domoticz in synology as package! Available now.
Gravityz
- Domoticz version: 2025.1
oh
just one last question.
will the KwH and watt numbers from the power devices also be saved inside the DB
just checking before i loose a year of history
umbr3lla
I am running Domoticz on my Synology Xpenology box running DSM 6.0.1 and now my RFXCOM no longer works.
I have also installed the UsbSerialDrivers_DSM-6.0 drivers from Jadhal but still no joy.
In the logs this is what I get:
Error: RFXCOM: Error opening serial port!
In the hardware page I cannot select anything under the serial port either as shown below:
imagehosting
Anyone know how I can get around this and get it working again?
imagehostingAnyone know how I can get around this and get it working again?
Gravityz
uninstalled v7149
installed v5877(stable
restored database backup
had to start stop zwave a couple of times
had to restore config files which weree not accurate back then(zwcfg delete, manufacturer update, config files update)
and then everything was like it was before.
timeouts seem to be much less, so there has definately changed something which affects timeouts.
i do not think these time outs are generated from within the Zwave network but the seem to be generated between the zwave device and domoticz.
anyway thanks Jumbotroll
bertbigb
Hi jumbotroll,
In the item Xiaomi Smart Home Suite (very cheap) compatibilty corbin created a lot of nice stuff and put it in the beta.
Can you please be so friendly and make a beta package out of that for us?
Would be nice and thanks anyway
Best regards,
Bert
Best regards,
Bert
Best regards Bert
Synology DS1517+ - DSM 6.2
- mvveelen
Every Friday new packages are made by him. So if you can wait another 2 days, that would make it a lot easier for him (he makes a lot of versions for different DSM version, with or without Python plugin).
But maybe he can do you a favor
digimate
- Domoticz version: lastbeta
Yes, would be great!!bertbigb wrote:Hi jumbotroll,
Best regards,
Bert
Synology DS716+. Domotica devices (on about 30): KaKu (and other 433MHz devices), Z-Wave, Mi-Light, Xiaomi.
bertbigb
Of course I can wait (I didn't know from the Friday).mvveelen wrote:Every Friday new packages are made by him. So if you can wait another 2 days, that would make it a lot easier for him (he makes a lot of versions for different DSM version, with or without Python plugin).
But if he can do me a favor that would be wonderful!
I can only imagine how big the job is what jumbotroll is doing for all of us Synology-users and I enjoy his work everyday.
Best regards Bert
- mvveelen
Jumbotroll is always very helpful. That's one of the reasons I made a donation for his work.....
- jumbotroll
Updating some packages tonight, so you guys can test Xiaomi
http://www.jadahl.com/domoticz_beta_6.1/
https://paypal.me/Jumbotroll
Jumbotroll
Jumbotroll
- EdwinK
- Domoticz version: BETA
Just downloaded the newest version again. Looking great again.
bertbigb
Thanks, you are great!! Nice to have this new Xiaomi stuff to play with.jumbotroll wrote:Updating some packages tonight, so you guys can test Xiaomi
Best regards Bert
haholukr
- Domoticz version: 3.0.7253
When betta is expected bromolow-5.2_3.0.7295-7 )
I want to try it! Thanks!
- jumbotroll
Updatedhaholukr wrote:When betta is expected bromolow-5.2_3.0.7295-7 )
domoticz_bromolow-5.2_3.0.7320-7.spk
http://www.jadahl.com/domoticz_beta/
Jumbotroll
Jumbotroll
haholukr
Thank you very much! I'm happy!jumbotroll wrote:Updatedhaholukr wrote:When betta is expected bromolow-5.2_3.0.7295-7 )
I want to try it! Thanks!![]()
matsumoto
- Domoticz version: V3.9483
When possible, i'd like an updated package for DS413j with DSM 5.2.
Many thanks !
Many thanks !
Venemans
- Domoticz version: V3.7324
Just started using Domoticz.
Can you make an updated package for the DS410 with DSM 5.2 Beta?
Because I think with the update my Milight Ibox2 will be recognized and work.
Thanks for the great work.
- jumbotroll
Updated to Domoticz v3.0.7324-7Venemans wrote:Just started using Domoticz.
http://www.jadahl.com/domoticz_beta/?arch=ppc853x
Jumbotroll
Jumbotroll
- jumbotroll
Updated to Domoticz v3.0.7324-7matsumoto wrote:When possible, i'd like an updated package for DS413j with DSM 5.2.
Many thanks !
http://www.jadahl.com/domoticz_beta/?arch=88f6282
Jumbotroll
Jumbotroll
Venemans
Thank you very much for the quick updatejumbotroll wrote:Updated to Domoticz v3.0.7324-7Venemans wrote:Just started using Domoticz.
Thanks for the great work.![]()
Do this work now. I can se 1wire in hardware. I cant get this to work i doint no what im doing wrong. i can se and add z-wave sticks. Im using the latest Domoticz. It had bin so nice to get that to work.jumbotroll wrote:I will look into it.pepeEL wrote:No no
It also works on USB
I now use Raspberry with Domoticz and have connected to raspberry adapter 1wire usb DS9490r and it works perfect. Only Domoticz need to install owfs on raspberry.
Wysłane z mojego SM-G920F przy użyciu Tapatalka
Jumbotroll
