I also got same screen when i had https in config.js and i have https disabled, changed it to http, and worked after thatsafi78 wrote:Si.Maikie wrote: I only see info at the moment but that is because I don't have rooms setup I guess?
That's how it works for 'now'.Maikie wrote:Changed to http and then it works.
See 1 problem in my test room, there are 2 humidity/temp sensors, but its showing comfortable and not the temperature or the humidity.
Blinds still dotn have control over it, i have "blinds inverted" controljvdz wrote:I had a try today as well and really like this approach!tontze wrote: But, on my setup, blinds just shows its tate, no control buttons![]()
I've made a fix for the Blinds as I saw the same thing and this also takes the device.MaxDimLevel into account to avoid getting a percentage problem.
Just edit framboise.js and replace/insert these lines:@safi78, maybe you can update your version or do you want me to create a pull request? (I am new to git, but used to CVS/SVN)Code: Select all
case "Dimmer": if (device.Data == 'Off') { switchClass = 'btn btn-success btn-primary glyphicon glyphicon-off active'; } else { switchClass = 'btn btn-warning btn-primary glyphicon glyphicon-off active'; } $("#td-" + device.idx).html('<div class="slider-div"><input type="text" id="slider-' + device.idx + '" data-slider-value="' + device.LevelInt + '" data-slider-min="0" data-slider-max="' + device.MaxDimLevel + '" data-slider-tooltip="hide" /> <button class="'+switchClass+'" Onclick="switchLight(' + device.idx + ')"></button></div>'); $("#slider-" + device.idx).slider(); $("#slider-" + device.idx).on("slideStop", function(slideEvt) { setDimmer(device.idx, slideEvt.value); }); break; case "Blinds Percentage": if (device.Data == 'Open') { switchClass = 'btn btn-success btn-primary glyphicon glyphicon-off active'; } else { switchClass = 'btn btn-warning btn-primary glyphicon glyphicon-off active'; } $("#td-" + device.idx).html('<div class="slider-div"><input type="text" id="slider-' + device.idx + '" data-slider-value="' + device.LevelInt + '" data-slider-min="0" data-slider-max="' + device.MaxDimLevel + '" data-slider-step="1" data-slider-tooltip="hide" /> <button class="'+switchClass+'" Onclick="switchLight(' + device.idx + ')"></button></div>'); $("#slider-" + device.idx).slider(); $("#slider-" + device.idx).on("slideStop", function(slideEvt) { setDimmer(device.idx, slideEvt.value); }); break; case "Motion Sensor":
Jos
I am sure you'll be able to figure this out when looking at the change I made what needs to be done.tontze wrote: Blinds still dotn have control over it, i have "blinds inverted" control
Enjoy the latest update thenrickvanakkeren wrote:I really like the simplicity of your dashboard and the way I can group information.
But... in Dashticz I can add some other nice things, like ´buienradar´, traffic info, sunset/sunrise.
For me, combining these two would be the best solution! So I'm gonna try to add this in Framb0ise, but maybe I need some help![]()
A big thanks to jvdz for adding Scenes and Groups!jvdz wrote:@safi78,
Guess this setup is becoming quite popular.
Adding the slash after the url is indeed now working, but thought I tried that in the beginning as well... not important now.
I noticed that the script is not filtering the scene in the rooms and assumes they are device idx'es. I have scene in rooms as the DTGMENU setup is using the same approach as your web front-end and using the room definitions for the telegram inline menu structure. So I have quite some SCENEs/GROUPs defined in them which are showing now obviously strange information.
How do you feel about this? Should they be filtered out or should there be support for SCENE's/Groups like in the regular frontend?
Jos
Hi Henry,henrivb wrote:Hi, I installed it and it looks really nice. One question: I have created a roomplan called "Inputs" and it contains Input1..Input8. Each time I refresh the framb0ise screen the inputs are displayed in a different order, they jump around. It would be nice if they where always displayed in a same and sorted order. Another plan called "Relays" containing 8 relays has the same behavior.
safi78 wrote:Hi Henry,henrivb wrote:Hi, I installed it and it looks really nice. One question: I have created a roomplan called "Inputs" and it contains Input1..Input8. Each time I refresh the framb0ise screen the inputs are displayed in a different order, they jump around. It would be nice if they where always displayed in a same and sorted order. Another plan called "Relays" containing 8 relays has the same behavior.
I know, I use the same sorting stuff domoticz does, but it doesn't work for me. I have to look into this.
Can you report a bug as a reminder?
No problem, glad you like it.henrivb wrote:Done. I created a bug report called: "framb0ise - jumping items", thanks in advance.
Where did you report it?henrivb wrote:Done. I created a bug report called: "framb0ise - jumping items", thanks in advance.
Maybe take a look at the browser console? Usually found under develepment tools. If there are errors, they'll show up theremarcotrumpet wrote:Hi
Just started yesterday with that awesome dashboard. No problem at all, but.. if I connect to http://myddns:port/framb0ise when I'm under wifi it's ok, if I go out I can connect to the page but nothing is listed.. It seems that I don't have any roomplans.. If I connect to domoticz main page with the same ddns everythings works fine.
