framb0ise v2 - awesome new dashboard!
safi78
- Domoticz version: LastBeta
Re: framb0ise v2 - awesome new dashboard!
Please add bug-reports, instead of here in the forum.Maikie wrote:Cannot open the setting anymore
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
andi216
- Domoticz version: 3.7243
Thank you very much for update the camera. It works very well.
safi78
NPandi216 wrote:Thank you very much for update the camera. It works very well.
marcotrumpet
Hi, no screen settings appear to me. and nothing appen if I click on settings icon on top right
safi78
https://github.com/safi78/framb0ise/issuesmarcotrumpet wrote:Hi, no screen settings appear to me. and nothing appen if I click on settings icon on top right
- jvdz
- Domoticz version: 4.107
Please give the current version a try as I have added the basic support for all Blinds types, but don't have all devices available for testing so don't know whether the directions are right and possibly are requiring a stop button.jvdz wrote:I am sure you'll be able to figure this out when looking at the change I made what needs to be done.tontze wrote: Blinds still dotn have control over it, i have "blinds inverted" control![]()
I don't have any inverted blinds to test with.
Jos
Jos
kniazio
My cams not visible
my cams is:
http://192.168.1.161:8085/snapshot
http://192.168.1.162:8086/snapshot
my cams is:
- framb2.jpg (215.72 KiB) Viewed 5555 times
- framb1.jpg (191.52 KiB) Viewed 5555 times
- jvdz
Post an issue in GITHUB when you have an issue to report: https://github.com/safi78/framb0ise/issueskniazio wrote:My cams not visible
.. and don't forget to post the DOMOTICZ config details of one of the camera's so it can be checked what the root cause could be.
Jos
tontze
- Domoticz version: Beta Ch
Nice ! Works fine. THNX ! But another thing came up, in one roomplan all doubled ? :jvdz wrote:Please give the current version a try as I have added the basic support for all Blinds types, but don't have all devices available for testing so don't know whether the directions are right and possibly are requiring a stop button.jvdz wrote:I am sure you'll be able to figure this out when looking at the change I made what needs to be done.tontze wrote: Blinds still dotn have control over it, i have "blinds inverted" control![]()
Jos
Jos
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- jvdz
Please post your issue in GITHUB so we can keep track of them: https://github.com/safi78/framb0ise/issues
In this case add the result of the following url so we can see which device are defined in the room:
http://192.168x.x:8080/json.htm?type=co ... vices&idx=1
Change the red number in that request to the correct roomnumber and of course the appropriate IP:PORT.
Jos
Jos
safi78
Hi Guys,
Just released a new version (we are now working in 2 branches, master & development).
New functionality will be added to the development-branche first, tested & then released.
New stuff:
1. Option to save settings to Domoticz or just local. (credits: jvdz) This is very nice if you have more devices, e.g. laptop & iPad. You can configure framb0ise on your laptop (easier) and later import these settings on your iPad so you don't have to fiddle around with the small keyboard
Also, this can keep your settings synchronized throughout all your devices.
You can always choose to store settings locally if you want variations in your settings on a 'per device'-basis.
Because this is a great overhaul of the settings-store function, if you run into problems from a previous version, just clear your local cache / remove localStorage stuff, framb0ise will 'kick in' from there.
Try it out, let us know what you think!
2. Weather Widget (Darksky) with weekly-predication. Hover your mouse over the 'title' of the widget to see the temp-predictions for the next week.
I chose to go for this approach, to keep the widget clean & tidy, but the extra information is there on demand. Check it out, let me know if you like it
3. Weathermap Widget (Buienradar) rain prediction. If rain is predicted, the title will turn to 'orange' as a warning, and tell you the 'from' and 'to' times to bring an umbrella.
This is based on your latitude / longitude location from domoticz, so make sure these are accurate for you to give you the best experience.
As always:
1. Feedback is very welcome in this thread
2. Bugs & Feature requests are only picked up from: https://github.com/safi78/framb0ise/issues
Please, send the bugs / requests to meantioned url, this is so much easier to keep track, in stead of PM's or in this thread.
New stuff:
As always:
Maikie
Is it as designed or a bug that device with a $ in front don't show up in framb0ise anymore?
safi78
Designed. And it's not 'anymore', it was actually 'never'Maikie wrote:Is it as designed or a bug that device with a $ in front don't show up in framb0ise anymore?
We follow Domoticz 'guidelines'. $ is intended to make rooms hidden in the GUI and so it works in framb0ise, like it says in the instructions:
# How to order stuff around
Everything is based on the 'room-plan' inside domoticz.
So if you change the order of the rooms, or the order of the devices in that rooms, framb0ise will use that accordingly.
If you don't want a room to show up in framb0ise, but don't want to delete it in domoticz either, just add a '$' to the room name in domoticz. This will 'hide' the room. (I use this for my homebridge stuff for example.)
Maikie
Strange because it worked for me until I just updated again. To be clear, I don't mean $in front of a room name but in front of devices.safi78 wrote:Designed. And it's not 'anymore', it was actually 'never'Maikie wrote:Is it as designed or a bug that device with a $ in front don't show up in framb0ise anymore?![]()
safi78
I see,Maikie wrote:Strange because it worked for me until I just updated again. To be clear, I don't mean $in front of a room name but in front of devices.safi78 wrote:Designed. And it's not 'anymore', it was actually 'never'Maikie wrote:Is it as designed or a bug that device with a $ in front don't show up in framb0ise anymore?![]()
hmm, dunno, my first code didn't do anything specific with $devices. Coulde be that it worked then. After that jvdz added some more clever stuff to fix the order of things, maybe he filtered out the $devices.
In any case, my opinion is that is works like it should be, $ = hidden. Agree?
andi216
In Settings you can add a Iframe empty url for various?
- Screenshot_2017-04-30-09-16-56-1.jpg (86.52 KiB) Viewed 5418 times
bimse
- Domoticz version: Model 3
andi216 wrote:Hi,
How did you get this great weather system
Translated with google
bimse
I like the simple way the system is built, but, my eyes seemed essential as it's results, is a bit small.
How can I highlight, temperature, wind and ppm as well as all the other results.
How do I convert km/h to m/s
