",
         "idx" : "115"
   "status" : "OK",
   "title" : "Devices"
wizjos
Post by wizjos »
Great new functionality this Afvalwijzer (trash)!
However, I noticed that not all dates are displayed because in trash.js (the mijnafvalwijzer part) the object returnDates has the date as a keyname... When trashcollection on a given date has two different collections (for instance 'restafval' and 'plastic') only the latter of these two is added to the object...
Bit confusing: for some mondays 'plastic' is displayed and for other ones 'restafval'. At my place a monday is always 'restafval' and 'plastic' combined...
To solve this I've added a counter (called 'teller') which takes care of making the keys unique:
	if(service=='mijnafvalwijzer'){
		$.getJSON('http://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode=' + postcode + '&street=&huisnummer=' + homenumber + '&toevoeging=',function(data){
			data = data.data.ophaaldagen.data;
			teller=0;
			for(d in data){
				if(typeof(returnDates[curr])=='undefined'){
					returnDates[curr] = {}
				var startDate = moment(moment().format("DD-MM-YYYY"), "DD-MM-YYYY");
				var endDate = moment(moment(Date.now() + 64 * 24 * 3600 * 1000).format("DD-MM-YYYY"), "DD-MM-YYYY");
				var testDate = moment(data[d]['date'], "YYYY-MM-DD");
				if(testDate.isBetween(startDate, endDate, 'days', true)){
					returnDates[curr][moment(moment(data[d]['date'], "YYYY-MM-DD")).format("YYYY-MM-DD")+teller]='<div>'+data[d]['nameType']+': '+moment(moment(data[d]['date'], "YYYY-MM-DD")).format("DD-MM-YYYY")+'</div>';
				teller++;
			addToContainer(random,returnDates);
In the original situation these moments are displayed (I've hacked a little to display more than 3 collection dates):
and with the counter:
Suits my needs a bit more... :mrgreen:
Regards,
Wizjos
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
wizjos wrote:Great new functionality this Afvalwijzer (trash)!
			teller=0;
			for(d in data){
				teller++;
In the original situation these moments are displayed (I've hack a little to display more than 3 collection dates):trash1.PNG and with the counter:trash2.PNG
Regards,
Wizjos
Thanks, will fix this!
robgeerts
Post by robgeerts »
koowee wrote:Rob, can you add these two new device types to Dashticz
   "Sunset" : "21:41",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 4,
         "ID" : "00001801",
         "Mode" : 0,
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "mode",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "329"
   "status" : "OK",
   "title" : "Devices"
   "Sunset" : "21:41",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 9,
         "ID" : "0",
         "Name" : "Solar",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Timers" : "false",
         "Type" : "General",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "115"
   "status" : "OK",
   "title" : "Devices"
Added in latest beta!
mlamie
Domoticz version: 3.5877
Post by mlamie »
I really like the Dashticz dashboard, the only issue for me to use it, is the power consumption. My wall tablet (nexus 7 2013) can't charge fast enough. The USB cable is to long and I need to change things, now it is located next to the thermostat. I used 2 wires connected to the thermostat and the other 2 wires for charging. The charger is located at my HR-kettle.
I now use ImperiHome, which does not drain the battery so fast and can be used 24/7 with the right display brightness.
Is there a way to improve power usage (other browser, refresh rate...) Any suggestions?
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
woody4165
Post by woody4165 »
Hi all
I'm using the "currentweather_big" in a small size block, width 2 (below the sunrise block).
I see it in this way.
Is there a way to center the text or resize it and show the weather icon on the left?
sander
Domoticz version: latest..
Post by sander »
Ouch! Hansie, that did the trick, now I just need to configure, but I see manny more posts on that. At least I can access now. Thanks!
Raspberry Pi 2B+
connected: klik aan klik uit switches, dimmers, weather station, water meter (pulse)
Automation use: Blocky
woody4165
Re: Dashticz v2.0, custom positioning and multiple screens
Post by woody4165 »
robgeerts wrote:First preview of color changer:
Hi @robgeerts
will it work also with Yeelight bulb ?
robgeerts
Post by robgeerts »
Dont know yet, the color choosing is a bit hard for me, especially because I dont have any colored lights...
woody4165
Post by woody4165 »
The hue plugin is still on going, isn't it?
I will try to understand if I can contribute for yeelight...
robgeerts
Post by robgeerts »
Yes, not finished yet..sorry
Blueone
Post by Blueone »
robgeerts wrote:Thanks, please send me when you are done with the weekdays (Especially 'Tomorrow')
Here it is:
function addToContainer(random,returnDates){
   var returnDatesSimple={}
   var done = {};
   for(c in returnDates){
      for(cr in returnDates[c]){
         returnDatesSimple[cr] = returnDates[c][cr];
         done[c]=true;
   $('.trash'+random+' .state').html('');
   var c=1;
   Object.keys(returnDatesSimple).sort().forEach(function(key) {
      var date = moment(key).format("DD-MM-YYYY");
		var currentdate = moment(Date.now()).format("DD-MM-YYYY");
		var tomorrow = moment(new Date()).add(1,'days').format("DD-MM-YYYY")
		var nextweek = (moment(new Date()).add(6,'days').format("DD-MM-YYYY"))
		if(date == currentdate){
			returnDatesSimple[key] = (returnDatesSimple[key]).replace(date, "Today");
		else if(date == tomorrow){
			returnDatesSimple[key] = (returnDatesSimple[key]).replace(date, "Tomorrow");
		else if(date <= nextweek){
			returnDatesSimple[key] = (returnDatesSimple[key]).replace(date, moment(moment(date).format("DD-MM-YYYY")).format("dddd"));
		else {
			//console.log(date)
      if(c<=4) $('.trash'+random+' .state').append(returnDatesSimple[key]);
      c++;
Also changed the number of items to 4 so you have al the trash in one view. (PMD,GFT,Trash,paper). (but this could be a personal choice), I hope this code is usefull.
robgeerts
Post by robgeerts »
Added to latest beta! Thanks!
Although I've changed it a bit so today/tomorrow and the daynames shows in the correct language!
Blueone
Post by Blueone »
Cool, I just wanted to upload the code with the other languages, i thought about it when I already posted it.
Thanks again!
koowee
Post by koowee »
   "Sunset" : "21:41",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 4,
         "ID" : "00001801",
         "Mode" : 0,
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "mode",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "329"
   "status" : "OK",
   "title" : "Devices"
   "Sunset" : "21:41",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 9,
         "ID" : "0",
         "Name" : "Solar",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Timers" : "false",
         "Type" : "General",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "115"
   "status" : "OK",
   "title" : "Devices"
Thanks, now Dashticz shows correct mode!
There is also possibility to change mode In Domoticz. It can be done via device Edit-button. Can this feature also be implemented to Dashticz?
Blueone
Post by Blueone »
robgeerts wrote:Added to latest beta! Thanks!
One minor change, the first letter of the day in uppercase :P
   var done = {};
         done[c]=true;
   var c=1;
         returnDatesSimple[key] = (returnDatesSimple[key]).replace(date, lang['today']);
         returnDatesSimple[key] = (returnDatesSimple[key]).replace(date, lang['tomorrow']);
	 	returnDatesSimple[key] = (returnDatesSimple[key]).replace(date, moment(moment(date).format("DD-MM-YYYY")).locale('nl').format("dddd"));
		returnDatesSimple[key]= returnDatesSimple[key].charAt(0).toUpperCase() + date.slice(1);
      else {
         //console.log(date)
      c++;
barbaar
Post by barbaar »
Just starteed using dashticz. Now I'm busybuilding a custom positioning. This works ok when I initially load the page om my Tablet. However, after the first automatic refresh, the screen s black with only the current time and outside temperature forecasts being displayed. Below you find my current CONFIG.js. On my tablet, I use the Kiosk Browser (https://play.google.com/store/apps/deta ... ully&hl=en)
Any idea what is wrong?
var _WEATHER_CITY = 'Utrecht';
var _WEATHER_COUNTRY = 'NL';
var _USE_AUTO_POSITIONING = false;
var _USE_FAVORITES = false;
var _HIDE_SECONDS_IN_CLOCK = true;
var _HIDE_MEDIAPLAYER_WHEN_OFF = false;
var _STANDBY_AFTER_MINUTES = 1;
var _USE_BEAUFORT = true;
var _TRANSLATE_SPEED = false;
var _SHOW_LASTUPDATE = true;
var _LASTUPDATE_FORMAT = 'DD-MM-YY HH:mm';
var _IDXmoonpicture = 31; //index of the uservariabele MoonPicture
var _SCREENSLIDER_EFFECT = 'slide';
var _USE_STATIC_WEATHERICONS = false; // Static or 'moving' weather icons
var _APIKEY_MAPS = 'XXXX';
var _MAPS_LATITUDE = 52.090737;
var _MAPS_LONGITUDE = 5.121420;
var _MAPS_ZOOMLEVEL = 11;
var _STREAMPLAYER_TRACKS = [
{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/ ... ive_96.mp3"},
{"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"},
{"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
{"track":4,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
{"track":5,"name":"StuBru","file":"http://mp3.streampower.be/stubru-high.mp3"},
var buttons = {}
buttons.buienradar = {width:12, isimage:true, image: 'http://api.buienradar.nl/image/1.0/Rada ... =285&h=256', url: 'http://www.weer.nl/verwachting/nederlan ... t/1811978/'}
buttons.calendar = {width:4, icon: 'fa-calendar', title: 'Kalender', url: 'https://calendar.google.com/calendar'}
buttons.nunl = {width:4, icon: 'fa-newspaper-o', title: 'Nu.nl', url: 'http://www.nu.nl'}
buttons.nzbget = {width:4, icon: 'fa-download', title: 'NZBget', url: 'http://192.168.1.5'}
buttons.moon= {width:12, isimage:true, refreshimage:60000, image: 'moon'}
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Switches';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['title'] = 'Lights';
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['type'] = 'blocktitle';
blocks['blocktitle_3']['title'] = 'Data';
blocks[92] = {}
blocks[92]['title'] = 'Boiler On'
blocks[92]['icon'] = 'fa-fire'
blocks[336] = {}
blocks[336]['title'] = 'Temp Buiten'
blocks[364] = {}
blocks[364]['title'] = 'Temp Binnen'
blocks['news_2'] = {}
blocks['news_2']['feed'] = 'http://feeds.nos.nl/nosnieuwsalgemeen';
blocks[106] = {}
blocks[106]['hide_stop'] = true;
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1','s2',626,644,69,68,67,66,63,677,'blocktitle_2','s1',203,190,145]
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather','blocktitle_3',92,'336_1',364]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['clock',buttons.buienradar,buttons.moon]
columns[3]['width'] = 2;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg1.jpg';
screens[1]['background_morning'] = 'bg_morning.jpg';
screens[1]['background_noon'] = 'bg_noon.jpg';
screens[1]['background_afternoon'] = 'bg_afternoon.jpg';
screens[1]['background_night'] = 'bg_night.jpg';
HansieNL
Post by HansieNL »
   var done = {};
         done[c]=true;
   var c=1;
      else {
         //console.log(date)
      c++;
Maybe captalize the first letter of papier, restafval and plastic and change gft to GFT?
Blah blah blah
HansieNL
Post by HansieNL »
barbaar wrote:Hi,
var buttons = {}
var blocks = {}
blocks[92] = {}
blocks[336] = {}
blocks[364] = {}
blocks[106] = {}
var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
var screens = {}
screens[1] = {}
Nothing seems to be wrong. Your screen goes to standby after 1 minute and shows exactly what you told and have configured.
Blah blah blah
Locked
