Thats a good question. i think both questions have the same problem in this case, i don't know for sure that the lux value is supported at the moment. In the top tiles you can choose which value from the Json you want to show but the line charts are an other case.AleSpero wrote:Hello! I recently discovered this tool, and it's really great! Thank you for your hard work
I got some questions:
- Can i add data from 2 different devices in a line chart? I've seen in the general discussion topic that someone had both temperature and humidity in the same chart, i tried to replicate that (using a Lux sensor instead of humidity)
-Speaking of the Lux sensor, i can't seem to display its data in a line chart (i tried Domoticz smart chart too)
Is it supported? I tried something like
But it's showing an "usage" graph with no data in it.Code: Select all
Room Illumination = 8, day, lux
Thank you!
I will create an issue in the GitHub about the lux values and will look into it asap.
