mvveelen
Post by mvveelen »
bing69 wrote:
mvveelen wrote:
deennoo wrote:À exemple is on the wiki
Reading it already :D
Although I have to see how (and IF) I can upload an MP3 to the Gateway with the Mi Home app on my iPhone......Just for testing purposes of course :mrgreen:
With the app, press record by the sounds...
Unfortunately there is no such option in the iPhone app. I forgot to take the Samsung from work, so I can try that tomorrow.
bing69
Post by bing69 »
Om my iphone 7 there is a option
deennoo
Post by deennoo »
Mp3 is iOS compatible of course, i test it
http://domo-attitude.fr
mvveelen
Post by mvveelen »
bing69 wrote:
mvveelen wrote:
bing69 wrote: With the app, press record by the sounds...
Huh? Same hardware and software here, but where exactly can I find it?
Edit:
Ah, found it !
bing69
Post by bing69 »
I send a mail to you
marcotrumpet
Post by marcotrumpet »
Great job guys.. gateway alarm ringtone works perfect but I can't trigger it with blocky.. in the log I see "eventSystem: Malformed action sequence!" Tried both with Police siren 1 and "10"
Inviato dal mio iPhone utilizzando Tapatalk
mvveelen
Post by mvveelen »
Uploaded a (spoken) ringtone (thanks bing69), but will there be an option to upload an original mp3 file or can we only record the music and then upload it (loss of quality)?
Going to read some more on the Wiki :)
deennoo
Post by deennoo »
Hum can't try know for mp3 on iOS, but as iOS doesn't support mp3 natively definitly it can't...Switch to android
deennoo
Post by deennoo »
marcotrumpet wrote:Great job guys.. gateway alarm ringtone works perfect but I can't trigger it with blocky.. in the log I see "eventSystem: Malformed action sequence!" Tried both with Police siren 1 and "10"
As This is a selector switch use setlevel to xx%
mvveelen
Post by mvveelen »
If I need to upload an MP3 and Android supports it, then I will use a Samsung from work :D
chrispazz
Post by chrispazz »
With which frequency power consumption is detected?
Is it possible to have an event triggered with a power consumption variation?
Thank you
deennoo
Post by deennoo »
chrispazz wrote:With which frequency power consumption is detected?
Thank you
Power consumtion isn't immédiate, it doesn't have any Time setting that mean you can't use it for Real Time watchi'g
mvveelen
Post by mvveelen »
@corbin: the battery status for the door/window sensors is still hard-coded to 3Volt ? Will this be corrected in a new update or am I missing something ?
deennoo
Post by deennoo »
For me each one got different value, have to check this
bing69
Post by bing69 »
mvveelen wrote:@corbin: the battery status for the door/window sensors is still hard-coded to 3Volt ? Will this be corrected in a new update or am I missing something ?
I have 4 door sensors with a value of 3.025, 3.045 and 2 * 3.065
mvveelen
Post by mvveelen »
I'll delete them and add them again, maybe that helps. Although 3V could be correct, because I haven't used them yet :D
Edit: can't add them after deleting them. There are no unused devices found even if I have the option enabled to accept new Hardware Devices.....hmmm... Maybe I have to wait (much) longer ?
mrefex
Domoticz version: 3.7041
Xiaomi Smart Home Suite Doorbell trigger
Post by mrefex »
I installed the gateway and added the Doorbell gateway and volume and mp3.
My question is how to send a command to the gateway to play the doorbell sound.
mvveelen
Post by mvveelen »
Anybody a solution for this?
Do I have to remove the whole gateway perhaps (I hope not)? Or is there another way to get the battery statuses back in Domoticz? After waiting a few hours, they are still not back in the (unused) devices list.
bing69
Post by bing69 »
Do you use the switch???
mvveelen
Post by mvveelen »
What switch? I use the doorsensors and would like to have the battery statuses (back) in Domoticz.
