Python plugin: Sony Bravia TV
Schuko80
Re: Python plugin: Sony Bravia [ready for test]
Post by Schuko80 »
Wow, it works now ... for all who have problems, the Problem was the opera browser, at the Computer it don't works with a old Version of Firefox, too - now i have used Firefox on Android and it works - nice plugin - thanks ;)
G3rard
Domoticz version: No
Post by G3rard »
Schuko80 wrote:Wow, it works now ... for all who have problems, the Problem was the opera browser, at the Computer it don't works with a old Version of Firefox, too - now i have used Firefox on Android and it works - nice plugin - thanks ;)
That's good to hear :D
Not using Domoticz anymore
G3rard
Post by G3rard »
markcame wrote: i have try to use localtest.py but i get response "[]" and i'm not able to read the real response, i think that actually the renew happens because the old cookie loses it's validity.
Can you also share localtest.py? Maybe I can help with the response part.
G3rard
Post by G3rard »
DarkFoxDK wrote:I've got a Sony Bravia KDL-46EX724, which is a couple of generations older than the ones supported by the plugin, however, it still does support IRCC codes, so I wonder what would be needed for at least partial support?
Have done some testing with my KDL-32EX720 and only IRCC commands are supported. So it's not possible to turn the TV on.
Also it's not possible to show what is being played.
So the only thing possible is to make a very simple version, where you can use a selector switch or the remote control to do some basic controls (volume, channel, HDMI input etc).
That would mean I have to make a new plugin for this kind of TV's. I can try to find some time to do that, but it has a low priority.
What IRCC functions do you want to control from Domoticz with this plugin?
And maybe we can use some info from this site.
G3rard
Post by G3rard »
EBOOZ wrote:This is awesome! I'll test the script this weekend :roll:
Already did some testing?
DarkFoxDK
Post by DarkFoxDK »
Unless you really feel like it, I wouldn't bother. I can just as easily use my current script with virtual switches and on/off actions. :)
G3rard
Post by G3rard »
DarkFoxDK wrote:Unless you really feel like it, I wouldn't bother. I can just as easily use my current script with virtual switches and on/off actions. :)
Are you able to switch the TV on with your script (using the wakeonlan part)? Then things are getting more interesting ;)
DarkFoxDK
Post by DarkFoxDK »
Sadly not.
markcame
Post by markcame »
on localtest.py i sinply added :
x.connect("0000" , "prova","prova1")
on the first run, then i pass the pin and run manually again and changing the code with
x.connect("3074" , "prova","prova1")
then the tv says device registered but in bravia.py the json.dumps give me error and i'n not able lo read the real response
pi@raspberrypi:~/domoticz/plugins/sony$ python3 localtest.py
  File "localtest.py", line 25, in <module>
  File "/home/pi/domoticz/plugins/sony/bravia.py", line 104, in connect
    Domoticz.Debug(json.dumps(response.json()))
AttributeError: 'bytes' object has no attribute 'json'
for now i have set a workaround i call with subprocess a bash script to renew the cookie but would be nice to obtain internally form the plugin
G3rard
Post by G3rard »
@markcame, yeah that is exactly the line I mentioned in an earlier post, which isn't changed and still depending on the requests module, where the other parts of the code are changed to use the urllib module (requests module is not working with the Python plugin).
Can you change
to
Domoticz.Debug(response)
and maybe comment out the next line starting with self._cookies because that is also still using the requests module part.
markcame
Post by markcame »
G3rard wrote:@markcame, yeah that is exactly the line I mentioned in an earlier post, which isn't changed and still depending on the requests module, where the other parts of the code are changed to use the urllib module (requests module is not working with the Python plugin).
Can you change
to
changing gime me
b'{"id":1,"result":[]}'
it seems still give null result
G3rard
Post by G3rard »
Just released a new version on https://github.com/gerard33/sony-bravia.
* Added remote control --> you can now use the remote control in Domoticz (next to the TV icon in the Status device), this can among others be used for volume up and down (will also work when you have an amplifier connected)
* Added channel number in playing information --> shows the channel number which is playing
* Some code cleanup
vgr2
Post by vgr2 »
I could see the remote control, but how should it be work? I could not see any response if i try it... do i have to do updates before
G3rard
Post by G3rard »
Update to the latest version of the plugin and then restart Domoticz.
vgr2
Post by vgr2 »
ok I will try it. Will it be also possible (for you) to have an connection to the integrated TV camaera?
G3rard
Post by G3rard »
Nope, the TV camera is not part of the interface I am using for the plugin.
vgr2
Post by vgr2 »
Remote control is working with latest version. Will it be possible to add the TV/Radio button to RC?
G3rard
Post by G3rard »
Yeah that's possible.
In plugin.py replace the following line
elif Command == "Channels": _tv.send_req_ircc("AAAAAQAAAAEAAAA6Aw==")        # Display
with
elif Command == "Channels": _tv.send_req_ircc("AAAAAgAAABoAAABXAw==")        # Tv_Radio
Then select the TV in the Hardware menu and press Update.
After that pressing the CH button can be used for TV/Radio.
You can of course change any of the other keys you would like to use for this.
vgr2
Post by vgr2 »
Could not find the line
in my plugin.py the line Looks like
elif Command == "Channels": _tv.send_req_ircc("AAAAAgAAABoAAABhAw==") # PopUpMenu
G3rard
Post by G3rard »
You're right, I already have an updated version where the CH button is representing the Info button of the TV remote.
But the line with Channels and ending with #PopUpMenu is the one you can replace.
