- mvveelen
Re: Dashticz v2.0, custom positioning and multiple screens
OK,
I'll try once more:
The 2 calendars aren't working OK.
Sometimes I see both, sometimes I see none, sometimes I see twice the same, but most of the time I only see one of the calendars. I'm using the Apple calendar.
Is this still a bug or am I the only one with more than 1 Apple calendar having these issues ?
On a side-note: when I DO see the calendar(s), the colours can't be set so they are pink or blue (and you can barely read the appointments). Any fix on this?
I'll try once more:
Blueone
Workingrobgeerts wrote:Cure is also working now:
In config.js add:And define in block as:Code: Select all
var trashcan = {} trashcan.cure = { trashapp: 'cure', width:4, zipcode:'5654SB', housenumber:'3' }Code: Select all
columns[1]['blocks'] = [trashcan.cure]
qwerk
when using the latest beta
the var _THEME = 'default' has to be in your config.
pkrabben
- Domoticz version: 3.5877
Hi Rob thanks for this continuous improvementsBlueone wrote:Workingrobgeerts wrote:Cure is also working now:
columns[1]['blocks'] = [trashcan.cure], except the paper, it isn't shown, the title in the json is "Papier en karton"
What are the codes for recycle manager?
- HansieNL
Find some code in the app. Maybe you can use it:
http#2http://afvalkalender.dar.nl/push/address?postcode=#3http://afvalkalender.dar.nl/push/calendar?postcode=##http://afvalkalender.goes.nl/#ehttp://dataservice.deafvalapp.nl/dataservice/DataServiceServlet?service=CHECK_ADRES&land=NL&postcode=#fhttp://dataservice.deafvalapp.nl/dataservice/DataServiceServlet?service=OPHAALSCHEMA&land=NL&postcode=##http://dutchapp.nl/afval/#+http://dutchapp.nl/afval/AfvalNederland.ics##http://dutchapp.nl/afval/area##http://dutchapp.nl/afval/gad#$http://dutchapp.nl/afval/hellendoorn##http://dutchapp.nl/afval/meld##http://dutchapp.nl/afval/meppel# http://dutchapp.nl/afval/opslaan##http://dutchapp.nl/afval/regg##http://dutchapp.nl/afval/regp##http://dutchapp.nl/afval/rova##http://dutchapp.nl/afval/twente##http://dutchapp.nl/afval/uden#$http://dutchapp.nl/afval/waardlanden#9http://inzamelkalender.hvcgroep.nl/push/address?postcode=#:http://inzamelkalender.hvcgroep.nl/push/calendar?postcode=#>http://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode=#)http://rova.quintor.nl/rest/toevoegingen/#=http://vpn-wec-api.recyclemanager.nl/v2/calendars?postalcode=##https#(https://afvalkalender.circulus-berkel.nl#)https://afvalkalender.cure-afvalbeheer.nl#!https://afvalkalender.cyclusnv.nl#+https://afvalkalender.gemeenteberkelland.nl##https://afvalkalender.meerlanden.nl##https://afvalkalender.venray.nl##https://app-measurement.com/a#,https://appservice.rd4.nl/api/afvalkalender/##https://inzamelschema.rmn.nl#Ahttps://pagead2.googlesyndication.com/pagead/gen_204?id=gmob-apps##https://www.avalex.nl#*https://www.gemeentebest.nl/afvalkalender/##https://www.google.com#'https://www.veldhoven.nl/afvalkalender/#1https://www.venlo.nl/trash-removal-calendar/ical/#*https://www.vianen.nl/afval/afvalkalender/##i#,iCertData failed to retrive data from remote
Blah blah blah
- rbisschops
- Domoticz version: 2.2563
I know it's all about taste, but I personally don't like the new weather icons. Is there a way to put the old icons back with breaking the coming releases. Using latests beta of this afternoon.
Thx
Ralph
Thx
Ralph
RPi 3B (master): RFXtrx433, Harmony Hub, Z-Wave devices, CoCo units, Hue, Xiaomi Aquara
RPi 2B (slave): P1 connection, MySensors with custom built watermeter sensors on Aquadis+
RPi’s with: Mosquitto MQTT, Home Bridge, Home Assistant (for evaluation only)
- HansieNL
var _USE_STATIC_WEATHERICONS = true; in config.js gives you the static icons backrbisschops wrote:I know it's all about taste, but I personally don't like the new weather icons. Is there a way to put the old icons back with breaking the coming releases. Using latests beta of this afternoon.
Thx
Ralph
Blah blah blah
tontze
- Domoticz version: Beta Ch
I just did git pull, and all my buttons disappeared, they still exist in config.js ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
robgeerts
- Domoticz version: 3.7067
Any errors in console?
- HansieNL
I had the same, add the following to config.js...tontze wrote:I just did git pull, and all my buttons disappeared, they still exist in config.js ?
Blah blah blah
robgeerts
Oopsie
will fix tonight when i get home
clubeddie
How can i extract a JSON output url?robgeerts wrote:TRASH CALENDAR (DE AFVAL APP)
WARNING: Only DeAfvalApp is working.
If anyone can provide me a JSON-output url of other services, send it to me
(With example zipcode)
I already have url's for:
Recyclemanager
MijnAfvalWijzer
Wil fix those asap so you dont need LUA-scripts
I want to extract it for you from http://inzamelkalender.hvcgroep.nl/
- mvveelen
+1clubeddie wrote:How can i extract a JSON output url?robgeerts wrote:TRASH CALENDAR (DE AFVAL APP)
Recyclemanager
MijnAfvalWijzer
Or rather... + 1000
- htilburgs
Rob, cannot get this to work.robgeerts wrote:Cure is also working now:
I got an error "undefined". Any way I can check what's going wrong?
EDIT: clicking on it gives a 404 Not found
Hardware:
b00n
Someone know how to get the json from an site?
i need it from this one: https://mijn.circulus-berkel.nl/afvalkalender/
tontze
Hm, that didnt help for me ..HansieNL wrote:I had the same, add the following to config.js...tontze wrote:I just did git pull, and all my buttons disappeared, they still exist in config.js ?
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
robgeerts
Re: RE: Re: Dashticz v2.0, custom positioning and multiple screens
Sure you have the latest version?? Maybe a cache problem?htilburgs wrote:Rob, cannot get this to work.robgeerts wrote:Cure is also working now:
b00n
Maybe an idea to add spotify support in the amazing dash ?
An easy question... how can add a blocktitle like "Schakelaars woonkamer" ?
- Schermafbeelding 2017-05-04 om 20.53.00.png (242.09 KiB) Viewed 2378 times
- htilburgs
It's the beta from 1/2 hour ago. Cleared cache and tried several browsers. No result. Cannot trace where it comes from.robgeerts wrote:Sure you have the latest version?? Maybe a cache problem?htilburgs wrote:Rob, cannot get this to work.robgeerts wrote:Cure is also working now:
Hardware:
