Locked
heggink
Domoticz version: 12451
Re: New Dashboard Design
Post by heggink »
Hey Rob, is the thermostat already generic enough to cover my Nest? If so then I can safely upgrade as well ️.
Verstuurd vanaf mijn HUAWEI NXT-L29 met Tapatalk
DASHTICZ 🙃
P1 meter & solar panel
HansieNL
Post by HansieNL »
robgeerts wrote:Ah, great!
I didn't see it ;)
It's fixed in the next version (not pushed to Gitlab yet but will be when I finished the arrange-function, hopefully tonight)
Thanks.
If you go faster than light you can miss something :D ;)
Is it gonna work for all selector switches?
Blah blah blah
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
heggink wrote:Hey Rob, is the thermostat already generic enough to cover my Nest? If so then I can safely upgrade as well Image️.
Could you send me the json-output?
robgeerts
Post by robgeerts »
BETA BETA BETA
Want to test the latest version where you can arrange the blocks yourself?
Download the ZIP from (REMOVED LINK,VISIT GITLAB)
Copy the contents to a NEW SUBFOLDER, so do not overwrite your existing dashboard.
Copy CONFIG-DEFAULT.js to CONFIG.js and change according your needs.
You need to know the IDX of every device you want to show!!
You can create extra/less columns with a desired width and with the desired blocks.
Disclaimer:
Remember it may possible things wont work correctly so dont use it as your main dashboard.
Your wife/husband could get angry ;)
EDIT: BETA IS NOW IN GITLAB!
Last edited by robgeerts on Thursday 06 April 2017 10:07, edited 5 times in total.
heggink
Post by heggink »
Nest:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "21.3",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 40,
"HardwareName" : "Thermostat",
"HardwareType" : "Nest Thermostat/Protect",
"HardwareTypeVal" : 52,
"HaveTimeout" : false,
"ID" : "0000001",
"LastUpdate" : "2017-04-05 18:14:55",
"Name" : "Home Temp",
"Notifications" : "false",
"PlanID" : "3",
"PlanIDs" : [ 3 ],
"Protected" : false,
"SetPoint" : "21.3",
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "SetPoint",
"Timers" : "false",
"Type" : "Thermostat",
"TypeImg" : "override_mini",
"Unit" : 0,
"Used" : 1,
"XOffset" : "545",
"YOffset" : "204",
"idx" : "388"
Dummy P1 device:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"Counter" : "38624.279",
"CounterDeliv" : "8124.372",
"CounterDelivToday" : "1.083 kWh",
"CounterToday" : "20.460 kWh",
"CustomImage" : 0,
"Data" : "19911754;18712525;2239784;5884588;0;190",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 52,
"HardwareName" : "P1 Meter",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"ID" : "82603",
"LastUpdate" : "2017-04-05 18:15:07",
"Name" : "Energy Grid",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SubType" : "Energy",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "P1 Smart Meter",
"TypeImg" : "counter",
"Unit" : 1,
"Usage" : "0 Watt",
"UsageDeliv" : "190 Watt",
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "603"
Cheers!
DASHTICZ 🙃
Dynamic
Post by Dynamic »
robgeerts wrote:BETA BETA BETA
Download the ZIP from https://drive.google.com/file/d/0B3wQhk ... dON2s/view
Disclaimer:
You have left some personal data in the config_default.js. Your Wunderground API-key is still there ;-)
robgeerts
Post by robgeerts »
Aha! Well, not a big deal, its a free version ;)
Dynamic
Post by Dynamic »
How can I manual add a scene? They can have the same IDX as a device.
robgeerts
Post by robgeerts »
heggink wrote:Nest:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "21.3",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 40,
"ID" : "0000001",
"PlanID" : "3",
"PlanIDs" : [ 3 ],
"Timers" : "false",
"Unit" : 0,
"Used" : 1,
"XOffset" : "545",
"YOffset" : "204",
"idx" : "388"
Dummy P1 device:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Description" : "",
"Favorite" : 1,
"HardwareID" : 52,
"ID" : "82603",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Timers" : "false",
"Unit" : 1,
"Usage" : "0 Watt",
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "603"
Cheers!
Wich one do you wanna see with the P1?
"Usage" : "0 Watt",
robgeerts
Post by robgeerts »
Dynamic wrote:How can I manual add a scene? They can have the same IDX as a device.
I have to implement this, i'm thinking of prepend an S like:
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',1,2,'s233']
columns[1]['width'] = 3;
(s233 would be a scene)
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
Its already working. I to have a nest thermosaat.
robgeerts
Post by robgeerts »
Well, his Nest is not exactly the same, i tested his output and its not correct 100%, will fix this later tonight.
Dynamic
Post by Dynamic »
robgeerts wrote:I have to implement this, i'm thinking of prepend an S like:
columns[1] = {}
Looks good to me...
I've been playing around and I love to customize the dashboard! However, I'm having some small isues with the icons. There are not correct positioned:
Edit: current weather is now OK. I had to remove the 'width'. But I can't fix the sonos-buttons...
robgeerts
Post by robgeerts »
Thanks for the feedback, will fix this in de next version!
EdwinK
Post by EdwinK »
Not going to dive into this just yet. All those numbers are confusing me. Maybe I will give it a try next weekend.
robgeerts
Post by robgeerts »
I understand! I'm thinking of a way to build up the page without configuring all the devices but to make use of some defaults... This will be easier (and fine) for many users.
SwordFish
Post by SwordFish »
@robgeerts
I really appreciate how quick you jump in the problems we send
EdwinK
Post by EdwinK »
Yes, I think Rob is doing an awful lot of work for us. Fixing problems almost as soon as we have send them.
robgeerts
Post by robgeerts »
Dynamic wrote: I've been playing around and I love to customize the dashboard! However, I'm having some small isues with the icons. There are not correct positioned:
Should be better now!
BETA 3: https://drive.google.com/file/d/0B3wQhk ... sp=sharing
EdKo66 wrote:Not going to dive into this just yet. All those numbers are confusing me. Maybe I will give it a try next weekend.
I've just fixed that if you dont want to position every device, he tries to do this automatically, I added these variables (default=true) in the BETA-version:
var _USE_AUTO_POSITIONING 	= true;
var _USE_FAVORITES			= true;
SwordFish wrote: I really appreciate how quick you jump in the problems we send Image
EdKo66 wrote:Yes, I think Rob is doing an awful lot of work for us. Fixing problems almost as soon as we have send them.
Last edited by robgeerts on Wednesday 05 April 2017 21:41, edited 1 time in total.
robgeerts
Post by robgeerts »
SwordFish wrote: Its already working. I to have a nest thermosaat.
Could you send me your nest output?
Locked
