Tip: Cheap wireless doorbell from Action
m00st
Post by m00st »
A tip for Dutch Domoticz users: the Select Plus wireless doorbell that's for sale for 5,95 Eur at the Action works well with RFXcomm, provided that you enable the Byron SX protocol on the RFXcomm.:
This is the unit in it's packaging:
It comes with a remote door clicker (battery included) and the receiver (the thing that makes the sound) plugs into an EU power socket. It has 3 volumes and 36 different melodies. Pretty handy as a chime for some event.
EdwinK
Re: Tip: Cheap wireless doorbell from Action
Post by EdwinK »
Thanks. Going to get me some later.
SteGe
Post by SteGe »
That is working for me as well. I have it as a trigger for getting a snapshot of my security camera and send it to my whatsapp.
But when I trigger it in Domoticz, the chime is ringing as well (and so annoying my Girlfriend when testing the system haha)
Synology DS3615xs | Raspberry pi 3b |
RFXtrx433E | MySensors | Z-wave | Philips Hue | Ikea Tradfri |
Sunscreen | Power switches | Toon | Harmony | UE Smartradio |
Weatherstation | Doorbell | Letterbox reader | Lux | Temp | Humidity | Motion |
TyzzyT
Domoticz version: 3.5877
Post by TyzzyT »
This is awesome!
I was looking for a cheap device which could alarm me in case of fire, waking up, etc. This is exactly what I was looking for.
Is it possible to make the doorbell and the siren both a seperate sensor in Domoticz? So I can have a seperate doorbell switch and a seperate siren for multiple applications?
Dirk
Post by Dirk »
Thanks for sharing! This Action doorbell works for me to. I have not looked into un-pairing the doorbell and the chime, would be nice to be able to use the doorbell as a remote-control for other domoticz actions.
Snakfy
Post by Snakfy »
Thanks for the Tip!
I'm going to have a look tomorrow if they still have it.
Chillout
Post by Chillout »
I got this exact model last week. So far, I haven't been able to get it working...
freijn
Domoticz version: Stable
Post by freijn »
for the RFLinkGateway the doorbell is working the sirene can not be triggered by the Domoticz system :-(
Dirk
Post by Dirk »
Chillout wrote: Sunday 04 March 2018 22:26 I got this exact model last week. So far, I haven't been able to get it working...
Did you enable the correct protocol? (the Byron SX protocol on the RFXcomm according to the first post).
jelledj
Post by jelledj »
Are there separate low cost doorbell buttons (beldrukker < dutch) with integrated light that I can connect to my wired cables of my current doorbell connected to the transformer in my utility room, that will be able to create an event in domoticz (RFZcomm?)
Scalyvo
Post by Scalyvo »
Hi All,
My setup : platform raspberry2 with domoticz v3.8153
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver
Version: Ext2/1024
I have the Byron SX protocol enabled by (Modus instellen) and click the set mode button .
When i want to add new hardware, the Byron sx protocol is not in the (Type) list to select .
What can i do more ?
Greetzzz
Scalyvo
Eddiever
Domoticz version: 2022.1
Post by Eddiever »
Use the Learn Light/Switch and then push the button. This should show your new button/doorbell.
Scalyvo
Post by Scalyvo »
Eddiever wrote: Friday 30 March 2018 11:56 Use the Learn Light/Switch and then push the button. This should show your new button/doorbell.
Thnx problem solved !
Dirk
Post by Dirk »
Note that these doorbells are in & out of stock often at Action. So if you don't find them now, try again in a few weeks or try another Action. Utrecht currently doesn't sell them but Amsterdam does.
gschmidt
Post by gschmidt »
I have also same doorbell, created a switch for it with rfxtrx433xl (lighting 4) modus added. When I hit the doorbell switch there is only one record in the log, but when I push the physical doorbell button there are 3 or 4 records in the log???...I want to sent a notification but not 3 or 4...is there a trick for this?
wvries
Domoticz version: latest B
Post by wvries »
gschmidt wrote: Wednesday 30 January 2019 15:42 I have also same doorbell, created a switch for it with rfxtrx433xl (lighting 4) modus added. When I hit the doorbell switch there is only one record in the log, but when I push the physical doorbell button there are 3 or 4 records in the log???...I want to sent a notification but not 3 or 4...is there a trick for this?
did you figure this out already ?
within dzvents, use the lastUpdate check.
if (domoticz.devices('Frontdoor Bel').changed and domoticz.devices('Frontdoor Bel').lastUpdate.minutesAgo > 1) then
"Action"
