Python Plugin: Broadlink RM2
plaaggeest
Re: Python Plugin: Broadlink RM2
Post by plaaggeest »
deennoo wrote:Just test on debian, Domoticz looks lib at
/usr/local/lib/python3.4/dist-packages/
this mean you need to install python who is used for domoticz
sudo apt-get install python3-pip libglib2.0-dev
sudo pip3 install Crypto
sudo pip3 install broadlink
When done, you have to copy lib on the good dir :
sudo cp -r /usr/local/lib/python3.4/dist-packages/Crypto/ /usr/lib/python3.4/
sudo cp -r /usr/local/lib/python3.4/dist-packages/broadlink /usr/lib/python3.4/
Then restart domoticz en enjoy !
sudo service domoticz restart
@zak45 maybe you can update your wiki with this thank you for this great plugin !
when did you release the one for Orange Box ? ahrd to transforme to freebox revolution ?
runs without any problems, but when I perform
I receive the following error:
sudo pip3 install broadlink     Downloading/unpacking broadlink
  Downloading broadlink-0.4.tar.gz
  Running setup.py (path:/tmp/pip-build-8kfdo1wo/broadlink/setup.py) egg_info for package broadlink
      File "<string>", line 17, in <module>
      File "/tmp/pip-build-8kfdo1wo/broadlink/setup.py", line 12
        except ImportError, e:
    SyntaxError: invalid syntax
    Complete output from command python setup.py egg_info:
Cleaning up...
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-8kfdo1wo/broadlink
Storing debug log for failure in /root/.pip/pip.log
I am a noob and cant tell what the issue is. Some able to help me out?
jlites00
Post by jlites00 »
CODE: SELECT ALL
Cleaning up...
I'm having the same problem. I tried installing Python 3.5 . Still the same issue.
deennoo
Re: RE: Re: Python Plugin: Broadlink RM2
Post by deennoo »
zak45 wrote:Hi,
there is no way to do that in oneshot for all devices.
On the next release, you should be able to put device off by using Domoticz param:
You have to create à pushon button
http://domo-attitude.fr
lonwan
Post by lonwan »
Cleaning up...
I have the same problem!! And I also tried install Python 3.5, the problem did not disappear. I ask for help!
zak45
Domoticz version: V2024.4
Post by zak45 »
This is not due to python version but to broadlink version. Actual version 0.4 had compatibility problem, hope should be solved soon.
in the meantime, see there:
https://www.domoticz.com/forum/viewtopi ... 4&start=20
lonwan
Post by lonwan »
Thanks, i'll try it today
plaaggeest
zak45 wrote:This is not due to python version but to broadlink version. Actual version 0.4 had compatibility problem, hope should be solved soon.
Alright, got the broadlink installed via above comment. Thank you!
Copied the plugin files to the created folder.
Created the Broadlink Hardware with IP+Mac. But still have python issues:
2017-04-28 12:52:28.495 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/BroadlinkRM2/:/usr/local/lib/python35.zip:/usr/local/lib/python3.5/:/usr/local/lib/python3.5/plat-linux:/usr/local/lib/python3.5/lib-dynload'.
2017-04-28 12:52:28.495 Error: (Broadlink) Module Import failed, exception: 'ImportError'
2017-04-28 12:52:28.495 Error: (Broadlink) Module Import failed: ' Name: broadlink'
2017-04-28 12:52:40.754 Hardware Monitor: Fetching data (System sensors)
2017-04-28 12:52:46.349 (Nest) Thermostat (Thermostaat)
2017-04-28 12:52:46.350 (Nest) Temp + Humidity (Beneden)
2017-04-28 12:53:10.790 Hardware Monitor: Fetching data (System sensors)
2017-04-28 12:53:16.924 (Nest) Thermostat (Thermostaat)
2017-04-28 12:53:16.926 (Nest) Temp + Humidity (Beneden)
2017-04-28 12:53:21.504 (433 Receiver) Temp + Humidity (Boven)
2017-04-28 12:53:30.239 Error: Broadlink hardware (13) thread seems to have ended unexpectedly
Any ideas what this could be?
zak45
Post by zak45 »
maybe this :
you need to adapt to your configuration
lonwan
Post by lonwan »
zak45 wrote:
maybe this :
Made on your last post, installed version 0.3 (Successfully installed broadlink-0.3 pycrypto-2.6.1), but in the directory /usr/local/lib/python3.4/dist-packages/ there is no broadlink folder
As a result, I again have a snag. What am I doing wrong?
zak45
Post by zak45 »
lonwan wrote:
zak45 wrote:
maybe this :
do you have mixed python version i.e 2.7.x & 3.x ?
lonwan
Post by lonwan »
zak45 wrote: do you have mixed python version i.e 2.7.x & 3.x ?
yes, 2.7 and 3.4, and I tried to install 3.5.
What can I do to make it work?
zak45
Post by zak45 »
your default python env should be 2.7, this made problem.
you should use pip3 command for each installation.
lonwan
Post by lonwan »
zak45 wrote: your default python env should be 2.7, this made problem.
I use pip3 command, But the folder "broadlink" appears in the /usr/local/lib/python3.5/site-packages.
I copied the folder "broadlink" in /usr/local/lib/python3.4/dist-packages/broadlink and /usr/lib/python3.4/
And restarted the service:
sudo systemctl restart domoticz.service
But I still get an error in the log, I'm clearly doing something wrong:
2017-04-29 13:47:54.340 Error: PluginList: Error 'Error document empty.' at line 0 column 0 in XML ''.
2017-04-29 13:47:56.847 (Broadlink) Stopped.
2017-04-29 13:47:57.047 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/BroadlinkRM2/:/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
2017-04-29 13:47:57.047 Error: (Broadlink) Module Import failed, exception: 'ImportError'
2017-04-29 13:47:57.047 Error: (Broadlink) Module Import failed: ' Name: Crypto'
and:
2017-04-29 13:53:00.767 Error: Broadlink hardware (10) thread seems to have ended unexpectedly
P.S.:
I finally realized my mistake. I copied the folder "Crypto" :
sudo cp -r /usr/local/lib/python3.5/site-packages/Crypto /usr/local/lib/python3.4/dist-packages
I restarted the service and I had a temperature sensor and a remote in the switches section! Now it works! Thanks a lot for your help, zak45.
Just want to say that the team
Python3 --version
Gives out:
Python 3.5.3
But the team
Sudo apt-get remove python3
Issue a delete request:
Libpython3.4 libpython3.4-dev python3.4-dev
What does it mean? Do I have python3.4 and python3.5.3 on the same system?
zak45
Post by zak45 »
@lonwan
nice to see it's work ;-)
yes, you can have various python version installed on the same system. Could be necessary as some script work only with 2.7.x some other with 3.x etc ...
reza
Domoticz version: 2024.4
Post by reza »
hi. i want test it with windows. i run setup.exe but after install dont add broadlink in hardware.
reza
Post by reza »
reza
Post by reza »
also for raspberry i want use stable version. can i use this for stable version ?
zak45
Post by zak45 »
reza wrote:also for raspberry i want use stable version. can i use this for stable version ?
yes , can be used from plugin POV but need beta Domoticz version... worked at home since many weeks without trouble.
And for installation problem please read wiki and forum, lot's of informations has been provided.
reza
Post by reza »
i want just use stable version 3.5877 (because i did some change in domoticz and i dont want update this). so can you help me for run this on 3.5877 version ?
i need this plugin very :(
zak45
Post by zak45 »
reza wrote:i want just use stable version 3.5877 (because i did some change in domoticz and i dont want update this). so can you help me for run this on 3.5877 version ?
Sorry , this need domoticz v3.7xxx or better.
