Blocky Commands ignored
cbartetzko
Domoticz version: 2023.1
Post by cbartetzko »
My observation is, that blocky scripts are sometimes totally ignored by the system (Of course they are marked active)
or that single blocky commands are ignored (e.g. when you try to set a new setpoint for a thermostat).
In all these cases there is no message / no hint at all in the Log, why these blocky commands are ignored.
Is there any possibility to debug blocky on a deeper level than the system log, which doesn't show anything ?
Lebo2d9
Domoticz version: L stab
Re: Blocky Commands ignored
Post by Lebo2d9 »
I think there must be some errors in the blocky scripts. Here they always work.
Can you copy one of your scripts that isn't working
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
cbartetzko
Here you are:
See Attachement
The script as such is executed in this case (Messages are written into the Log)
However the Set-Commands are totally ignored, no message, no Failure message, no hint at all in the log, why this is ignored.
tozzke
Domoticz version: Stable
Post by tozzke »
Isn't this because you simply can't set the '... actual' block? that it's just a read out of this specific sensor?
When I add a dummy thermostat ( I don't have a smart thermostat myself), I get to add this block (under Devices - SetPoints)
Shouldn't you use this block instead?
cbartetzko
Probably you are right.
However the strange thing is, that I do not have this "Set SetPoint" Command available in my Blockly
nor do I have other Devices than the "actual." for Setpoints.
Obviously you are using a Beta firmware, which has new functions available,
which are not available in the latest stable firmware.
cbartetzko
I've upgraded now to the latest Beta-Firmware (3.7365).
But even there I don't get the "Set Setpoint" Blockly-Element as you are showing.
All I can access is this:
StanHD
Post by StanHD »
It should be in "Devices" if you expand that one?
Python:- Broadlink RM2, Sonos
cbartetzko
In my Devices Menu there are no Setpoints:
StanHD
Post by StanHD »
Hmm, could you take a look in Chrome Incognito mode. If that's possible?
cbartetzko
Yeah, in Chrome Incognito Mode it seems to work:
But how do I get it working in my normal Chrome environment ?
Chrome App-Cache Cleaning (as described in Domoticz User-Manual) does not help.
I tried this several times.
cbartetzko
And by the way, even with this new Blockly-Function (tried no in Chrome Incognito Mode)
my intitial problem of ignored Blockly commands is still there:
Script is working, Comments are written into Log, but "Set Setpoint" Commands are ignored (not executed, no message in Log)
Lebo2d9
Post by Lebo2d9 »
Don't you need to update the value with a json sctipt?
Verstuurd vanaf mijn SM-G920F met Tapatalk
More to come
Lebo2d9
Post by Lebo2d9 »
I set the setpoints of my heating like this.
http://127.0.0.1:8080/json.htm?type=set ... &used=true
More to come
cbartetzko
Of course I can update Setpoint with scripts (e.g. with a LuA-script).
But I wanted to do this in Blockly.
Of what use is this new Blockly-Element "Set Setpoint" if I need a script additionally ?
Lebo2d9
Post by Lebo2d9 »
I use the url with a dummy switch in the on/off action
More to come
