Locked
robgeerts
Domoticz version: 3.7067
Re: Dashticz v2.0, custom positioning and multiple screens
Post by robgeerts »
mvveelen wrote:Not really sure how to use this:
I have three calendars, OK I can only use 2, so I use the 2 URL's for the 2 calendars I want to add in the 2 first URL's I can add.
But then the calendars.combined : what URL can I use in the calendars.combined.url in the case of an iCloud calendar? Just https://www.icloud.com/#calendar ?
Do you get any errors in console?
Although I havent tested it, in theory you can use 3 calendars with this code:
var calendars = {}
calendars.first = { icalurl: 'https://cors-anywhere.herokuapp.com/https://urlto.cal' }
calendars.second = { icalurl: 'https://cors-anywhere.herokuapp.com/https://urlto.cal' }
calendars.third = { icalurl: 'https://cors-anywhere.herokuapp.com/https://urlto.cal' }
calendars.combined = {}
calendars.combined.calendars = [
   { color:'white',calendar:calendars.first },
   { color:'#ccc',calendar:calendars.second },
   { color:'#ccc',calendar:calendars.third }
calendars.combined.url = 'https://www.icloud.com/#calendar';
mvveelen
Post by mvveelen »
Even bijkomen van de wedstrijd hoor :mrgreen:
I get this error when I use the calendars:
https://cors-anywhere.herokuapp.com/https://p03-calendarws.icloud.com/ca/subscribe/1/bknN4a2idziGc9c-aovFkgA-cut-nah7Lxm6Yof9Q
Failed to load resource: the server responded with a status of 421 (Misdirected Request)
Edit:
un-published the calendar and re-published the calendar. Got a new URL and that one works fine IF I use the calendars separately. The combined calendar doesn't show anything.
Error :
https://cors-anywhere.herokuapp.com/webcal://p49-calendars.icloud.com/published/2/hkmcyFxGuPN-cut-iOokHc
Failed to load resource: the server responded with a status of 404 (Invalid host)
htilburgs
Post by htilburgs »
robgeerts wrote:
TapNL wrote:
Would it be possible to add a wiki-file / how-to / readme for the extra's some users have made?
For instance:
- The waste calendar: how-to ad the switch, the contents of the lua script, etc.
- The moon add-on: what switches to add (and how), etc (nice, but not really sure HOW to add which switches etc).
- The calendar add-on (most recent)
- How to adjust the height (and witdh) of the traffic
- etc.
We can read this topic, but if it is in the package, then it would me much easier to maintain and find. Right?
I think this is a good idea, and are more then happy to contribute to this.
The way I imagine it is that we make per function as short description in the wiki and keep updating that.
If we create a trello board of functions that need to be fixed and functions that changed we can set this up quite easy.
@Rob: what do you think?
@Others: who wants to participate?
I just switched from Trello to the issue tracker of Github, for several reasons...
The wiki is already there, maintained by @htilburg. Everybody can participate to this wiki to expand the possibilities.
http://www.domoticz.com/wiki/Dashticz-v2
I've added today a page "Custom Applications" and made a start with "Moon Add-On".
Feel free to participate....;)
Hardware:
EdwinK
Post by EdwinK »
If only I knew how I got the 'Afvalwijzer' working, I would add it.
And.. You are my hero... Moon script is working again. Still not from an external script, but just from within the Lua editor in Domoticz.
htilburgs
Post by htilburgs »
I just have the moonphase working on my testdashboard, the wiki will be updated in 5 minutes.
Than I will start with the waste calendar. Hope I can help you. (Have to read all the pages).
Do you know how to center the moonphase image?? It's now at the left.
Hardware:
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
When I have time this weekend I will try to put description garbage calendar om the wiki
EdwinK
Post by EdwinK »
Not sure. But I might try and see. And just as I posted in a previous post, the moon script is working perfectly. :)
Moon
Moon
Screen Shot 2017-05-03 at 21.30.18.png (71.61 KiB) Viewed 1626 times
htilburgs
Post by htilburgs »
SwordFish wrote:When I have time this weekend I will try to put description garbage calendar om the wiki
:D
Hardware:
Derik
Post by Derik »
grrr
V2.o from github with gitclone. [ from the wiki ]
I do have:
a CONFIG.js
var _LANGUAGE 			= 'nl_NL'; //or: en_US, fr_FR, hu_HU
var _HOST_DOMOTICZ		  	= 'http://192.168.5.70:8080';
var _DOMOTICZ_REFRESH		= 5; //in seconds
var _DASHTICZ_REFRESH		= 10; //in minutes
var _HOST_ZIGGO_HORIZON	  	= ''; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND  	= '';
var _WEATHER_CITY 			= 'Nijmegen';
var _WEATHER_CITYNAME 		= ''; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY 		= 'NL';
var _USE_AUTO_POSITIONING 		= true; //don't want to configure positions, use auto positioning
var _USE_FAVORITES			= true; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK 		= false; //do not show the seconds in the clock
var _HIDE_MEDIAPLAYER_WHEN_OFF 	= false; //when you have a mediaplayer connected, hide it if nothing is playing
var _NEWS_RSSFEED			= 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT			= false;
var _USE_BEAUFORT 			= true; //Bft instead of m/s
var _TRANSLATE_SPEED 		= false; //windspeed, north northwest instead of NNW
var _STANDBY_AFTER_MINUTES  		= false; //enter amount of minutes like: 5 (5 minutes)
var _SCROLL_NEWS_AFTER 		= 7000; //milliseconds, so 7000 is 7 seconds
var _SHOW_LASTUPDATE 		= true;
var _LASTUPDATE_FORMAT 		= 'DD-MM-YY HH:mm';
var _SCREENSLIDER_EFFECT 		= 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip'
var _APIKEY_MAPS			= '';
var _MAPS_LATITUDE			= '';
var _MAPS_LONGITUDE			= '';
var _AUTO_SWIPEBACK_TO		= 1; //when no activity, swipe back to main screen after x seconds
var _AUTO_SWIPEBACK_TIME		= 10; //seconds
// Online Radio Stream Plugin, Note: you must enable  plugin in column section 'streamplayer', see columns[3]['blocks'] example below.
var _STREAMPLAYER_TRACKS  	= [
								{"track":1,"name":"Music FM","file":"http://stream.musicfm.hu:8000/musicfm.mp3"},
								{"track":2,"name":"Radio 1","file":"http://213.181.210.106:8000/high.mp3"},
								{"track":3,"name":"Test FM","file":"http://213.181.210.106:8000/high.mp3"},
// iCalendar Plugin, supports all .ics calendar types like Google Calendar, Apple Calendar
var _ICALENDAR_URL			= 'https://testurl.com/ical.ics'; //supports .ics type calendars (Google Calendar, Apple Calendar etc.)
var _ICALENDAR_DATEFORMAT		= 'friendly'; //'friendly', 'MM.DD.YYYY HH:mm', 'DD.MM.YYYY HH:mm', 'YYYY.MM.DD HH:mm'
var _ICALENDAR_LOCALE		= 'en'; //en,hu, etc.
//Buttons or images to open webpages in an iframe, like a news website or weather forecast
var buttons = {}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weeronline.nl/Europa/Nederland/Son/4058667'}
//CUSTOM POSITIONING:
//defining wich blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
var blocks = {}
blocks[1] = {}
blocks[1]['width'] = 4;
blocks[1]['title'] = 'Living room'
blocks[1]['icon'] = 'fa-eye';
blocks[1]['image'] = 'bulb_off.png';
blocks[204] = {5} //dimmer
blocks[204]['width'] = 12;
blocks[204]['title'] = 'Living room' //if you want change the name of switch different then domoticz
blocks['blocktitle_1'] = {test'}
blocks['blocktitle_1']['title'] = 'Schakelaars';
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['Tester_1',9,2,62,'144_2',204,248,295] //remark: idx 144 produces 2 blocks, so you can use: '144_1' and '144_2' (or of course, just 144 if you want one)
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather',5,'144_1']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise','horizon','streamplayer',buttons.buienradar,buttons.radio,buttons.calendar,buttons.nunl,buttons.nzbget]
columns[3]['width'] = 2;
//var columns_standby = {}
//columns_standby[1] = {}
//columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
//columns_standby[1]['width'] = 12;
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg1.jpg';
screens[1]['background_morning'] = 'bg_morning.jpg';
screens[1]['background_noon'] = 'bg_noon.jpg';
screens[1]['background_afternoon'] = 'bg_afternoon.jpg';
screens[1]['background_night'] = 'bg_night.jpg';
//screens[2] = {}
//screens[2]['background'] = 'bg3.jpg';
//screens[2]['background_morning'] = 'bg_morning.jpg';
//screens[2]['background_noon'] = 'bg_noon.jpg';
//screens[2]['background_afternoon'] = 'bg_afternoon.jpg';
//screens[2]['background_night'] = 'bg_night.jpg';
//screens[2]['columns'] = [4,5,6]
Without any Api because need to learn..
I do have:
Only no custom page with columns or blocks
So please where do i go wrong looks not so difficult....
Just the blank page is not what i was expecting... :roll: :roll:
Edit:
See now a error:
Check the domoticz adres and this is ok...
htilburgs
Post by htilburgs »
It's working great (that's why I'm going to make the wiki, because it's was not complete clear how-do-they-do-it).
My moon is not boxed and not centered...
Hardware:
htilburgs
Post by htilburgs »
Derik wrote:grrr
I do have:
a CONFIG.js
var buttons = {}
var blocks = {}
blocks[1] = {}
var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
var screens = {}
screens[1] = {}
//screens[2] = {}
I do have:
Edit:
See now a error:
I had the same issue today, after doing a git pull.
Seems that something went wrong, because I had the same issue. Looking into the problem, it seems that I didn't had an empty image (img) directory.
Copied my custom directory, renamed the dashboard folder to .org and did a new git clone.
Still no images and the same issue. After uploading the images from a backup, everything is Ok.
@Robgeerts, is there a possible issue with the github configuration?
Hardware:
EdwinK
Post by EdwinK »
I want your moon ;)
htilburgs
Post by htilburgs »
EdKo66 wrote:I want your moon ;)
It's default from the dashboard installation...
Hardware:
EdwinK
Post by EdwinK »
Derik wrote:grrr
Edit:
See now a error:
I noticed that you als get that error when there is something else wrong. When i make a typo in a part of a 'var' then it also gives that error.
Wheeling
Domoticz version: 3.5877
Post by Wheeling »
htilburgs wrote:
EdKo66 wrote:
htilburgs wrote:
Hi @htilburgs
Nice Dash
Can you share the iPhone script with us :)
I've been looking for it for a long time, but do not get it to work.
Thx
Bennie
htilburgs
Post by htilburgs »
Wheeling wrote:
htilburgs wrote:
EdKo66 wrote:
Hi @htilburgs
Nice Dash
Thx
Bennie
Just send you a PM....
Hardware:
robgeerts
Post by robgeerts »
htilburgs wrote:
Derik wrote:grrr
I do have:
a CONFIG.js
var buttons = {}
var blocks = {}
blocks[1] = {}
var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
var screens = {}
screens[1] = {}
//screens[2] = {}
I do have:
Edit:
See now a error:
I just pulled it from gitlab, renamed config-default.js to config.js. Then I only changed the domoticz path and worked like a charm....
Trigun
Domoticz version: 4.10717
Post by Trigun »
Hi All,
first of all, what a great dashboard!
Allthough it looks amazing, I am not able to get it working and I can't see where it goed wrong.
I changed the CONFIG-DEFAULT.js with my IP adress and saved it as CONFIG.js after putting all the files in www/dashticzv2 folder.
tried to open http://192.168.1.94:8080/dashticzv2 but get an 404 error.
Am I overlooking something??
thanks in advance!
robgeerts
Post by robgeerts »
Try calling index.html after it:
http://192.168.1.94:8080/dashticzv2/index.html
(otherwise Domoticz catches the request)
EdwinK
Post by EdwinK »
Trigun wrote:Hi All,
thanks in advance!
Perhaps you can share your CONFIG.js here. Are you sure the address is correct?
Locked
