I installed a new sd-card for my raspberry 2 with raspian jessie
I did a Clean install of domoticz
And then I installed de Nefit Easy server (https://www.domoticz.com/wiki/NefitEasy)
I think everything is OK
│ Name │ mode │ status │ ↺ │ cpu │ memory │
│ nefiteasyhttpserver │ fork │ online │ 426 │ 0% │ 2.3 MB │
In Domotcz I add new hardware -> Nefit easy http server over lan interface
I used this settings
Remote address: 127.0.0.1
poort: 3000
After this I expected new devices but nothing appears
In the logging I see errors
2017-01-06 14:43:38.467 Error: NefitEasy: Invalid data received! (Press)
017-01-06 14:46:59.263 Error: NefitEasy: Invalid data received! (Gas)
2017-01-06 14:47:09.536 Error: NefitEasy: Invalid data received (main)!
What is going wrong or did I missed Something??
Nefit Easy not so Easy
jannl
- Domoticz version: 2025.5.x
Re: Nefit Easy not so Easy
Did you try restarting Domoticz?
- gjaa
[quote][/quote]
A couple of times but doesn't work
I was thinking my thermostat is using the guest network in my house and Domoticz isn't
They are both in a different IP-network can that be the problem?
- jvdz
- Domoticz version: 4.107
That will be a problem when the IP traffic isn't routed between those 2 networks. That is something to check on your router, or simply connect your PC/mobile to the guest network and see if you can reach the domoticz server.gjaa wrote:I was thinking my thermostat is using the guest network in my house and Domoticz isn't
Jos
pepijn
The easy server will connect to the Bosch servers and not directly to the thermostat.jvdz wrote:That will be a problem when the IP traffic isn't routed between those 2 networks. That is something to check on your router, or simply connect your PC/mobile to the guest network and see if you can reach the domoticz server.gjaa wrote:I was thinking my thermostat is using the guest network in my house and Domoticz isn't
Jos
Does the Netfit CLI works correctly?
https://github.com/robertklep/nefit-easy-cli
- gjaa
I let the wifi connect to the guest network and the utp to the other so now it connect to both networks.That will be a problem when the IP traffic isn't routed between those 2 networks. That is something to check on your router, or simply connect your PC/mobile to the guest network and see if you can reach the domoticz server.
I reboot te pi and the the problems are not solved.
Is there a possibility to check on the commandline if the server is working correctly
- gjaa
Thanks I found the solutionDoes the Netfit CLI works correctly?
I had a wrong character in my password I used an exclamation ("!")
Changed the password and its working now
- jvdz
Ah .. that makes sense.... sneaking out of this thread again..pepijn wrote: The easy server will connect to the Bosch servers and not directly to the thermostat.
Jos
igorwolsink
pm2 start /home/pi/nefiteasyhttpserver.sh
[PM2] Applying action restartProcessId on app [nefiteasyhttpserver](ids: 0)
[PM2] [nefiteasyhttpserver](0) ✓
[PM2] Process successfully started
│ nefiteasyhttpserver │ fork │ stopped │ 16 │ 0% │ 0 B │
Use `pm2 show <id|name>` to get more details about an app
this is what i get.. some one can help me out ?
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
