Domoboard - Configuration issues
Domoboard is a dashboard for Domoticz based on Python Flask.
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
squandor
Domoticz version: 3.5837
Re: Domoboard - Configuration issues
Post by squandor »
AleSpero wrote:Hello! I recently discovered this tool, and it's really great! Thank you for your hard work :D
I got some questions:
- Can i add data from 2 different devices in a line chart? I've seen in the general discussion topic that someone had both temperature and humidity in the same chart, i tried to replicate that (using a Lux sensor instead of humidity)
-Speaking of the Lux sensor, i can't seem to display its data in a line chart (i tried Domoticz smart chart too)
Is it supported? I tried something like
Room Illumination = 8, day, lux
But it's showing an "usage" graph with no data in it.
Thank you! :)
Thats a good question. i think both questions have the same problem in this case, i don't know for sure that the lux value is supported at the moment. In the top tiles you can choose which value from the Json you want to show but the line charts are an other case.
I will create an issue in the GitHub about the lux values and will look into it asap.
AleSpero
Post by AleSpero »
Thanks man, appreciated :D
caveman85
Domoticz version: 3.8153
Post by caveman85 »
I'm starting with Domoboard, but it seems not to support my blinds... is this correct.
i've tried;
Uitval = <id>, blinds
and
Uitval = <id>, blinds, Data
but nothing happens or shown on the dashboard.
Ant ideas's?
RFAH
Domoticz version: 3.6395
Post by RFAH »
i've tried;
and
Ant ideas's?
I have the same problem.
As far as i know, blinds are not supported (yet).
You can show the status of the blinds (using top_tiles: status open/closed).
But for now you cannot open or close the blinds using domoboard.
However, maybe it is possible to use an on/off dummy switch and a (lua) script to open or close the blinds.
By showing the dummy switch in domoboard, you can use the switch to open of close the blinds.
(I have not tried this myself, but it can be a temporary solution).
woody4165
Post by woody4165 »
I have a camera url that works on a browser, but does not in the domoboard config.
  [[camera]]
    [[[campa]]]
      url = http://user:[email protected]/tmpfs/auto.jpg
What can I check?
caveman85
Post by caveman85 »
woody4165 wrote: Monday 11 September 2017 8:48 Hi
  [[camera]]
    [[[campa]]]
What can I check?
Can you tell us which browser you are using? For Chrome check; https://www.chromestatus.com/feature/5669008342777856
woody4165
Post by woody4165 »
Thanks!!
That is the issue.
I didn't know about it, with Opera it's working, but my main browser is Chrome...
I will try some other solution!
caveman85
Post by caveman85 »
Is there a way to "reload" the camera img DIV? Currently a camera-screenshot is shown in my Domoboard, but I have to reload for a new "screenshot". Can this be automated, so it refreshes the img every X seconds?
woody4165
Post by woody4165 »
In this dashboard I haven't seen any parameter for refresh or refresh time, so I don't think so.
FuTuReD
Post by FuTuReD »
When I start domoboard and go to the right IP, I get the following error:
File "/home/pi/domoboard/modules/webconfig.py", line 23, in getVersion
f = open('VERSION.md', 'r')
IOError: [Errno 2] No such file or directory: 'VERSION.md'
the file is availablie in /home/pi/domoboard/
caveman85
Post by caveman85 »
I had the same error. From which directory are you launching the script? Try a sub folder up or deeper and start again
FuTuReD
Post by FuTuReD »
Thanks for reply,
Whan I launch Domoboard as service then I have no problems anymore.
But what about the development of Domoboard? The last update on Github is 5 month ago. if I compare that with dashticz....
