freakshock
Re: Dashticz v2.0, custom positioning and multiple screens
What browser do you use on an Android tablet?
I've tried Chrome, Full Screen Browser and Dolphin.
Chrome is bad because I can't hide the adress bar, dolphin can do this but it makes the page scroll so when I try to swipe it shows the adress bar again. Full screen browser seems perfect on the address bar and zooming side of things, but it crashes once or twice a day on my Nexus 10.
freakshock
Here it is, power and gas:robgeerts wrote: It is already available but not all devices get recognized correctly... Please send me the output of the devices and I will fix it a.s.a.p.
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"Counter" : "8231.165",
"CounterDeliv" : "0.157",
"CounterDelivToday" : "0.000 kWh",
"CounterToday" : "3.847 kWh",
"CustomImage" : 0,
"Data" : "3744641;4486524;69;88;230;0",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 2,
"HardwareName" : "Slimme meter",
"HardwareType" : "P1 Smart Meter USB",
"HardwareTypeVal" : 4,
"HaveTimeout" : false,
"ID" : "1",
"LastUpdate" : "2017-04-20 20:37:24",
"Name" : "Stroom",
"Notifications" : "false",
"PlanID" : "2",
"PlanIDs" : [ 2 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "Energy",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "P1 Smart Meter",
"TypeImg" : "counter",
"Unit" : 1,
"Usage" : "230 Watt",
"UsageDeliv" : "0 Watt",
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "1"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"Counter" : "5207.100",
"CounterToday" : "2.090 m3",
"CustomImage" : 0,
"Data" : "5207.100",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 2,
"ID" : "1",
"LastUpdate" : "2017-04-20 20:35:44",
"Name" : "Gas",
"PlanID" : "2",
"PlanIDs" : [ 2 ],
"SubType" : "Gas",
"SwitchTypeVal" : 1,
"Timers" : "false",
"Unit" : 2,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "2"
robgeerts
- Domoticz version: 3.7067
Just tested these and they seem to work?freakshock wrote:Here it is, power and gas:robgeerts wrote: It is already available but not all devices get recognized correctly... Please send me the output of the devices and I will fix it a.s.a.p.
{ "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "Counter" : "8231.165", "CounterDeliv" : "0.157", "CounterDelivToday" : "0.000 kWh", "CounterToday" : "3.847 kWh", "CustomImage" : 0, "Data" : "3744641;4486524;69;88;230;0", "Description" : "", "Favorite" : 1, "HardwareID" : 2, "HardwareName" : "Slimme meter", "HardwareType" : "P1 Smart Meter USB", "HardwareTypeVal" : 4, "HaveTimeout" : false, "ID" : "1", "LastUpdate" : "2017-04-20 20:37:24", "Name" : "Stroom", "Notifications" : "false", "PlanID" : "2", "PlanIDs" : [ 2 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "Energy", "SwitchTypeVal" : 0, "Timers" : "false", "Type" : "P1 Smart Meter", "TypeImg" : "counter", "Unit" : 1, "Usage" : "230 Watt", "UsageDeliv" : "0 Watt", "Used" : 1, "XOffset" : "0", "YOffset" : "0", "idx" : "1" }, { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "Counter" : "5207.100", "CounterToday" : "2.090 m3", "CustomImage" : 0, "Data" : "5207.100", "Description" : "", "Favorite" : 1, "HardwareID" : 2, "HardwareName" : "Slimme meter", "HardwareType" : "P1 Smart Meter USB", "HardwareTypeVal" : 4, "HaveTimeout" : false, "ID" : "1", "LastUpdate" : "2017-04-20 20:35:44", "Name" : "Gas", "Notifications" : "false", "PlanID" : "2", "PlanIDs" : [ 2 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "Gas", "SwitchTypeVal" : 1, "Timers" : "false", "Type" : "P1 Smart Meter", "TypeImg" : "counter", "Unit" : 2, "Used" : 1, "XOffset" : "0", "YOffset" : "0", "idx" : "2" },
SwordFish
- Domoticz version: V4.11375
I noticed that the dashboard isn't refreshing. I have a scene that's goes on after sunset. The lights were on but the dashboard didn't refresh. I waited for a minute nothing only when I press a different button it's refreshed?
Letalis
Thanks for a really nice Dashboard.
I will send you a gift soon..
Btw is there a possibility to change the layout of the sliders to "top-bottom" instead of "left-right".
robgeerts
Could you try latest version just pushed to gitlab?
sonar
- Domoticz version: 3.8153
In Chrome on Android you can choose an option from the menu "Add to Homescreen"(Toevoegen aan startscherm). This will make a shortcut on your homescreen. If you start the dashboard with this shortcut the dashboard will be fullscreen.freakshock wrote:Chrome is bad because I can't hide the adress bar
freakshock
This is my result for all power/gas blocks: Clicking the three graph options does nothing.robgeerts wrote:Just tested these and they seem to work?freakshock wrote:Here it is, power and gas:robgeerts wrote: It is already available but not all devices get recognized correctly... Please send me the output of the devices and I will fix it a.s.a.p.
robgeerts
Ah, I thought clicking on a block didnt work.freakshock wrote:This is my result for all power/gas blocks:robgeerts wrote:Just tested these and they seem to work?freakshock wrote:
Ok, do you get an error in console (f12) ? (only works when opening on windows)
SwordFish
Now its working.robgeerts wrote:Could you try latest version just pushed to gitlab?
Where can i adjust the refresh time so that i can set my own time?
robgeerts
At the bottom of main.js (twice), will add a variable for this..
SwordFish
Thanks, that would be nice.robgeerts wrote:At the bottom of main.js (twice), will add a variable for this..
freakshock
No errors unfortunately.. only this output but I think that's not related to this problem:robgeerts wrote:Ah, I thought clicking on a block didnt work.freakshock wrote:This is my result for all power/gas blocks:robgeerts wrote:
index.html#1:8 Error parsing a meta element's content: ';' is not a valid key-value pair separator. Please use ',' instead.
jquery.min.js:4 Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.Thanks, perfect solution, especially since I can use the pull to refresh functionsonar wrote:In Chrome on Android you can choose an option from the menu "Add to Homescreen"(Toevoegen aan startscherm). This will make a shortcut on your homescreen. If you start the dashboard with this shortcut the dashboard will be fullscreen.freakshock wrote:Chrome is bad because I can't hide the adress bar
robgeerts
Added in latest version.SwordFish wrote:Thanks, that would be nice.robgeerts wrote:At the bottom of main.js (twice), will add a variable for this..
You can add to config.js:
var _DOMOTICZ_REFRESH = 10; //seconds
- gielie
- Domoticz version: latest β
@ robgeerts
It works like a charm, very impressive work.
I'd like to change the color of the fan.on but it is not a fa-icon, how do I do this?
And (I'm not very demanding) I'd like to create a link to the 3rd screen if possible. So when I click my small webcam on the first screen it will show the 3rd screen with a bigger webcam picture.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
- htilburgs
Wow, lot of changes!
Have to get working again on the Wiki
Btw, Thanx for the iphone output. Not at home right now, but will try it tomorow.
Hardware:
robgeerts
Just overwrite fan.png in img-folder with another image.gielie wrote: It works like a charm, very impressive work.
I'll put this on my todo-list.gielie wrote: And (I'm not very demanding) I'd like to create a link to the 3rd screen if possible. So when I click my small webcam on the first screen it will show the 3rd screen with a bigger webcam picture.
- mlamie
- Domoticz version: 3.5877
I use Chrome (full screen) on my Nexus 7 tablet. If you select add to home screen in the Chrome menu, a shortcut will be created, via this shortcut the address bar is not given. Secondly I use Power Toggles and enable Immersive mode which will hide the Android top bar and on screen buttons.freakshock wrote:What browser do you use on an Android tablet?
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
whiteduck
Hi Rob,
Thanks for fixing the pump icon status! EDIT: Actually it is not fixed: see below in Chrome.
Oddly running Chrome (no zoom) and Safari (no zoom) I get a different result on my Mac.
In the attachment Chrome is on the left and while the available browser window size is different due to the headers I notice in Safari (on the right) I lose the bottom of the window and cannot scroll down to see it - looks like the window size is not being correctly picked up. Not a major issue but just wanted to let you know.
Best regards
Ian
Best regards
Ian
Domoticz on Ubuntu 16.04 LTS VM
RFXCom USB transceiver
Aeon Labs V2 USB (Zwave)
Various HomeEasy, Oregon devices and sensors. Now using Z-Wave Fibaro FGMS-001, TKB TZ88Es
TP-Link IP310 Cameras
- bierlaagh
- Domoticz version: 4.9984
Thnx for the latest update , Scenes are working now.
got another issue (or i don't know how to adjust)
I have an UV meter, which gives the following output:
what do i have to change to replace On/off to the output (0.0 in this case)
"ActTime" : 1492726357,
"ServerTime" : "2017-04-21 00:12:37",
"Sunrise" : "06:26",
"Sunset" : "20:43",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 0,
"CustomImage" : 0,
"Data" : "0.0 UVI",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 1,
"HardwareName" : "rfxcom",
"HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
"HardwareTypeVal" : 1,
"ID" : "8900",
"LastUpdate" : "2017-04-21 00:12:28",
"Name" : "uv meter",
"PlanID" : "2",
"PlanIDs" : [ 2, 6, 10 ],
"SignalLevel" : 7,
"SubType" : "UVN800",
"Timers" : "false",
"Type" : "UV",
"TypeImg" : "uv",
"UVI" : "0.0",
"Unit" : 0,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "69"
"status" : "OK",
"title" : "Devices"
}1x Raspberry PI 3 With Domoticz V.3.7318
1X RFXtrx433 USB 433.92MHz
1X Synology DS213j Nas
Toon by Eneco including Toon Zon
several KAKU switches and dimmers
Mysensors WIFI Gateway including meters, switches en humidity sensors
Wifi Dimmers (home made)
