robgeerts
- Domoticz version: 3.7067
Re: New Dashboard Design v2, custom positioning and multiple screens
Cool!
If something still doesnt work, make sure you've the latest version!
koowee
It seems that there is a small problem with windspeed using netatmo? I think that it should be m/s, not km/u or h
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"Chill" : 0.0,
"CustomImage" : 0,
"Data" : "323.00;NW;14;31;0.0;0.0",
"Description" : "",
"Direction" : 323.0,
"DirectionStr" : "NW",
"Favorite" : 0,
"Gust" : "3.1",
"HardwareID" : 13,
"HardwareName" : "Netatmo",
"HardwareType" : "Netatmo",
"HardwareTypeVal" : 54,
"HaveTimeout" : false,
"ID" : "1443",
"LastUpdate" : "2017-04-07 20:23:06",
"Name" : "Wind Gauge",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Speed" : "1.4",
"SubType" : "Weather Station",
"Timers" : "false",
"Type" : "Wind",
"TypeImg" : "wind",
"Unit" : 0,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "188"
robgeerts
Fixed in latest version, the icon now also rotates to the right direction!koowee wrote:It seems that there is a small problem with windspeed using netatmo? I think that it should be m/s, not km/u or h
- EdwinK
- Domoticz version: BETA
- EdwinK
Thanks. that fixed it.
- heggink
- Domoticz version: 12451
Hey Rob,
Just tried your latest release. I can't get the alignment to work for my ipad2. Any suggestions?
H
H
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
robgeerts
Could you try latest version?heggink wrote:Hey Rob,
By the way, someone interested in using charts?
pvm
- Domoticz version: 4.10538
Wow, really nice progress
Guess I have to do some sponsoring for your tablet too
(will be done in a couple of minutes)
Result so far (in my temporary home, most of my devices are not installed)
I do have some issues:
-The dashboard does not function completely in IE 11 (no issue for me, possibly for others)
-I am using 2 dummy hardware types, which do not display correct:
1: Dummy hardware displaying moisture of soil in percentage (0-100%)
2 Dummy hardware displaying foodvalue in soil in uS/cm
Do you see an option to display the correct values and add icons? Can I do this myself?
edit: sorry we were posting at the same time... I'll upgrade to the latest version and report back on the IPad layou
edit: Ah and yes interested in using charts. It is hard to keep up with all changes, big compliment to you!
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 100,
"CustomImage" : 11,
"Data" : "33 %",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 2,
"HardwareName" : "FlowerCare",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"HaveTimeout" : true,
"ID" : "00082018",
"Image" : "Water",
"LastUpdate" : "2017-03-30 19:15:42",
"Name" : "MijnPlantjeVocht",
"Notifications" : "true",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SensorType" : 1,
"SensorUnit" : "%",
"SubType" : "Custom Sensor",
"Timers" : "false",
"Type" : "General",
"TypeImg" : "Water",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "18"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 15,
"Data" : "310 uS/cm",
"Description" : "Voedingsstoffen >500?",
"Favorite" : 1,
"HardwareID" : 2,
"ID" : "00082025",
"Image" : "Heating",
"Name" : "MijnPlantjeVoeding",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SensorType" : 1,
"SensorUnit" : "uS/cm",
"Timers" : "false",
"Type" : "General",
"TypeImg" : "Heating",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "25"
- dashipad.jpg (213.26 KiB) Viewed 3236 times
robgeerts
Thanks!pvm wrote:Wow, really nice progress
Guess I have to do some sponsoring for your tablet too(will be done in a couple of minutes)
Since it will be mostly used on tablets, this wont be an issue, but will fix as much as possiblepvm wrote: -The dashboard does not function completely in IE 11 (no issue for me, possibly for others)
Fixed in latest version!pvm wrote: -I am using 2 dummy hardware types, which do not display correct:
Wich icon do you prefer with the foodvalue?
In domoticz you use a heating icon?
I know, try to fix as much as possible!pvm wrote: I've tested the layout for the IPad in chrome by selecting the ipad as device. I have similar layout issues as mentioned by heggink:
Thanks!!pvm wrote: Ah and yes interested in using charts. It is hard to keep up with all changes, big compliment to you!
pvm
I would like the cutlery iconrobgeerts wrote:Fixed in latest version!pvm wrote: -I am using 2 dummy hardware types, which do not display correct:
Thanks again for the quick fixes, downloading latest version now
robgeerts
Download it again
Just added the cutlery icon
Good night!
Good night!
- heggink
Hey Rob,
ipad looks muuch better! Thx.
Couple of items:
1) all of my percentage (memory, CPU, sensors) show as on/off. See json output below.
2) Same for 'distance' devices
3) barometer and humidity show 2 decimals (see eralier picture) and barometer uses % instead of hPa (below as well)
Many thanks again. Couple of beers coming up.
H
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"Barometer" : 1026,
"CustomImage" : 0,
"Data" : "9.5 C, 83 %, 1026 hPa",
"Description" : "",
"DewPoint" : "6.76",
"Favorite" : 1,
"Forecast" : 3,
"ForecastStr" : "Cloudy",
"HardwareID" : 9,
"HardwareName" : "Weather Lelystad",
"HardwareType" : "Weather Underground",
"HardwareTypeVal" : 14,
"Humidity" : 83,
"HumidityStatus" : "Wet",
"ID" : "0001",
"LastUpdate" : "2017-04-07 23:34:56",
"Name" : "Lelystad Barometer",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SubType" : "THB1 - BTHR918, BTHGN129",
"Temp" : 9.5,
"Timers" : "false",
"Type" : "Temp + Humidity + Baro",
"TypeImg" : "temperature",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"forecast_url" : "aHR0cDovL3d3dy53dW5kZXJncm91bmQuY29tL2NnaS1iaW4vZmluZHdlYXRoZXIvZ2V0Rm9yZWNhc3Q/cXVlcnk9cHdzJTNBSUZMRVZPTEExNw==",
"idx" : "37"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "4.30%",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 50,
"HardwareName" : "Sensors",
"ID" : "00082548",
"Image" : "Computer",
"LastUpdate" : "2017-04-07 23:40:02",
"Name" : "Domoticz memory",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SubType" : "Percentage",
"Timers" : "false",
"Type" : "General",
"TypeImg" : "hardware",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "548"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "3.36%",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 50,
"ID" : "00082553",
"LastUpdate" : "2017-04-07 23:40:01",
"Name" : "Domoticz CPU",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Timers" : "false",
"Type" : "General",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "553"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "16.5 cm",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 44,
"HardwareName" : "Distance",
"ID" : "00082514",
"LastUpdate" : "2017-04-07 23:16:25",
"Name" : "Rosa Distance",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SubType" : "Distance",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "General",
"TypeImg" : "visibility",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "514"
Couple of items:
H
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"Barometer" : 1026,
"CustomImage" : 0,
"Description" : "",
"Favorite" : 1,
"Forecast" : 3,
"HardwareID" : 9,
"Humidity" : 83,
"ID" : "0001",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Temp" : 9.5,
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "37"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "4.30%",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 50,
"ID" : "00082548",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Timers" : "false",
"Type" : "General",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "548"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "3.36%",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 50,
"ID" : "00082553",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Timers" : "false",
"Type" : "General",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "553"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "16.5 cm",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 44,
"ID" : "00082514",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Timers" : "false",
"Type" : "General",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "514"
DASHTICZ 🙃
DASHTICZ 🙃
- heggink
forgot: on gitlab it says that things get removed on update. Are you sure? I used another main page already which is located in www as well and that just stays there. In your case, you use index.html as well which is domoticz' default so that DOES get overwritten with teh standard domoticz index.html (reason why I rename it myself before moving into www).
DASHTICZ 🙃
DASHTICZ 🙃
robgeerts
Thnx for the beers! Will check tomorrow about your devices! About updating.... Its better to move my dashboard in a subfolder I guess?
pvm
Thnx, layout issues for iPad are fixed (i'm just using too long names now... i should be able to shorten them)
- mAiden88
- Domoticz version: 3.7286
Maybe someone can help me..
Change CONFIG.js to right IP and place to Domoticz on my PI.
It don't starts this nice dashboard.. Even when i try to IP:PORT/index.html it starts Domoticz Dashboard.. (ofc i upload in www folder from Domoticz
If a starts index on the map, i get this >>> http://prntscr.com/etvhz4
What do i wrong?
What do i wrong?
Anyone can build a fast processor. The trick is to build a fast system.
robgeerts
Install it in a subfolder in the www directory and call it by: IP:PORT/subfolder/index.html
- mAiden88
You kidding me? It is just so easy? I am ashamed as an application developer.robgeerts wrote:Install it in a subfolder in the www directory and call it by: IP:PORT/subfolder/index.html
Thanks its working now.. Lets see what i can make now..
Dingetje2004
Gr8 Work ROB! What are the possibilities to add webcam support. I do have an image in your dashboard from my front door cam, but does not refreshes. I created a new button in CONFIG. I would alsolike to have it refreshed without refreshing the whole page every seconded. I was thinking something like this, but unfortunately does not work, nor does Iframe work.
I am using this piece of code in another dashboard and works for me. You know what to do best?
[img][/img]
<img src="http://192.168.178.10:99/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USERNAME&pwd=PASSWORD&t=" onClick="lightbox_open('camera', 25400);" "width="222px" height="155px" onload='setTimeout(function() {src = src.substring(0, (src.lastIndexOf("t=")+2))+(new Date()).getTime()}, 1000)' onerror='setTimeout(function() {src = src.substring(0, (src.lastIndexOf("t=")+2))+(new Date()).getTime()}, 5000)' alt='' />[img][/img]
