Sonoff Touch Topic is solved
Eddiever
Domoticz version: 2022.1
Sonoff Touch
Post by Eddiever »
I have a Sonoff Touch wall switch. I would like to change it's firmware through ESP Easy. I have been searching but haven't found the right firmware. Due to the fact it is using the 8285 chip instead of 8266.
Does anyone have a suggestion?
mayyam
Domoticz version: 4.11333
Re: Sonoff Touch
Post by mayyam »
_______________
- Dell FX-160 / Ubuntu 16.04
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
Eddiever
Re: Sonoff Touch
Post by Eddiever »
mayyam, thanks. I just flashed it. Now to replace it with the active touch which is in normal use. But do I cut the power or should I just replace the circuitboard with the wiring still alive? Just kidding, always with the power off.
Eddiever
Re: Sonoff Touch
Post by Eddiever »
As I stated before I am very new and trying things out. Flashing worked. I can activate the ligth by hardware switch and from Domoticz. But somehow (I really don't know why) if I switch it manually the status in Domoticz won't change. Used some info from sincze
Switch 1.PNG (18.07 KiB) Viewed 8696 times
switch 2.PNG (18.01 KiB) Viewed 8696 times
On action Domoticz:
http://192.168.1.160/control?cmd=GPIO,12,1
I could really use some help. Who can?
mayyam
Re: Sonoff Touch
Post by mayyam »
That's my config.
And I also use Rules:
on System#Boot do
    gpio,12,1
    timerSet,1,1
  endif
endon
on Rules#Timer=1 do
    gpio,12,0
endon
on button#state do
  if [button#state]=1
    gpio,12,1
    endif
endon
on button#state do
  if [button#state]=0
    gpio,12,0
    endif
endon
devices_2_2017-04-23 20_48_50-sonoff_touch_lazienka.png (16.77 KiB) Viewed 8696 times
devices_1_2017-04-23 20_48_27-sonoff_touch_lazienka.png (15.08 KiB) Viewed 8696 times
_______________
- 2x Xiaomi Gateway
Eddiever
Re: Sonoff Touch
Post by Eddiever »
Sorry mayyam, thought the code was from sincze.
Even if I set it up exactly like your example the state doesn't change within Domoticz. The IDX variable was wrong in my case. In Domoticz it has the value of 3. I changed that in both ESP devices.
From Domoticz:
What kind of stupid thing I am overlooking?
mayyam
Re: Sonoff Touch
Post by mayyam »
On ESPEasy, in button device You have to give idx of realay device in domoticz and check "Send data" chceck box.
_______________
- 2x Xiaomi Gateway
Eddiever
Re: Sonoff Touch
Post by Eddiever »
sonoff touch 1.PNG (6.55 KiB) Viewed 8682 times
esp 1.PNG (9.43 KiB) Viewed 8682 times
Changed it to 3 but still no state change when manually switched
mayyam
Re: Sonoff Touch
Post by mayyam »
Do You have "Send data" checked?
Also On Config tab: Protocol, Controller IP and Controller Port - do You have right values ?
_______________
- 2x Xiaomi Gateway
Eddiever
Re: Sonoff Touch
Post by Eddiever »
Switch 1.PNG (17.98 KiB) Viewed 8680 times
switch 2.PNG (18.01 KiB) Viewed 8680 times
mayyam
Re: Sonoff Touch
Post by mayyam »
And the Config tab?
_______________
- 2x Xiaomi Gateway
Eddiever
Re: Sonoff Touch
Post by Eddiever »
The config:
mayyam
Re: Sonoff Touch
Post by mayyam »
If Your Domoticz server is 192.168.1.200, and port is 8080 it looks right to me.
_______________
- 2x Xiaomi Gateway
Eddiever
Re: Sonoff Touch
Post by Eddiever »
My server is indeed on 192.168.1.200 and the port is 8080. Thus it is strange :(
8080 is the default port, right?
mayyam
Re: Sonoff Touch
Post by mayyam »
Right.
I Have no Domoticz password, so my Controller User and Controller Pass fields are empty, but maybe You have to fill them ?
_______________
- 2x Xiaomi Gateway
Eddiever
Re: Sonoff Touch
Post by Eddiever »
Oh mayyam, how great (and stupid of me). That is it. Username/password. Darn me.
Thank you so much for your quick reply and help!
mayyam
Re: Sonoff Touch
Post by mayyam »
Try Rules. With Rules if Wifi will crash, Sonoff Touch will still work. Also, there is no latency when You switch it manually with Rules.
on button#state do
if [button#state]=1
gpio,12,1
endif
endon
on button#state do
if [button#state]=0
gpio,12,0
endif
endon
I've also that rule:
on System#Boot do
gpio,12,1
timerSet,1,1
endif
endon
on Rules#Timer=1 do
gpio,12,0
endon
It's for telling me (one second blink) that there is power back if the electric company fu..ed up again.
_______________
- 2x Xiaomi Gateway
Eddiever
Re: Sonoff Touch
Post by Eddiever »
I have copied your rules and used them ;)
Great to know Rules in combination with actions if wifi is out. Will dive into that later on.
mayyam
Re: Sonoff Touch
Post by mayyam »
You can also use the GPIO - 13 on the Wifi Status Led on the Hardware settings.
_______________
- 2x Xiaomi Gateway
Eddiever
Re: Sonoff Touch
Post by Eddiever »
Already done that:
on System#Boot do
gpio,12,1
gpio,13,0
timerSet,1,1
endif
endon
on Rules#Timer=1 do
gpio,12,0
gpio,13,1
endon
on button#state do
if [button#state]=1
gpio,12,1
gpio,13,0
endif
endon
on button#state do
if [button#state]=0
gpio,12,0
gpio,13,1
endif
endon
