Python plugin: Sony Bravia TV
Re: Python plugin: Sony Bravia [ready for test]
Wow, it works now ... for all who have problems, the Problem was the opera browser, at the Computer it don't works with a old Version of Firefox, too - now i have used Firefox on Android and it works - nice plugin - thanks
- G3rard
- Target OS: -
- Domoticz version: No
That's good to hearSchuko80 wrote:Wow, it works now ... for all who have problems, the Problem was the opera browser, at the Computer it don't works with a old Version of Firefox, too - now i have used Firefox on Android and it works - nice plugin - thanks
Not using Domoticz anymore
- G3rard
- Target OS: -
Can you also share localtest.py? Maybe I can help with the response part.markcame wrote: i have try to use localtest.py but i get response "[]" and i'm not able to read the real response, i think that actually the renew happens because the old cookie loses it's validity.
- G3rard
- Target OS: -
Have done some testing with my KDL-32EX720 and only IRCC commands are supported. So it's not possible to turn the TV on.DarkFoxDK wrote:I've got a Sony Bravia KDL-46EX724, which is a couple of generations older than the ones supported by the plugin, however, it still does support IRCC codes, so I wonder what would be needed for at least partial support?
Also it's not possible to show what is being played.
So the only thing possible is to make a very simple version, where you can use a selector switch or the remote control to do some basic controls (volume, channel, HDMI input etc).
That would mean I have to make a new plugin for this kind of TV's. I can try to find some time to do that, but it has a low priority.
What IRCC functions do you want to control from Domoticz with this plugin?
And maybe we can use some info from this site.
- G3rard
- Target OS: -
Already did some testing?EBOOZ wrote:This is awesome! I'll test the script this weekend
Unless you really feel like it, I wouldn't bother. I can just as easily use my current script with virtual switches and on/off actions.G3rard wrote:Have done some testing with my KDL-32EX720 and only IRCC commands are supported. So it's not possible to turn the TV on.DarkFoxDK wrote:I've got a Sony Bravia KDL-46EX724, which is a couple of generations older than the ones supported by the plugin, however, it still does support IRCC codes, so I wonder what would be needed for at least partial support?
- G3rard
- Target OS: -
Are you able to switch the TV on with your script (using the wakeonlan part)? Then things are getting more interestingDarkFoxDK wrote:Unless you really feel like it, I wouldn't bother. I can just as easily use my current script with virtual switches and on/off actions.
Sadly not.G3rard wrote:Are you able to switch the TV on with your script (using the wakeonlan part)? Then things are getting more interestingDarkFoxDK wrote:Unless you really feel like it, I wouldn't bother. I can just as easily use my current script with virtual switches and on/off actions.
on localtest.py i sinply added :G3rard wrote:Can you also share localtest.py? Maybe I can help with the response part.markcame wrote: i have try to use localtest.py but i get response "[]" and i'm not able to read the real response, i think that actually the renew happens because the old cookie loses it's validity.
x.connect("0000" , "prova","prova1")
x.connect("3074" , "prova","prova1")
pi@raspberrypi:~/domoticz/plugins/sony$ python3 localtest.py
File "localtest.py", line 25, in <module>
File "/home/pi/domoticz/plugins/sony/bravia.py", line 104, in connect
Domoticz.Debug(json.dumps(response.json()))
AttributeError: 'bytes' object has no attribute 'json'
- G3rard
- Target OS: -
@markcame, yeah that is exactly the line I mentioned in an earlier post, which isn't changed and still depending on the requests module, where the other parts of the code are changed to use the urllib module (requests module is not working with the Python plugin).
Can you change
to
and maybe comment out the next line starting with self._cookies because that is also still using the requests module part.
Can you change
Domoticz.Debug(response)
changing gime meG3rard wrote:@markcame, yeah that is exactly the line I mentioned in an earlier post, which isn't changed and still depending on the requests module, where the other parts of the code are changed to use the urllib module (requests module is not working with the Python plugin).
Can you changetoCode: Select all
and maybe comment out the next line starting with self._cookies because that is also still using the requests module part.Code: Select all
b'{"id":1,"result":[]}'
- G3rard
- Target OS: -
Just released a new version on https://github.com/gerard33/sony-bravia.
* Added remote control --> you can now use the remote control in Domoticz (next to the TV icon in the Status device), this can among others be used for volume up and down (will also work when you have an amplifier connected)
* Added channel number in playing information --> shows the channel number which is playing
* Some code cleanup
* Some code cleanup
I could see the remote control, but how should it be work? I could not see any response if i try it... do i have to do updates before
- G3rard
- Target OS: -
Update to the latest version of the plugin and then restart Domoticz.
ok I will try it. Will it be also possible (for you) to have an connection to the integrated TV camaera?
- G3rard
- Target OS: -
Nope, the TV camera is not part of the interface I am using for the plugin.
Remote control is working with latest version. Will it be possible to add the TV/Radio button to RC?
- G3rard
- Target OS: -
Yeah that's possible.
In plugin.py replace the following line
with
Then select the TV in the Hardware menu and press Update.
After that pressing the CH button can be used for TV/Radio.
You can of course change any of the other keys you would like to use for this.
elif Command == "Channels": _tv.send_req_ircc("AAAAAQAAAAEAAAA6Aw==") # Display
elif Command == "Channels": _tv.send_req_ircc("AAAAAgAAABoAAABXAw==") # Tv_Radio
Could not find the line
in my plugin.py the line Looks like
elif Command == "Channels": _tv.send_req_ircc("AAAAAgAAABoAAABhAw==") # PopUpMenu
- G3rard
- Target OS: -
You're right, I already have an updated version where the CH button is representing the Info button of the TV remote.
But the line with Channels and ending with #PopUpMenu is the one you can replace.
