Locked
maluko
Re: Dashticz v2.0, custom positioning and multiple screens
Post by maluko »
i am trying to add a virtual swicth that control my irrigation zone system, but i am facing with this problem:
virtual swich is placed on "rega" plan and hiden on main plan, so can´t see on dashboard, if i bring back to main next came back to dash.
can i contorn this?
thanks.
HansieNL
Post by HansieNL »
maluko wrote:i am trying to add a virtual swicth that control my irrigation zone system, but i am facing with this problem:
can i contorn this?
thanks.
You have to use var _USE_FAVORITES = false
Blah blah blah
HansieNL
Post by HansieNL »
htilburgs wrote:The Wiki page for Dashticz v2.0 is now up-to-date.
You can find this page on http://www.domoticz.com/wiki/Dashticz-v2
Well done job!!!
I use the following code for lightbulbs css because then i also can set the opacity. Maybe you can add to the wiki?
.fa.fa-lightbulb-o.on {
color: rgba(0,255,0,0.4)
I just see a lot // are in the wiki used, where it should not be used. Maybe it's better to remove them. I think it's confusing for a lot of people.
Blah blah blah
htilburgs
Post by htilburgs »
Well done job!!!
I see what you mean. Just cleaned up the // in the wiki.
For the CSS I will create a different section "User CSS Modifications". I trie to keep it clean and simple (just as Dashticz v2.0)....;)
Hardware:
Dingetje2004
Post by Dingetje2004 »
Well done job!!!
What code do I have to add in custom css for making the icons a little bigger? thanks!
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
hpapagaj wrote: Back to the question: so it is not possible to enable only news column and make other columns (switches, date, clock, buttons, weather etc) work automatically like until now?
No, its either automatically without modifications or defining every device you want.
I can understand it's a lot of work the first time, finding the right idx's and stuff but its worth it ;)
It will be much easier to switch columns and move devices
hpapagaj wrote: robgeerts: I made some merge requests today, if you find it useful, you can merge it.
I will check them out, thanks!
Edit: have merged your request (the favicons).
I would like own favicons instead of using the Domoticz-favicons but for now this is fine, thanks.
westd001
Post by westd001 »
Hi Rob and others,
I follow this topic for a few weeks now and it's really great to see the progress in the development of the dashboard. Thanks for that, and I will make an donation for your tabblet :-)
I made some modifications so the dashboard layout fitts on my 7"Raspii3 touchscreen. See the picture. One thing I can't change is the text that is shown at all "Rookmelders" on page 2. The status is "Normal" but it say's "Rook gedetecteerd", could you please change this in the next release ?
I am still changing the layout of the second screen but it will fit some day.......
John
htilburgs
Post by htilburgs »
Dingetje2004 wrote:
htilburgs wrote:
HansieNL wrote: Well done job!!!
You have to edit the custom.css and put the next part in there (I've updated the wiki also ;))
.fa-lightbulb-o:before{
	font-size: 24px;
Hardware:
wizjos
Post by wizjos »
westd001 wrote:I made some modifications so the dashboard layout fitts on my 7"Raspii3 touchscreen.
Nice! Care to share?
Regards,
Wizjos
EdwinK
Post by EdwinK »
westd001 wrote:Hi Rob and others,
John
Looks great.
pvdhelm
Post by pvdhelm »
is it gonna rain script doesn't work for me. Get the following error in domoticz
2017-04-15 11:00:00.254 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_rain.lua: /home/pi/domoticz/scripts/lua/script_time_rain.lua:165: bad argument #1 to 'sub' (string expected, got nil)
what kind of virtual switch do i have to make. My switch only prints HELLO WORLD
robgeerts
Post by robgeerts »
westd001 wrote: I follow this topic for a few weeks now and it's really great to see the progress in the development of the dashboard. Thanks for that, and I will make an donation for your tabblet :-)
Thansk, really appreciate it!
westd001 wrote: One thing I can't change is the text that is shown at all "Rookmelders" on page 2. The status is "Normal" but it say's "Rook gedetecteerd", could you please change this in the next release ?
Could you send me the output of that device?
robgeerts
Post by robgeerts »
freakshock wrote:Hi Rob,
Amazing dashboard! I like how most of it works straight out of the box. One question, is it normal behavior that the buienradar image does not refresh on its own? Does it only refresh with a full page refresh? Tested this with chrome on android and Windows. Thanks
I just tested this in latest version and its working for me...
Could you test this?
rbo0567 wrote:
robgeerts wrote:
rbo0567 wrote:Hi Rob,
I'm following this thread a couple of days now and I appreciate your work in this thread a lot.
For me it became more interesting when the camera's got your attention. Tried it after downloading the latest version of Dashticz but can only get 1 camera working at the same time. I made a screen specially for 4 cams but I see only the image of 1 cam (4 times).
Am I doing something wrong?
I didnt test with multiple cams yet... will do this soon!
If there is something I can help you with, please let me know.
Could you test latest version?
Dropshot
Post by Dropshot »
What will be the most convenient way to update this dashboard to the latest version?
robgeerts
Post by robgeerts »
Backup your config.js and custom.css en download the latest version.
Overwrite your existing files.
Or, if you use git on your computer, just use the pull-function
Blueone
Post by Blueone »
I created a cgi script which can be used to change the brightness off the original raspberry touchscreen:
Sources I used:
https://code-maven.com/set-up-cgi-with-apache for setting up cgi in the raspberry
https://github.com/linusg/rpi-backlight, this api is being used simply install by following the instruction on the page
Attached the cgi script based on python (rename to cgi). Simple to use:
http://127.0.0.1/cgi-bin/screen_brightn ... ghtness=11
A valid brightness is between 11-255
a brightness of 0 turns the screen off
I would be great if this one can be added to the stand-by function. Also the text in stand-by is now grey, it would be nice if the text is real white. In the case the text can still be read with a low brightness in the evening from a distance on the couch or something :)
btw, it is a pyton script, don't change it with a windows text editor.
screen_brightness.cgi.txt
(752 Bytes) Downloaded 95 times
robgeerts
Post by robgeerts »
If you want the text to be white, add to custom.css:
.standby .row {
	opacity:1 !important;
I cannot use cgi in my scripts.
I could make a setting that the dashboard has to call an url when going to standby.
westd001
Post by westd001 »
Wizjos,
Here is the code, i only changed config.js, creative.js and the background (attached).
config.js:
var _LANGUAGE 				= 'nl_NL'; //or en_US
var _HOST_DOMOTICZ		  	= 'http://192.168.x.x:xxxx';
var _HOST_ZIGGO_HORIZON	  	= ''; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND  	= 'xxxxxxx';
var _WEATHER_CITY 		= 'Delft';
var _WEATHER_COUNTRY 		= 'NL';
var _USE_AUTO_POSITIONING 	= false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES		= false; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK 	= true; //do not show the seconds in the clock
var _HIDE_MEDIAPLAYER_WHEN_OFF	= false; //when you have a mediaplayer connected, hide it if nothing is playing
var _NEWS_RSSFEED		= 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT		= false;
var _STANDBY_AFTER_MINUTES	= false; //enter amount of seconds like: 5 (5 seconds)
var buttons = {}
buttons.buienradar = {width:12, isimage:true, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}
buttons.camerakeuken = {width:6, image: 'img/SecurityCam.png', title: 'Camera Keuken', url: 'http://192.168.x.x:xxx/snapshot.cgi?user=xxxx&pwd=xxxxx&rate=1'}
buttons.camerablokhut = {width:6, image: 'img/SecurityCam.png', title: 'Camera Blokhut', url: 'http://192.168.x.x:xxxx/snapshot.cgi?user=xxxx&pwd=xxxxx&rate=1'}
"CUSTOM POSITIONING:"
//defining wich blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
var blocks = {}
blocks[12] = {}
blocks[12]['width'] = 6;
blocks[64] = {}
blocks[64]['width'] = 6;
blocks[66] = {}
blocks[66]['width'] = 6;
blocks[109] = {}
blocks[109]['width'] = 6;
blocks[116] = {}
blocks[116]['width'] = 6;
blocks[423] = {}
blocks[423]['width'] = 6; //1 to 12, remove this line if you want to use the default (4)
blocks[425] = {}
blocks[425]['width'] = 6;
blocks[435] = {}
blocks[435]['width'] = 6;
blocks[436] = {}
blocks[436]['width'] = 12;
blocks[443] = {}
blocks[443]['width'] = 12;
blocks[479] = {}
blocks[479]['width'] = 6;
blocks[485] = {}
blocks[485]['width'] = 6;
blocks[536] = {}
blocks[536]['width'] = 6;
blocks[576] = {}
blocks[576]['width'] = 6;
blocks[577] = {}
blocks[577]['width'] = 6;
blocks[716] = {}
blocks[716]['width'] = 6;
blocks[743] = {}
blocks[743]['width'] = 6;
blocks[753] = {}
blocks[753]['width'] = 6;
blocks[801] = {}
blocks[801]['width'] = 6;
blocks[813] = {}
blocks[813]['width'] = 3;
blocks[814] = {}
blocks[814]['width'] = 3;
blocks[815] = {}
blocks[815]['width'] = 3;
blocks[816] = {}
blocks[816]['width'] = 3;
blocks[833] = {}
blocks[833]['width'] = 6;
blocks[841] = {}
blocks[841]['width'] = 6;
blocks[842] = {}
blocks[842]['width'] = 6;
blocks[843] = {}
blocks[843]['width'] = 12;
blocks['currentweather'] = {}
blocks['currentweather']['width'] = 12;
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['title'] = 'Weersvoorspelling';
//defining number of columns, their contents en widths
//width can be a number 1 to 12, but total widths of all columns should always be 12
var columns = {}
columns[1] = {}
columns[1]['blocks'] = [753,716,425,743,66,423,485,436,443] //remark: idx 144 produces 2 blocks, so you can use: '144_1' and '144_2' (or of course, just 144 if you want one)
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['currentweather','weather',843,814,815,816]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise',buttons.buienradar,buttons.radio,buttons.nunl]
columns[3]['width'] = 2;
columns[4] = {}
columns[4]['blocks'] = [64,833,109,116,576,577,479,801]
columns[4]['width'] = 5;
columns[5] = {}
columns[5]['blocks'] = ['12_1','536_1','12_2','536_2',buttons.camerakeuken,buttons.camerablokhut]
columns[5]['width'] = 5;
columns[6] = {}
columns[6]['blocks'] = ['clock']
columns[6]['width'] = 2;
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'brushed-metallic-backgroud800x480_3.jpg';
screens[2] = {}
screens[2]['background'] = 'brushed-metallic-backgroud800x480_3.jpg';
screens[2]['columns'] = [4,5,6]
just changed this part in creative.js:
  .slider-pagination {
      position: absolute;
      bottom: 20px;
      width: 95%;
      left: 0;
      text-align: right;
      z-index: 1000;
Rob, this is the output of a "Smoke detector"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "Normal",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 3,
         "HardwareName" : "RFXCOM",
         "HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
         "HardwareTypeVal" : 1,
         "HaveDimmer" : false,
         "HaveGroupCmd" : false,
         "HaveTimeout" : false,
         "ID" : "6B9D00",
         "LastUpdate" : "2017-04-07 13:27:43",
         "MaxDimLevel" : 0,
         "Name" : "Rookmelder Overloop (M)",
         "Notifications" : "true",
         "PlanID" : "5",
         "PlanIDs" : [ 5, 6 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : 4,
         "Status" : "Normal",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "KD101 smoke detector",
         "SwitchType" : "Smoke Detector",
         "SwitchTypeVal" : 5,
         "Timers" : "false",
         "Type" : "Security",
         "TypeImg" : "smoke",
         "Unit" : 0,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "576"
Blueone
Post by Blueone »
robgeerts wrote:If you want the text to be white, add to custom.css:
.standby .row {
Isn't it possible to call this url http://127.0.0.1/cgi-bin/screen_brightn ... ghtness=11 when this script is added by the user? If not, I can also create a simple HTML which can be put in the webserver which run's the cgi.
EdwinK
Post by EdwinK »
pvdhelm wrote:is it gonna rain script doesn't work for me. Get the following error in domoticz
You need to have a txt switch AND an ON/OFF switch. Make sure that the name you give the ON/OFF-switch is exactly the same as in the script. Also, a NILL error can mean that the temp file isn't created or writable. I believe user hansienl has writen something about that in this topic.
Locked
