I do have them.
Tested on version 7276 and Corbin's 7165 (Friday compile).
When you do the off action via the app, the log receives the command, but not domoticz
2017-04-10 11:08:13.141 {"cmd":"report","model":"ctrl_neutral2","sid":"158d000153cb9d","short_id":21851,"data":"{\"channel_1\":\"off\"}"}
It is indeed only channel 1, channel 0 status change is detected
Btw, it is not only via the app, if you use the physical button for channel 1, the off toggle is also not detected
- corbin
The channel_1 updating should now be working correctly, see my latest commit
Nice, will do a compile when I come home, will report back
Yeap solve ! That perfect !corbin wrote:The channel_1 updating should now be working correctly, see my latest commit
http://domo-attitude.fr
Thx for your report ! I was thinking that i was alone to use those device and get this error.joebar wrote:I do have them.
Hello, what can you do with the "Xiaomi Gateway MP3". I can not find any use for it.
i'm on the wiki for this as corbin works was merge to official beta, don't be nervous guy !schurgan wrote:Hello, what can you do with the "Xiaomi Gateway MP3". I can not find any use for it.
- mvveelen
@deennoo, I don't think it's fair to call everybody "nervous" when they ask a question. I'm not nervous, and I think schurgan isn't nervous too
But: we appreciate everybody's help with the Xiaomi gateway and it's peripherals, and we're looking forward to the next Beta of Domoticz in which new bits and pieces will be added. Keep up the good work and thanks again !
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
Domoticz Wiki is update for new sound feature: https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara)
Domoticz dev accept Corbin update, this will be on beta very soon !
Don't forget, to see Sound Switch, you have to allow new device, on parameter, and goes to hardware select your Xiaomi Gateway, and clik on Modify.
Then thoses switch will be shown on unused Device Tab.
Hello deennoo,deennoo wrote:i'm on the wiki for this as corbin works was merge to official beta, don't be nervous guy !
I'm not nervous. It is also a logical question, what can be done with the thing or do I make something wrong?
'm not nervous, I feel confident that it will be fine.
But now I'm excited, I have the beta and everything's in !!
You can't made something wrong when it's not explain how to use it and how it work, lots of users (not naming you in particular) asking to have this feature, or report about voltage problem but they are just not able to read how to test dev fork, or be patient to wait for final release. this cause some nervous anwer and felling.schurgan wrote:Hello deennoo,deennoo wrote:i'm on the wiki for this as corbin works was merge to official beta, don't be nervous guy !
Now all is present to enjoy those hardware fully, next limit is to be able to read this topic and the wiki.
- G3rard
- Target OS: -
- Domoticz version: No
@corbin, @deennoo
Thanks for the new features and the updated wiki!
Really enjoying these Xiaomi features in Domoticz
Not using Domoticz anymore
Sorry bit late, good job.. solvedcorbin wrote:The channel_1 updating should now be working correctly, see my latest commit
2017-04-11 18:13:41.105 (Xiaomi Gateway) Light/Switch (Plafond spots)
2017-04-11 18:13:41.465 {"cmd":"report","model":"ctrl_neutral2","sid":"158d000153cb9d","short_id":21851,"data":"{\"channel_1\":\"off\"}"}
Of course I can read and waited for the release. I use only the official betas. And then I saw the device, but could not do anything with him and asked politely. You're doing a great job and I'm also grateful, but I think you should be more relaxed.deennoo wrote:You can't made something wrong when it's not explain how to use it and how it work, lots of users (not naming you in particular) asking to have this feature, or report about voltage problem but they are just not able to read how to test dev fork, or be patient to wait for final release. this cause some nervous anwer and felling.schurgan wrote:Hello deennoo,deennoo wrote:i'm on the wiki for this as corbin works was merge to official beta, don't be nervous guy !
i'm agree with you and i want to be relaxed, why fill you agressed ? you ask for a thing that i was working on it, remember domoticz is a freeware and we do it for fun, i know some app where xiaomi plugin is for 6€ and wiki isn't easy to read like ours.schurgan wrote:Of course I can read and waited for the release. I use only the official betas. And then I saw the device, but could not do anything with him and asked politely. You're doing a great job and I'm also grateful, but I think you should be more relaxed.deennoo wrote:You can't made something wrong when it's not explain how to use it and how it work, lots of users (not naming you in particular) asking to have this feature, or report about voltage problem but they are just not able to read how to test dev fork, or be patient to wait for final release. this cause some nervous anwer and felling.schurgan wrote:
Hello deennoo,
just anserwing about pikpat comment about, if you take it for you ok ! not my problem.
- mvveelen
Just updated to the latest Domoticz beta and....Hello new Xiaomi devices
!! Going to play with the new features and see what I can do with the MP3's
À exemple is on the wiki
- mvveelen
Reading it alreadydeennoo wrote:À exemple is on the wiki
Although I have to see how (and IF) I can upload an MP3 to the Gateway with the Mi Home app on my iPhone......Just for testing purposes of course
With the app, press record by the sounds...mvveelen wrote:Reading it alreadydeennoo wrote:À exemple is on the wiki
