EspEasy Wemos Mini and push button notification
Everything about esp8266 and more.
ensingg
Post by ensingg »
Sorry, I am a newbie. Tried reading many wikis but still too much information.
I like to have a push button connected to my ESP8266 and when I press it, I like to get a notification from Domoticz.
I configured ESPEasy with a device. But don't know what to do in Domoticz.
Please be patient and help me ;-)
Best regards,
Gert
Toulon7559
Domoticz version: <2025
Re: EspEasy Wemos Mini and push button notification
Post by Toulon7559 »
Shorthand writing, but this in summary gives the idea [the ESPEasy Wiki describes in more detail]:
1. Go to Domoticz, Setup, Hardware
2. Create Dummy with Switch => will create Switch Device
3. Go to Domoticz, Setup, Devices
4. Under Hardware look for Dummies
5. Take note of the IDX for the Switch you created under 2.
6. Use that IDX in ESPEasy, Devices to identify your switch
7. Then in Domoticz use the information in your application
Eawo
Post by Eawo »
I also have this problem with a sonoff with easyesp it just won't work with idx not sure what I'm doing wrong it works great using http link.
And it works fine with http but if I use idx I can use the push button and see the relay changes off/on
Do I need to have a mtqq client to get idx working?
Westcott
Post by Westcott »
Hi Eawo,
Can you post screenshots of your ESPeasy and Domoticz device pages, please?
And no, you don't need MQTT.
Eawo
Post by Eawo »
OK heres my settings plz tell if u want more info :D
And in Domoticz Log it says this 2017-04-23 13:17:13.354 User: Eawo initiated a switch command (46/Sonoff/On)
griztoof
Domoticz version: 4.97
Post by griztoof »
hi,
have anyone the solution ?
I have the same matter without solution. i spend a lot of time to reading forums …
My esp switch when i press the button, but domoticz Don't change the status of the button. (the IDX is well informed)
marcojpolet
Post by marcojpolet »
Did you also read the help page for Domoticz MQTT? It also says:
MQTT Client Gateway with LAN interface"
https://www.letscontrolit.com/wiki/inde ... oticz_MQTT
Perhaps you missed that?
Is there a reason you want MQTT? I use Domoticz HTTP and this works fine.
Also you might consider installing a more recent version of esp easy? I use the mega branch which works quite good.
Regards,
Marco
griztoof
Post by griztoof »
Thanks à lot, I've try http and it works fine
