Nefit Easy not so Easy
gjaa
Post by gjaa »
I installed a new sd-card for my raspberry 2 with raspian jessie
I did a Clean install of domoticz
And then I installed de Nefit Easy server (https://www.domoticz.com/wiki/NefitEasy)
I think everything is OK
│ Name │ mode │ status │ ↺ │ cpu │ memory │
│ nefiteasyhttpserver │ fork │ online │ 426 │ 0% │ 2.3 MB │
In Domotcz I add new hardware -> Nefit easy http server over lan interface
I used this settings
Remote address: 127.0.0.1
poort: 3000
After this I expected new devices but nothing appears
In the logging I see errors
2017-01-06 14:43:38.467 Error: NefitEasy: Invalid data received! (Press)
017-01-06 14:46:59.263 Error: NefitEasy: Invalid data received! (Gas)
2017-01-06 14:47:09.536 Error: NefitEasy: Invalid data received (main)!
What is going wrong or did I missed Something??
jannl
Domoticz version: 2025.5.x
Re: Nefit Easy not so Easy
Post by jannl »
Did you try restarting Domoticz?
gjaa
Post by gjaa »
[quote][/quote]
A couple of times but doesn't work
I was thinking my thermostat is using the guest network in my house and Domoticz isn't
They are both in a different IP-network can that be the problem?
jvdz
Domoticz version: 4.107
Post by jvdz »
gjaa wrote:I was thinking my thermostat is using the guest network in my house and Domoticz isn't
That will be a problem when the IP traffic isn't routed between those 2 networks. That is something to check on your router, or simply connect your PC/mobile to the guest network and see if you can reach the domoticz server.
Jos
pepijn
Post by pepijn »
Jos
The easy server will connect to the Bosch servers and not directly to the thermostat.
Does the Netfit CLI works correctly?
https://github.com/robertklep/nefit-easy-cli
gjaa
Post by gjaa »
I let the wifi connect to the guest network and the utp to the other so now it connect to both networks.
I reboot te pi and the the problems are not solved.
Is there a possibility to check on the commandline if the server is working correctly
gjaa
Post by gjaa »
Thanks I found the solution
I had a wrong character in my password I used an exclamation ("!")
Changed the password and its working now :D
jvdz
Post by jvdz »
pepijn wrote: The easy server will connect to the Bosch servers and not directly to the thermostat.
Ah .. that makes sense.... sneaking out of this thread again.. :)
Jos
igorwolsink
Post by igorwolsink »
pm2 start /home/pi/nefiteasyhttpserver.sh
[PM2] Applying action restartProcessId on app [nefiteasyhttpserver](ids: 0)
[PM2] [nefiteasyhttpserver](0) ✓
[PM2] Process successfully started
│ nefiteasyhttpserver │ fork │ stopped │ 16 │ 0% │ 0 B │
Use `pm2 show <id|name>` to get more details about an app
this is what i get.. some one can help me out ?
