sonar
- Domoticz version: 3.8153
Re: Dashticz v2.0, custom positioning and multiple screens
After todays pull the up and down arrow of my blinds are positioned on top of eachother.
Dropshot
I had the same issue for my second screen, but it works on my first screen. Did you also place it on another screen?pkrabben wrote:Same issue tried it also on a new device without any history opening this dashboardrobgeerts wrote:What if you clear your browser cache?pkrabben wrote:for some reason my Graph and traffic map are not working
var _APIKEY_MAPS = 'AIzaSyCRgdUxmbzhMPyWAudqbQoaI1HmHZMWP7E'; var _MAPS_LATITUDE = 52.353472; var _MAPS_LONGITUDE = 5.181684;Before the update of yesterday my graph was workingCode: Select all
columns[4] = {} columns[4]['blocks'] = ['blocktitle_5','trafficmap','traffic','news'] columns[4]['width'] = 5;
Does any body have any clue or suggestion
Edit: I still get an error though: "You have included the Google Maps API multiple times on this page. This may cause unexpected errors."
I have it only on my first screen now..
robgeerts
- Domoticz version: 3.7067
In latest version, you can add the following variable in config.js:sonar wrote:It would be nice if the start zoom level for the trafficmap would also be a variable.
var _MAPS_ZOOMLEVEL = 10;
New version works excellent.
I can help you with some items of the "new features" column on your Trello board, but unfortunately I am full off work. Maybe I can work on some features on the weekend.
The best would be to work on selector (instead of dropdown), but at this time I have no idea for smaller screens.
sonar
Found two more issues/bugs.
Firstly I've noticed some strange behaviour when using multiple screens.
In my setup I've got two screens defined. On my second screen there is a graph and a traffic map.
If I open the second screen either sliding or using arrow key it doesn't work when moving to the right. If I move to the left the graph and trafficmap are working fine.
Right: Left: Secondly if I open the graphs of a energy button it opens fine but if I choose day/month/year the graph has some strange behaviour.
With every click on the buttons the graph adds another part to the graph.
- EdwinK
- Domoticz version: BETA
I believe all the graph's have that problem. Noticed it earlier today.sonar wrote: Secondly if I open the graphs of a energy button it opens fine but if I choose day/month/year the graph has some strange behaviour.
robgeerts
I hate the graph functionality of Domoticz!
Its just not logic... but will check things again...
- mvveelen
sonar
The graphs placed on the screen are working as expected. The problems only occur on the popup when clicking the energy buttons.robgeerts wrote:I hate the graph functionality of Domoticz!
- EdwinK
Also with wind an room temp, as far as I can see, and my up/download and ping graphs, but those are not importantsonar wrote:The graphs placed on the screen are working as expected. The problems only occur on the popup when clicking the energy buttons.robgeerts wrote:I hate the graph functionality of Domoticz!
- mvveelen
Trafficmap (Google maps) doesn't work for me too. I added a new API key:
And added it to the dashboard:
But nothing appears on the screen, except an empty space.
Am I forgetting something?
var _APIKEY_MAPS = 'AIzaSyCnBcu1WnewiNuNo94NTRuCoc0FUC_9fa8'; // this isn't my real API key of course
columns[4] = {}
columns[4]['blocks'] = ['blocktitle_5','trafficmap','news_2']
Ierlandfan
It works for me, but i did a fresh git clone around 13: 00 or so and copied my custom code in the new files.
I still use the one with the no variable zoom, besides that my graphs aren't working.
robgeerts
With your api key, I get the error the key is not valid...mvveelen wrote:Trafficmap (Google maps) doesn't work for me too. I added a new API key:
And added it to the dashboard:Code: Select all
var _APIKEY_MAPS = 'AIzaSyCnBcu1WnewiNuNo94NTRuCoc0FUC_9fa8'; // this isn't my real API key of course var _MAPS_LATITUDE = 52.353472; var _MAPS_LONGITUDE = 5.181684;
But nothing appears on the screen, except an empty space.Code: Select all
columns[4] = {} columns[4]['blocks'] = ['blocktitle_5','trafficmap','news_2'] columns[4]['width'] = 5;
- mvveelen
Well, this is not my api key
I'll send you the key via PM
- EdwinK
What API-key do you use? Google has several for their maps.
- mvveelen
I obtained it from here:EdKo66 wrote:What API-key do you use? Google has several for their maps.
https://developers.google.com/maps/docu ... et-api-key
- EdwinK
Thanks.
robgeerts
Thanks for the key, I tested it and works correctly!
Are you able to open the dashboard on another device?
Do you really have the latest version?
- mvveelen
I downloaded it 1,5 hour ago. I tried it in another browser and also on my iPhone, same result.
b00n
Same problem here
