maluko
Re: Dashticz v2.0, custom positioning and multiple screens
i am trying to add a virtual swicth that control my irrigation zone system, but i am facing with this problem:
virtual swich is placed on "rega" plan and hiden on main plan, so can´t see on dashboard, if i bring back to main next came back to dash.
can i contorn this?
thanks.
can i contorn this?
thanks.
- HansieNL
You have to use var _USE_FAVORITES = falsemaluko wrote:i am trying to add a virtual swicth that control my irrigation zone system, but i am facing with this problem:
can i contorn this?
thanks.
Blah blah blah
- HansieNL
Well done job!!!htilburgs wrote:The Wiki page for Dashticz v2.0 is now up-to-date.
You can find this page on http://www.domoticz.com/wiki/Dashticz-v2
I use the following code for lightbulbs css because then i also can set the opacity. Maybe you can add to the wiki?
.fa.fa-lightbulb-o.on {
color: rgba(0,255,0,0.4)
I just see a lot // are in the wiki used, where it should not be used. Maybe it's better to remove them. I think it's confusing for a lot of people.
Blah blah blah
- htilburgs
I see what you mean. Just cleaned up the // in the wiki.HansieNL wrote:Well done job!!!htilburgs wrote:The Wiki page for Dashticz v2.0 is now up-to-date.
For the CSS I will create a different section "User CSS Modifications". I trie to keep it clean and simple (just as Dashticz v2.0)....
Hardware:
Dingetje2004
What code do I have to add in custom css for making the icons a little bigger? thanks!htilburgs wrote:I see what you mean. Just cleaned up the // in the wiki.HansieNL wrote:Well done job!!!htilburgs wrote:The Wiki page for Dashticz v2.0 is now up-to-date.
robgeerts
- Domoticz version: 3.7067
No, its either automatically without modifications or defining every device you want.hpapagaj wrote: Back to the question: so it is not possible to enable only news column and make other columns (switches, date, clock, buttons, weather etc) work automatically like until now?
I can understand it's a lot of work the first time, finding the right idx's and stuff but its worth it
It will be much easier to switch columns and move devices
I will check them out, thanks!hpapagaj wrote: robgeerts: I made some merge requests today, if you find it useful, you can merge it.
Edit: have merged your request (the favicons).
I would like own favicons instead of using the Domoticz-favicons but for now this is fine, thanks.
westd001
Hi Rob and others,
I follow this topic for a few weeks now and it's really great to see the progress in the development of the dashboard. Thanks for that, and I will make an donation for your tabblet
I made some modifications so the dashboard layout fitts on my 7"Raspii3 touchscreen. See the picture. One thing I can't change is the text that is shown at all "Rookmelders" on page 2. The status is "Normal" but it say's "Rook gedetecteerd", could you please change this in the next release ?
I am still changing the layout of the second screen but it will fit some day.......
John
John
- htilburgs
You have to edit the custom.css and put the next part in there (I've updated the wiki alsoDingetje2004 wrote:What code do I have to add in custom css for making the icons a little bigger? thanks!htilburgs wrote:I see what you mean. Just cleaned up the // in the wiki.HansieNL wrote: Well done job!!!
.fa-lightbulb-o:before{
font-size: 24px;
}Hardware:
- wizjos
Nice! Care to share?westd001 wrote:I made some modifications so the dashboard layout fitts on my 7"Raspii3 touchscreen.
Regards,
Wizjos
- EdwinK
- Domoticz version: BETA
Looks great.westd001 wrote:Hi Rob and others,
John
pvdhelm
is it gonna rain script doesn't work for me. Get the following error in domoticz
what kind of virtual switch do i have to make. My switch only prints HELLO WORLD2017-04-15 11:00:00.254 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_rain.lua: /home/pi/domoticz/scripts/lua/script_time_rain.lua:165: bad argument #1 to 'sub' (string expected, got nil)
robgeerts
Thansk, really appreciate it!westd001 wrote: I follow this topic for a few weeks now and it's really great to see the progress in the development of the dashboard. Thanks for that, and I will make an donation for your tabblet![]()
Could you send me the output of that device?westd001 wrote: One thing I can't change is the text that is shown at all "Rookmelders" on page 2. The status is "Normal" but it say's "Rook gedetecteerd", could you please change this in the next release ?
robgeerts
I just tested this in latest version and its working for me...freakshock wrote:Hi Rob,
Amazing dashboard! I like how most of it works straight out of the box. One question, is it normal behavior that the buienradar image does not refresh on its own? Does it only refresh with a full page refresh? Tested this with chrome on android and Windows. Thanks
Could you test this?
Could you test latest version?rbo0567 wrote:If there is something I can help you with, please let me know.robgeerts wrote:I didnt test with multiple cams yet... will do this soon!rbo0567 wrote:Hi Rob,
I'm following this thread a couple of days now and I appreciate your work in this thread a lot.
For me it became more interesting when the camera's got your attention. Tried it after downloading the latest version of Dashticz but can only get 1 camera working at the same time. I made a screen specially for 4 cams but I see only the image of 1 cam (4 times).
Am I doing something wrong?
Dropshot
What will be the most convenient way to update this dashboard to the latest version?
robgeerts
Backup your config.js and custom.css en download the latest version.
Overwrite your existing files.
Or, if you use git on your computer, just use the pull-function
Blueone
I created a cgi script which can be used to change the brightness off the original raspberry touchscreen:
Sources I used:
https://code-maven.com/set-up-cgi-with-apache for setting up cgi in the raspberry
https://github.com/linusg/rpi-backlight, this api is being used simply install by following the instruction on the page
Attached the cgi script based on python (rename to cgi). Simple to use:
http://127.0.0.1/cgi-bin/screen_brightn ... ghtness=11
A valid brightness is between 11-255
a brightness of 0 turns the screen off
I would be great if this one can be added to the stand-by function. Also the text in stand-by is now grey, it would be nice if the text is real white. In the case the text can still be read with a low brightness in the evening from a distance on the couch or something
btw, it is a pyton script, don't change it with a windows text editor.
Sources I used:
- screen_brightness.cgi.txt
- (752 Bytes) Downloaded 95 times
robgeerts
If you want the text to be white, add to custom.css:
I cannot use cgi in my scripts.
I could make a setting that the dashboard has to call an url when going to standby.
.standby .row {
opacity:1 !important;
westd001
Wizjos,
Here is the code, i only changed config.js, creative.js and the background (attached).
config.js:
just changed this part in creative.js:
Rob, this is the output of a "Smoke detector"
config.js:
var _LANGUAGE = 'nl_NL'; //or en_US
var _HOST_DOMOTICZ = 'http://192.168.x.x:xxxx';
var _HOST_ZIGGO_HORIZON = ''; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND = 'xxxxxxx';
var _WEATHER_CITY = 'Delft';
var _WEATHER_COUNTRY = 'NL';
var _USE_AUTO_POSITIONING = false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES = false; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK = true; //do not show the seconds in the clock
var _NEWS_RSSFEED = 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT = false;
var _STANDBY_AFTER_MINUTES = false; //enter amount of seconds like: 5 (5 seconds)
var buttons = {}
buttons.buienradar = {width:12, isimage:true, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}
buttons.camerakeuken = {width:6, image: 'img/SecurityCam.png', title: 'Camera Keuken', url: 'http://192.168.x.x:xxx/snapshot.cgi?user=xxxx&pwd=xxxxx&rate=1'}
buttons.camerablokhut = {width:6, image: 'img/SecurityCam.png', title: 'Camera Blokhut', url: 'http://192.168.x.x:xxxx/snapshot.cgi?user=xxxx&pwd=xxxxx&rate=1'}
"CUSTOM POSITIONING:"
//defining wich blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
var blocks = {}
blocks[12] = {}
blocks[12]['width'] = 6;
blocks[64] = {}
blocks[64]['width'] = 6;
blocks[66] = {}
blocks[66]['width'] = 6;
blocks[109] = {}
blocks[109]['width'] = 6;
blocks[116] = {}
blocks[116]['width'] = 6;
blocks[423] = {}
blocks[423]['width'] = 6; //1 to 12, remove this line if you want to use the default (4)
blocks[425] = {}
blocks[425]['width'] = 6;
blocks[435] = {}
blocks[435]['width'] = 6;
blocks[436] = {}
blocks[436]['width'] = 12;
blocks[443] = {}
blocks[443]['width'] = 12;
blocks[479] = {}
blocks[479]['width'] = 6;
blocks[485] = {}
blocks[485]['width'] = 6;
blocks[536] = {}
blocks[536]['width'] = 6;
blocks[576] = {}
blocks[576]['width'] = 6;
blocks[577] = {}
blocks[577]['width'] = 6;
blocks[716] = {}
blocks[716]['width'] = 6;
blocks[743] = {}
blocks[743]['width'] = 6;
blocks[753] = {}
blocks[753]['width'] = 6;
blocks[801] = {}
blocks[801]['width'] = 6;
blocks[813] = {}
blocks[813]['width'] = 3;
blocks[814] = {}
blocks[814]['width'] = 3;
blocks[815] = {}
blocks[815]['width'] = 3;
blocks[816] = {}
blocks[816]['width'] = 3;
blocks[833] = {}
blocks[833]['width'] = 6;
blocks[841] = {}
blocks[841]['width'] = 6;
blocks[842] = {}
blocks[842]['width'] = 6;
blocks[843] = {}
blocks[843]['width'] = 12;
blocks['currentweather'] = {}
blocks['currentweather']['width'] = 12;
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['title'] = 'Weersvoorspelling';
//defining number of columns, their contents en widths
//width can be a number 1 to 12, but total widths of all columns should always be 12
var columns = {}
columns[1] = {}
columns[1]['blocks'] = [753,716,425,743,66,423,485,436,443] //remark: idx 144 produces 2 blocks, so you can use: '144_1' and '144_2' (or of course, just 144 if you want one)
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['currentweather','weather',843,814,815,816]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise',buttons.buienradar,buttons.radio,buttons.nunl]
columns[3]['width'] = 2;
columns[4] = {}
columns[4]['blocks'] = [64,833,109,116,576,577,479,801]
columns[4]['width'] = 5;
columns[5] = {}
columns[5]['blocks'] = ['12_1','536_1','12_2','536_2',buttons.camerakeuken,buttons.camerablokhut]
columns[5]['width'] = 5;
columns[6] = {}
columns[6]['blocks'] = ['clock']
columns[6]['width'] = 2;
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'brushed-metallic-backgroud800x480_3.jpg';
screens[2] = {}
screens[2]['background'] = 'brushed-metallic-backgroud800x480_3.jpg';
screens[2]['columns'] = [4,5,6]
.slider-pagination {
position: absolute;
bottom: 20px;
width: 95%;
left: 0;
text-align: right;
z-index: 1000;
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Normal",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 3,
"HardwareName" : "RFXCOM",
"HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
"HardwareTypeVal" : 1,
"HaveDimmer" : false,
"HaveGroupCmd" : false,
"HaveTimeout" : false,
"ID" : "6B9D00",
"LastUpdate" : "2017-04-07 13:27:43",
"MaxDimLevel" : 0,
"Name" : "Rookmelder Overloop (M)",
"Notifications" : "true",
"PlanID" : "5",
"PlanIDs" : [ 5, 6 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : 4,
"Status" : "Normal",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "KD101 smoke detector",
"SwitchType" : "Smoke Detector",
"SwitchTypeVal" : 5,
"Timers" : "false",
"Type" : "Security",
"TypeImg" : "smoke",
"Unit" : 0,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "576"
},- Attachments
- brushed-metallic-backgroud800x480_3.jpg (59.1 KiB) Viewed 2651 times
Blueone
Isn't it possible to call this url http://127.0.0.1/cgi-bin/screen_brightn ... ghtness=11 when this script is added by the user? If not, I can also create a simple HTML which can be put in the webserver which run's the cgi.robgeerts wrote:If you want the text to be white, add to custom.css:
I cannot use cgi in my scripts.Code: Select all
.standby .row { opacity:1 !important; }
- EdwinK
pvdhelm wrote:is it gonna rain script doesn't work for me. Get the following error in domoticz
You need to have a txt switch AND an ON/OFF switch. Make sure that the name you give the ON/OFF-switch is exactly the same as in the script. Also, a NILL error can mean that the temp file isn't created or writable. I believe user hansienl has writen something about that in this topic.
