Buienradar Weather Lookup Plugin
pvm
Domoticz version: 4.10538
Re: Buienradar Weather Lookup Plugin
Post by pvm »
Will this plugin also be delivered with a future Domoticz version ?
Spymate
Domoticz version: 4.10717
Post by Spymate »
since today the plugin gives a error.
This starten on 6 April at 15:15 uur.
log:
2017-04-06 16:49:55.195 (Buienradar) Retrieve weather data from http://xml.buienradar.nl/
2017-04-06 16:49:55.248 Error: (Buienradar) 'onStart' failed 'ParseError'.
2017-04-06 16:49:55.248 Error: (Buienradar) ----> Line 80 in /home/alexander/domoticz/plugins/domoticz-buienradar/plugin.py, function onStart
2017-04-06 16:49:55.248 Error: (Buienradar) ----> Line 78 in /home/alexander/domoticz/plugins/domoticz-buienradar/buienradar.py, function getBuienradarXML
2017-04-06 16:49:55.248 Error: (Buienradar) ----> Line 1184 in /usr/lib/python3.5/xml/etree/ElementTree.py, function parse
2017-04-06 16:49:55.248 Error: (Buienradar) ----> Line 607 in /usr/lib/python3.5/xml/etree/ElementTree.py, function parse
Does anyone know the solution ?
edit: I see that the XML link is empty. Might be a problem with buienradar.
Spymate
Post by Spymate »
Spymate wrote:since today the plugin gives a error.
log:
Buienradar is up and running. It was a problem with Buienradar.
EldigoR
Post by EldigoR »
Missing some error handling in buienradar.py:
Changed:
self.tree = ET.parse(xml)
self.lastUpdate = datetime.now()
into
try:
except ET.ParseError as err:
     Domoticz.Log("XML error: " + err)
     return
Plaagje
Domoticz version: Latest
Post by Plaagje »
Nice Plugin!
I could use an UV index.
And an rain predicament would be nice.
-Plaagje
EdwinK
Post by EdwinK »
Recently noticed this:
2017-04-11 12:09:12.970 Error: (Buienradar) ----> Line 90 in /usr/local/domoticz/var/plugins/buienradar/plugin.py, function onHeartbeat
2017-04-11 12:09:23.170 Error: (Buienradar) 'onHeartbeat' failed 'KeyError'.
GuyTreepbush
Post by GuyTreepbush »
I tried to install the plugin and I think the problem why it is not working is the python3-dev which I cannot install on my synology.
When I run the local.py:
  File "localtest.py", line 13, in <module>
    from buienradar import Buienradar
  File "/volume1/@appstore/domoticz/plugins/buienradar/buienradar.py", line 16, in <module>
    import urllib.request
ImportError: No module named request
anyone know how to avoid using python3-dev or install is on a synology?
FYI,
sudo apt install python3-dev
gives
apt: invalid flag: install
I have anoher plugin running without problems.
pvm
Post by pvm »
Shouldn't it be:
sudo apt-get install python3-dev
Or without 'install'
GuyTreepbush
Thanks for thinking with me but Synology works with an appstore and although I can install most things using PIP, Python packages typically only can be installed via the appstore. Tried your suggestions just to be sure but without succes.
EdwinK
Post by EdwinK »
Did you try to install easy_install. I did several weeks ago, and I could install what was needed with that.
GuyTreepbush
Great to know it is possible. I have easy_install installed so gave it a try. Hope you can help me a bit more... :?
easy_install python3-dev
Searching for python3-dev
Reading https://pypi.python.org/simple/python3-dev/
Couldn't find index page for 'python3-dev' (maybe misspelled?)
Scanning index of all packages (this may take a while)
No local packages or download links found for python3-dev
error: Could not find suitable distribution for Requirement.parse('python3-dev')
EdwinK
Post by EdwinK »
Sorry, Can't remember how I did that.
adsernl
Post by adsernl »
All,
i installed the pluging and see it when i want to add it as hardware. only if I click on the button "Add" nothing happened...
already reinstalled it, restarted Domoticz a couple of times. tried the 2 different ways to install but still i cannot add it :( dows someone have an idea?
GuyTreepbush
Changing
import urllib.error
to
import urllib
#import urllib.request
#import urllib.error
in the PY files on the synology at leasts lets the local.py file run succcesfull. Will check if it now also works in domoticz tomorrow.
Edit: Buienradar does not show up in Domoticz after restarting. Will continue my search n how to install python3-dev on a synology. I expect that to be the issue
GuyTreepbush
EdKo66 wrote:Thanks. I hope someone here will have a Synology and will answer.
Ed, there are multiple ways to do this. It can be done via SSH but I find it easiest to go to the web interface of the synology --> Package center --> Domoticz --> Stop service --> Start Service.
EdwinK
Post by EdwinK »
Got it working now. But thanks for your answer
ropske
Domoticz version: V3_8394
Post by ropske »
this only works for positions in the Netherlands? Or also for Belgium?
Snowtiger
Domoticz version: 4.10915
Post by Snowtiger »
ropske wrote:Hi,
It uses the http://xml.buienradar.nl/ file - only weather stations in the Netherlands ;)
ffes
Post by ffes »
ropske wrote:Hi,
The plugin uses http://xml/buienradar.nl and buienradar.be doesn't have such an xml feed, unfortunately.
If you are close to the Dutch border, maybe the plugin will be useful for you.
Snowtiger
Post by Snowtiger »
Update Domoticz Bèta 3.7602 - Buienradar (Weather Lookup) Type in Hardware types is missing and no actual information is delivered anymore by the Plugin.
Somebody else with the same experience?
Users browsing this forum: binbo and 1 guest
