Buienradar Weather Lookup Plugin
- Domoticz version: 4.10538
Re: Buienradar Weather Lookup Plugin
Will this plugin also be delivered with a future Domoticz version ?
- Domoticz version: 4.10717
since today the plugin gives a error.
This starten on 6 April at 15:15 uur.
log:
2017-04-06 16:49:55.195 (Buienradar) Retrieve weather data from http://xml.buienradar.nl/
2017-04-06 16:49:55.248 Error: (Buienradar) 'onStart' failed 'ParseError'.
2017-04-06 16:49:55.248 Error: (Buienradar) ----> Line 80 in /home/alexander/domoticz/plugins/domoticz-buienradar/plugin.py, function onStart
2017-04-06 16:49:55.248 Error: (Buienradar) ----> Line 78 in /home/alexander/domoticz/plugins/domoticz-buienradar/buienradar.py, function getBuienradarXML
2017-04-06 16:49:55.248 Error: (Buienradar) ----> Line 1184 in /usr/lib/python3.5/xml/etree/ElementTree.py, function parse
2017-04-06 16:49:55.248 Error: (Buienradar) ----> Line 607 in /usr/lib/python3.5/xml/etree/ElementTree.py, function parse
Does anyone know the solution ?
edit: I see that the XML link is empty. Might be a problem with buienradar.
log:
Spymate wrote:since today the plugin gives a error.
log:
Buienradar is up and running. It was a problem with Buienradar.
Missing some error handling in buienradar.py:
Changed:
into
Changed:
self.tree = ET.parse(xml)
self.lastUpdate = datetime.now()
try:
except ET.ParseError as err:
Domoticz.Log("XML error: " + err)
return
- Plaagje
- Domoticz version: Latest
Nice Plugin!
I could use an UV index.
And an rain predicament would be nice.
-Plaagje
-Plaagje
- EdwinK
- Domoticz version: BETA
Recently noticed this:
2017-04-11 12:09:12.970 Error: (Buienradar) ----> Line 90 in /usr/local/domoticz/var/plugins/buienradar/plugin.py, function onHeartbeat
2017-04-11 12:09:23.170 Error: (Buienradar) 'onHeartbeat' failed 'KeyError'.
I tried to install the plugin and I think the problem why it is not working is the python3-dev which I cannot install on my synology.
When I run the local.py:
anyone know how to avoid using python3-dev or install is on a synology?
FYI, gives
I have anoher plugin running without problems.
File "localtest.py", line 13, in <module>
from buienradar import Buienradar
File "/volume1/@appstore/domoticz/plugins/buienradar/buienradar.py", line 16, in <module>
import urllib.request
ImportError: No module named request
FYI,
sudo apt install python3-dev
apt: invalid flag: install
Shouldn't it be:
Or without 'install'
sudo apt-get install python3-dev
Thanks for thinking with me but Synology works with an appstore and although I can install most things using PIP, Python packages typically only can be installed via the appstore. Tried your suggestions just to be sure but without succes.
- EdwinK
Did you try to install easy_install. I did several weeks ago, and I could install what was needed with that.
Great to know it is possible. I have easy_install installed so gave it a try. Hope you can help me a bit more...
easy_install python3-dev
Searching for python3-dev
Reading https://pypi.python.org/simple/python3-dev/
Couldn't find index page for 'python3-dev' (maybe misspelled?)
Scanning index of all packages (this may take a while)
No local packages or download links found for python3-dev
error: Could not find suitable distribution for Requirement.parse('python3-dev')
- EdwinK
Sorry, Can't remember how I did that.
All,
i installed the pluging and see it when i want to add it as hardware. only if I click on the button "Add" nothing happened...
already reinstalled it, restarted Domoticz a couple of times. tried the 2 different ways to install but still i cannot add it
dows someone have an idea?
Changing
to
in the PY files on the synology at leasts lets the local.py file run succcesfull. Will check if it now also works in domoticz tomorrow.
Edit: Buienradar does not show up in Domoticz after restarting. Will continue my search n how to install python3-dev on a synology. I expect that to be the issue
import urllib.error
import urllib
#import urllib.request
#import urllib.error
EdKo66 wrote:Thanks. I hope someone here will have a Synology and will answer.
Ed, there are multiple ways to do this. It can be done via SSH but I find it easiest to go to the web interface of the synology --> Package center --> Domoticz --> Stop service --> Start Service.
- EdwinK
Got it working now. But thanks for your answer
- Domoticz version: V3_8394
this only works for positions in the Netherlands? Or also for Belgium?
- Domoticz version: 4.10915
It uses the http://xml.buienradar.nl/ file - only weather stations in the Netherlandsropske wrote:Hi,
The plugin uses http://xml/buienradar.nl and buienradar.be doesn't have such an xml feed, unfortunately.ropske wrote:Hi,
If you are close to the Dutch border, maybe the plugin will be useful for you.
Update Domoticz Bèta 3.7602 - Buienradar (Weather Lookup) Type in Hardware types is missing and no actual information is delivered anymore by the Plugin.
Somebody else with the same experience?
