ddahya
Re: New Dashboard Design
just noticed in that my setpoint devices are not showing up at two devices in the Dashboard
- Setpoint Device 2.JPG (21.78 KiB) Viewed 2851 times
- Setpoint Device 1.JPG (21.2 KiB) Viewed 2851 times
robgeerts
- Domoticz version: 3.7067
Aren't they also positioned in the left column?ddahya wrote:just noticed in that my setpoint devices are not showing up at two devices in the Dashboard
Could you send me a complete screenshot?
And, if possible, the complete (all devices) json-output from domoticz, via PM?
- EdwinK
- Domoticz version: BETA
Worksrobgeerts wrote:
Could you test if this is working, add to creative.css:EdKo66 wrote: Just the two bottom (wind and barometer) should go up a little more.
(or download latest version)Code: Select all
.states > div { height:75px; } #switches > div { height:85px; }
robgeerts
@ALL:
Do define wich switches/states you want to show, I'm thinking of the following solution, if there's a file called POSITION.JS execute this, if not, parse everything the way it is currently. The contents could be something like:
In this case, everybody can arrange their dashboard according to their needs!
//defining wich blocks to show
var blocks = {}
blocks[23] = {}
blocks[23]['title'] = 'Dinner table'; //remove line if you want use title as defined in domoticz
blocks[23]['width'] = 2; //1 to 12, remove this line if you want to use the default (4)
blocks[35] = {}
blocks[35]['title'] = 'Living room'; //remove line if you want use title as defined in domoticz
blocks[35]['width'] = 2; //1 to 12, remove this line if you want to use the default (4)
blocks[76] = {}
blocks[76]['title'] = 'Stairs'; //remove line if you want use title as defined in domoticz
blocks[76]['width'] = 2; //1 to 12, remove this line if you want to use the default (4)
//defining number of columns, their contents en widths
//width can be a number 1 to 12, but total widths of all columns should always be 12
var columns = {}
columns[1] = {}
columns[1]['blocks'] = {23,35,76}
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = {'weather',1,67,128,'buttons'}
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = {'clock','sunrise','currentweather'}
columns[3]['width'] = 2;
ddahya
Just sent you all the details via PMrobgeerts wrote:Aren't they also positioned in the left column?ddahya wrote:just noticed in that my setpoint devices are not showing up at two devices in the Dashboard
- Dynamic
- Target OS: -
I think it's a good approach. If you need a beta-tester, count me in!robgeerts wrote:@ALL:
In this case, everybody can arrange their dashboard according to their needs!Code: Select all
//defining wich blocks to show var blocks = {} blocks[23] = {} blocks[23]['title'] = 'Dinner table'; //remove line if you want use title as defined in domoticz blocks[23]['width'] = 2; //1 to 12, remove this line if you want to use the default (4) blocks[35] = {} blocks[35]['title'] = 'Living room'; //remove line if you want use title as defined in domoticz blocks[35]['width'] = 2; //1 to 12, remove this line if you want to use the default (4) blocks[76] = {} blocks[76]['title'] = 'Stairs'; //remove line if you want use title as defined in domoticz blocks[76]['width'] = 2; //1 to 12, remove this line if you want to use the default (4) //defining number of columns, their contents en widths //width can be a number 1 to 12, but total widths of all columns should always be 12 var columns = {} columns[1] = {} columns[1]['blocks'] = {23,35,76} columns[1]['width'] = 5; columns[2] = {} columns[2]['blocks'] = {'weather',1,67,128,'buttons'} columns[2]['width'] = 5; columns[3] = {} columns[3]['blocks'] = {'clock','sunrise','currentweather'} columns[3]['width'] = 2;
- EdwinK
I would like that very much.robgeerts wrote:@ALL:
robgeerts
Already started with this and it's looking good!
SwordFish
- Domoticz version: V4.11375
Verry nicerobgeerts wrote:@ALL:
robgeerts
PROGRESS, THESE DIFFERENT LAYOUTS ARE ONLY DONE BY CHANGING STUFF IN CONFIG:
SwordFish
Looks nice.
Is it possible to move the weather witch now is located bij status to vooruitzichten?
robgeerts
You can move it to a place where ever you want
- HansieNL
@robgeerts: You're almost faster than light
Is it possible to have the selector switch show to the right selection instead of always "select"?
Blah blah blah
robgeerts
Well, it does at my dashboard...HansieNL wrote:@robgeerts: You're almost faster than light![]()
In this case, I can hide the left block...
- HansieNL
The Toon Setpoint is working great now!!! But I also have a selector switch to quickly select a presetted temperature.
Tried an other selector switch and it just shows "select" and not the selection already made. I hope it's more clear now.
Blah blah blah
robgeerts
What's the output of that selector?HansieNL wrote:The Toon Setpoint is working great now!!! But I also have a selector switch to quickly select a presetted temperature.
- HansieNL
I don't know if you can make it work default for every selector switch?robgeerts wrote:What's the output of that selector?HansieNL wrote:The Toon Setpoint is working great now!!! But I also have a selector switch to quickly select a presetted temperature.
This is for my Thermostaat selector switch:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 15,
"Data" : "On",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 2,
"HardwareName" : "Dummy",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "0001407F",
"Image" : "Heating",
"IsSubDevice" : false,
"LastUpdate" : "2017-04-05 15:08:06",
"Level" : 40,
"LevelActions" : "|http%3A//192.168.2.14%3A8080/json.htm%3Ftype%3Dcommand%26param%3Dthermostatstate%26idx%3D35%26state%3D0|http%3A//192.168.2.14%3A8080/json.htm%3Ftype%3Dcommand%26param%3Dthermostatstate%26idx%3D35%26state%3D1|http%3A//192.168.2.14%3A8080/json.htm%3Ftype%3Dcommand%26param%3Dthermostatstate%26idx%3D35%26state%3D2|http%3A//192.168.2.14%3A8080/json.htm%3Ftype%3Dcommand%26param%3Dthermostatstate%26idx%3D35%26state%3D3|",
"LevelInt" : 40,
"LevelNames" : "Off|Comfort|Thuis|Slapen|Weg|Hand",
"LevelOffHidden" : true,
"MaxDimLevel" : 100,
"Name" : "Thermostaat",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"SelectorStyle" : 0,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "On",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Selector Switch",
"SwitchType" : "Selector",
"SwitchTypeVal" : 18,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "Light",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "48"
Blah blah blah
robgeerts
I think the problem is that not of these levels (Off|Comfort|Thuis|Slapen|Weg|Hand) is set als active in the output...
What was the active state at the time you copied the output?
- HansieNL
"Weg" was selected. It must be this one: "LevelInt" : 40, or this on "Level" : 40,robgeerts wrote:I think the problem is that not of these levels (Off|Comfort|Thuis|Slapen|Weg|Hand) is set als active in the output...
Blah blah blah
robgeerts
Ah, great!
I didn't see it
It's fixed in the next version (not pushed to Gitlab yet but will be when I finished the arrange-function, hopefully tonight)
I didn't see it
